KTM EXC520 tidy up
PostPosted: 22:50 - 02 Mar 2011    Post subject: KTM EXC520 tidy up Reply with quote
The bike formally belonging to MattSpratt is now in my garage, As described it definitely needs a tidy up and a bit of work. I thought I would keep track of mods and changes here.
The plans in rough order of when they will be done.
Fit the following parts,
Kickstart,
Rear Tyre,
Side Stand
Sort out the wiring
A good service
Sort the Speedo out
Then once it is running well I plan a supermoto conversion, fresh panels and graphics.
I had a quick blast round the streets it is horrid on tarmac, the engine however feels really good, no nasty noises and really grunty.
Right first things first, getting it started, no kickstart and a dodgy electric start means that Matt and used a couple of wires you could use to bridge the Solenoid. The wires Matt had used where far too thin and had melted, rather than risk it I rewired it myself and put some block connections on either end (Stinkwheel please don't hate me), it works but I don't like it. I will get the electric starter going ASAP.
Pics not great I'm afraid but here they are
You can see the modified starter by the seat.
https://img.photobucket.com/albums/v295/chris-red/IMG_0380.jpg
https://img.photobucket.com/albums/v295/chris-red/IMG_0381.jpg
Cut wires and I'll not sure why.
https://img.photobucket.com/albums/v295/chris-red/IMG_0383.jpg
I like the slogan Laughing
https://img.photobucket.com/albums/v295/chris-red/IMG_0382.jpg
Raf
PostPosted: 23:22 - 02 Mar 2011    Post subject: Reply with quote
Funny how matt always complains about my bikes being bodged..
So he finally sold it? Thought he was keeping it.
CBR1100xx - BMW K1100 - BMW K100 - Triumph Sprint ST 955i - Suzuki GSX-R 600 - Suzuki DR 350 - Yamaha XV 750 - Honda CBR 600 FM - Yamaha XT 600 - Yamaha Rs 200 - Honda NSR 125
reggie
PostPosted: 02:32 - 03 Mar 2011    Post subject: Reply with quote
ditch the gay monster stickers for a start
when the shit hits the fan make sure its facing the other way.
PostPosted: 09:18 - 03 Mar 2011    Post subject: Reply with quote
I thought that went without saying Laughing
MaybeGuy
PostPosted: 11:15 - 03 Mar 2011    Post subject: Reply with quote
this thread makes me sad
make it out to me in your will
clue with the electric start. by the headstock you can see where the insulation has split on the switchgear, and sometimes the button works by moving the bars hard to the left. I assume that's where the broken wire is.
PostPosted: 11:50 - 03 Mar 2011    Post subject: Reply with quote
I did see that, I had a look but the other insulation seem OK, my Spark mate is coming round tonight to hopefully get it sorted. Hopefully it will be sorted tonight, I'll be going to KTM tomorrow to order some bits.
New tyre air filter and fairing bolts ordered as some where missing.
Sorting out that exhaust as well, where did you get it from? Some one cut the baffle tube off (why I don't know) have sourced a replacement tube and will be getting it welded on then the exhaust repacked.
reggie
PostPosted: 01:06 - 04 Mar 2011    Post subject: Reply with quote
ive got a standard endcan ? ive got loads of exc 400/450/525 bits tbh
MaybeGuy
PostPosted: 07:28 - 04 Mar 2011    Post subject: Reply with quote
it's got a stock system, i just also gave him a leovince system with it.
Yeah, fuck knows why that was cut off. I got it off a ktm guy i know.
PostPosted: 18:47 - 04 Mar 2011    Post subject: Reply with quote
I'm after..
Front Brake light switch,
Tank pad bung thing (plugs into the frame and the tanks sits on top of it.)
Dzus fastener for the airbox
Front brake caliper (maybe)
Speedo Sensor
Let me know if you have any of those Thumbs Up
PostPosted: 18:48 - 04 Mar 2011    Post subject: Reply with quote
I'm after..
Speedo Sensor
PostPosted: 19:38 - 04 Mar 2011    Post subject: Reply with quote
I sneezed and this happened
https://a8.sphotos.ak.fbcdn.net/hphotos-ak-ash4/189945_10150111086678476_512803475_6308183_7732250_n.jpg
Trying to tackle a lot of the odd jobs that need doing.
The wiring is shite, countless wires just hacked off for no good reason, I found the starter circuit runs through the indicators for some reason. It was easy enough to find fix and problem with the starter. I also sorted out the horn which had had the wires removed form it and cut off. I really want to go through the loom and tidy it up hopefully I'll get round to that tomorrow.
The front brake calliper has the retaining pin sized, I tried everything apart from heat to try to get it out, it wouldn't budge, I'm keeping an eye out for a cheap second hand one an while considering my options I'm going to let a mate and my dad have a look first.
There is a brand new calliper on ebay, I was thinking of getting if I can get it for the right price, it comes with pads which would be a be bonus, and wouldn't need a rebuild which I would otherwise be doing on the current one and wouldn't need a new retaining pin.
reggie
PostPosted: 02:49 - 05 Mar 2011    Post subject: Reply with quote
Dzus fastener for the airbox, wut ? Question
im gessing the little things just above the rocker cover ?
