| claaazy fazer |
 claaazy fazer Derestricted Danger
| N cee thirty |
 N cee thirty Banned
| claaazy fazer |
| N cee thirty |
 N cee thirty Banned
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 12:21 - 02 Mar 2011 Post subject: |
Hi.
There are 3 'easy' ways of restricting it.
Washers in the inlet.
Different needles and springs with a restrictor plate to go in the top of the carb
Throttle stop.
Cant remember the dimensions off the top of my head but will have a look later.
Check Ebay regularly, a set will come up! ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Bikes: 2007 Derbi GPR 50, 1998 Yamaha Fazer 600 (written off), 2002 Yamaha Fazer 600, 1994 CBR 600F, 2003 Triumph Daytona 600, Kawasaki ZX6R J1.....Current: 2006 Yamaha FZ6, 1998 Suzuki TL1000R and a Honda VFR 400 NC30. |
| 0l0dom0l0 |
 Posted: 12:35 - 02 Mar 2011 Post subject: |
https://www.bikechatforums.com/viewtopic.php?t=213364&highlight=restrictor+dimensions ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
| claaazy fazer |
| Rogerborg |
 Rogerborg nimbA
 Posted: 14:59 - 02 Mar 2011 Post subject: |
Essentially any engine is restricted by the amount of fuel and air that it can suck in.
So for an IL4, I'd guesstimate 14mm holes, purely on the basis that:
GS500 restrictor = 20mm^2 * 2 = 800mm^2
So 14^2 * 4 = 784mm^2
I'll even sell you a bit of paper that guarantees(*) that you won't see more than 33bhp at the crank. Only £200!
(*) Guarantee is non-binding and for novelty purposes only. ____________________ Biking is 1/20th as dangerous as horse riding.
| N cee thirty |
 N cee thirty Banned
| claaazy fazer |
| 0l0dom0l0 |
| claaazy fazer |
| 0l0dom0l0 |
 Posted: 22:51 - 09 Mar 2011 Post subject: |
Procedure to fit the kit.
Remove fuel tank
Remove 2 side pannels on the bike (the one which has the seat lock in) that are held in by one 4mm alen key.
Undo the screws that clamp the airbox onto the carbs
Pull back airbox
Undo screws that clamp the carbs in the lnlet rubbers
Pull back carbs
put the kit in the inlet rubbers (it will be very tight, this is normal)
Carbs back on
Reverse order the rest.
The washers are held in by the carbs, they have no were to go once they are in the rubbers. Here is a shitty paint diagram.
https://cdn.bikechatforums.com/files/restrcictor_kit.png ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
| 0l0dom0l0 |
 Posted: 22:52 - 09 Mar 2011 Post subject: |
Here is a very good walk through.
https://www.banditforum.co.uk/forum/index.php?topic=22344.0 ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
| claaazy fazer |
 Posted: 09:30 - 10 Mar 2011 Post subject: |
| claaazy fazer |
| Rogerborg |
 Rogerborg nimbA
 Posted: 13:10 - 10 Mar 2011 Post subject: |
It really depends on the engine and the carbs.
The washers aren't doing anything magic, they're just restricting how much mixture can be sucked through the carb. In theory it shouldn't mess up the fuel mixture and make it run lean. You'll just reach a point where the flow of mixture can't keep up with the volume needed to keep filling the cylinder.
In practice though, you may find it's messing with the mixture and you'll have to put bigger jets in the carbs. Some restrictor kits come with different jets or even modified carb slides. If you've just slapped washers in, then keep an eye on the spark plug colour and modify the jets as required.
The thing is, you should be doing this anyway, even with a stock bike, as running lean will overheat your engine and cause Badness.
Don't fret about it, diagnose it. ____________________ Biking is 1/20th as dangerous as horse riding.
| monkeymanjaso... |
 monkeymanjaso... Borekit Bruiser
| serlant |
 serlant Brolly Dolly
There is a gap of 1 year, 164 days between these two posts... |
| N |
 N L Plate Warrior
 Posted: 09:05 - 21 Aug 2012 Post subject: |
| 0l0dom0l0 wrote: | Procedure to fit the kit.
Remove fuel tank
Pull back airbox
Pull back carbs
Carbs back on
https://cdn.bikechatforums.com/files/restrcictor_kit.png |
Hi, I'm having a go at this. How is it possible to pull back the airbox? Is that only possible once the airbox/carbs clamps are removed? |
The last post was made 13 years, 178 days ago. Instead of replying here, would creating a new thread be more useful? |
