33bhp restrictor kit!
claaazy fazer
PostPosted: 11:16 - 02 Mar 2011    Post subject: 33bhp restrictor kit! Reply with quote
Anybody selling a discontinued restrictor kit for a yamaha 600 fazer? 1999 reg
I'm having great trouble in finding a restrictor kit that is not from the rip off company FI International. That company is a JOKE considering you are only paying for the certificate that you DONT even need!
Can any fellow bikers help me out here...?
claaazy fazer
PostPosted: 11:56 - 02 Mar 2011    Post subject: Reply with quote
rob yarrr wrote:
i've got some washers,you could get them made for like a tenner
messege a guy called 000dom000 and he might know the dimensions of what they should be
Okay thank you, i will message him, i've heard that yamaha also do their own way of restricting a bike without using washers :\ don't know what though
0l0dom0l0
PostPosted: 12:21 - 02 Mar 2011    Post subject: Reply with quote
Hi.
There are 3 'easy' ways of restricting it.
Washers in the inlet.
Different needles and springs with a restrictor plate to go in the top of the carb
Throttle stop.
Cant remember the dimensions off the top of my head but will have a look later.
Check Ebay regularly, a set will come up!
0l0dom0l0
PostPosted: 12:35 - 02 Mar 2011    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?t=213364&highlight=restrictor+dimensions
claaazy fazer
PostPosted: 13:50 - 02 Mar 2011    Post subject: Reply with quote
I've found 4 washers 38mm in diameter on my bench in work, crazy as it seems i don't know if they will work if i drill the hole in the centre big enough. i think its around 12mm??
PostPosted: 14:59 - 02 Mar 2011    Post subject: Reply with quote
Essentially any engine is restricted by the amount of fuel and air that it can suck in.
So for an IL4, I'd guesstimate 14mm holes, purely on the basis that:
GS500 restrictor = 20mm^2 * 2 = 800mm^2
So 14^2 * 4 = 784mm^2
I'll even sell you a bit of paper that guarantees(*) that you won't see more than 33bhp at the crank. Only £200! Wink
(*) Guarantee is non-binding and for novelty purposes only.
claaazy fazer
PostPosted: 20:45 - 03 Mar 2011    Post subject: Re: 33bhp restrictor kit! Reply with quote
Can anybody help me out in fitting my washers, i know they go between the carb and the cylinder head but how hard is it too get the carbs out on a 1998 fazer 600.
Cheers!
0l0dom0l0
PostPosted: 21:44 - 03 Mar 2011    Post subject: Reply with quote
Took me about 45 mins from running to running. Its really not hard!
Just undo the carb rubber straps and the air box straps. Make sure you also undo the 3 air box screws.
Pull the carbs off and move them up. You can now put the washers in!
claaazy fazer
PostPosted: 11:40 - 09 Mar 2011    Post subject: Reply with quote
Thanks mate, was just wondering how the washers are secured in... do they just sit between the carb on the head orrr?..
Any chance you could post any pictures aswell? Sorry for the meither!
0l0dom0l0
PostPosted: 22:51 - 09 Mar 2011    Post subject: Reply with quote
Procedure to fit the kit.
Remove fuel tank
Remove 2 side pannels on the bike (the one which has the seat lock in) that are held in by one 4mm alen key.
Undo the screws that clamp the airbox onto the carbs
Pull back airbox
Undo screws that clamp the carbs in the lnlet rubbers
Pull back carbs
put the kit in the inlet rubbers (it will be very tight, this is normal)
Carbs back on
Reverse order the rest.
The washers are held in by the carbs, they have no were to go once they are in the rubbers. Here is a shitty paint diagram.
https://cdn.bikechatforums.com/files/restrcictor_kit.png
0l0dom0l0
PostPosted: 22:52 - 09 Mar 2011    Post subject: Reply with quote
Here is a very good walk through.
https://www.banditforum.co.uk/forum/index.php?topic=22344.0
claaazy fazer
PostPosted: 09:30 - 10 Mar 2011    Post subject: Reply with quote
0l0dom0l0 wrote:
Thanks a bunch matey!!
claaazy fazer
PostPosted: 12:21 - 10 Mar 2011    Post subject: Reply with quote
Do you know if installing these washers is bad for the engine, i've heard it gets the exhaust really hot and does more harm than good.
PostPosted: 13:10 - 10 Mar 2011    Post subject: Reply with quote
It really depends on the engine and the carbs.
The washers aren't doing anything magic, they're just restricting how much mixture can be sucked through the carb. In theory it shouldn't mess up the fuel mixture and make it run lean. You'll just reach a point where the flow of mixture can't keep up with the volume needed to keep filling the cylinder.
In practice though, you may find it's messing with the mixture and you'll have to put bigger jets in the carbs. Some restrictor kits come with different jets or even modified carb slides. If you've just slapped washers in, then keep an eye on the spark plug colour and modify the jets as required.
The thing is, you should be doing this anyway, even with a stock bike, as running lean will overheat your engine and cause Badness.
Don't fret about it, diagnose it.
monkeymanjaso...
PostPosted: 15:54 - 10 Mar 2011    Post subject: Reply with quote
does the washers thing work on all bike engines..........
serlant
PostPosted: 19:11 - 10 Mar 2011    Post subject: Reply with quote
What they said, no, My Xj600 Runs fine with just the restrictors in it(1990 so relatively old) and a friend with a 2000 SRAD 600 had only washers in his for 2 years and that ran fine when it was restricted, and now runs just as well as new with the restrictors removed, and they were just washers aswell so thats 2/2 1 old 1 newish no problems
04 CBR1000RR, 1995 Husqvarna TE410, 1998 VTR1000(Sold), 1990 XJ600(sold), 1996 KH125(dead and sold)
There is a gap of 1 year, 164 days between these two posts...
N
PostPosted: 09:05 - 21 Aug 2012    Post subject: Reply with quote
Remove fuel tank
Pull back airbox
Pull back carbs
Carbs back on
Hi, I'm having a go at this. How is it possible to pull back the airbox? Is that only possible once the airbox/carbs clamps are removed?
The last post was made 13 years, 175 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.66 - MySQL Queries: 13 - Page Size: 108.67 Kb