PostPosted: 11:50 - 05 Mar 2011    Post subject: Reply with quote
Some of the KTMs have these quick release Fateners called DZUS fasteners, it holds the airbox on.
Looks like this
https://img.photobucket.com/albums/v295/chris-red/P1010236.jpg
The bung sit where the frame meeting the sub frame Thumbs Up
MaybeGuy
PostPosted: 11:55 - 05 Mar 2011    Post subject: Reply with quote
quarter turn fasteners is what some people call them. make sure you get the right length though.
PostPosted: 10:47 - 06 Mar 2011    Post subject: Reply with quote
I got brand new caliper on ebay for about £80, expensive yes, but considering it comes with new pads and will not need new seals or a new retaining pin, plus I don't have to faf about getting the pin out. I think it is a good buy.
PostPosted: 19:13 - 10 Mar 2011    Post subject: Reply with quote
Right got a fair bit done today, fitted new kickstart, I have the bruises to show my ham fisted attempts of kicking it, it's easy when you work out the knack. Also fitted a new tyre it handles so much better. It's mostly back together now, I need a rear bulb I also need to find some screws I have miss placed there is a load of them I have put some where safe. Laughing
Only thing it needs now is a good service on the brakes. According to the KTM dealer the only way to buy the seals from KTM is if you buy a whole new calliper at a cost of £200, Fuck That.
After a bit of investigation and help from the KTM forum, I found that the 2003 calliper is the same part number and they list the seals on the fiche for it.
MaybeGuy
PostPosted: 20:51 - 10 Mar 2011    Post subject: Reply with quote
what was wrong with the calliper? iirc, the pads had a fair bit of life left, and it stopped pretty well. Other than the horriffic squeal.
PostPosted: 22:20 - 10 Mar 2011    Post subject: Reply with quote
The front has no life on the pads and the retaining pin is seized in. I managed to get a brand new one on ebay for cheap ish considering I needed new pads and a new pin and I would have replaced the seals so figured might as well. The rear is fine, but if I am going to bleed it through and I can get the seals cheap I might as well do a rebuild on them so the whole lot is totally refreshed.
I still don't think I have ridden it at full throttle yet, I got the back end doing a U turn, that put a massive smile on my face.
I bought a new airbox lid as it was in slightly better condition than mine but more importantly it has the 2 Dsuz fasteners with it, it got it for less than the cost of one fastener.
I am waiting on a friend of a friend who is welding the baffle tube to the end cap for the Leo Vince exhaust.
Hopefully with be getting muddy on saturday All the bike needs is a few nuts and bolts and a bulb.
I'm considering getting one of these.
https://www.trailtechproducts.co.uk/acatalog/Vapor_Stealth.html
Still waiting on...
Trail Tech Side Stand.
Misc nuts and bolts.
Fork seals
Spark plug
Stainless brake pin for the rear calliper.
A quick question about the clutch, It seems to 'kangaroo' sometimes when I'm trying to do slow speed stuff. I put this down to one of 3 things.
1. Problem with my technique, not sure though because clutch control and slow speed work is something I am really good at.
2. Clutch needs, Bleeding/Adjusting.
3. That's just the way it is, being the type of bike it is.
MaybeGuy
PostPosted: 23:41 - 10 Mar 2011    Post subject: Reply with quote
Why did you order a stainless brake pin for the rear? It's got a quick release lever on it which (iirc) is an aftermarket replacement.
The plug was replaced about 2000 miles ago, so there's pretty much no need for that.
Other than that, the bike's fucking easy to step out on. I was getting about 3/4 of a small roundabout by the time I got around to selling it.
I never had any issues with the clutch though, it's probably the technique.
PostPosted: 20:20 - 15 Mar 2011    Post subject: Reply with quote
Right latest update.
I went laning Saturday and Sunday, Saturday was great loads of fun, Sunday not so much.
I got stuck after about 10 minutes and had to push the bike out of this which wrecked me.
https://a1.sphotos.ak.fbcdn.net/hphotos-ak-snc6/189512_10150118066868476_512803475_6368637_368534_n.jpg
More or less all the bits have arrived now,
[img]https://img.photobucket.com/albums/v295/chris-red/P1010242.jpg
Including,
Brand new calliper from Oz
https://img.photobucket.com/albums/v295/chris-red/P1010243.jpg
https://img.photobucket.com/albums/v295/chris-red/P1010245.jpg
The front is seized to shit this came up for a steal so rather than bugger about trying to drill the old one, I bought this.
Also received my Trail Tech stand.
https://img.photobucket.com/albums/v295/chris-red/P1010247.jpg
It was slightly more expensive than the KTM one but the guy at KTM said the factory ones were not that good. It fits well, and looks very well made but is a bit pricey at £90.
The bike has also now been de-monstered
https://img.photobucket.com/albums/v295/chris-red/P1010246.jpg
Anyone know what this is?
https://img.photobucket.com/albums/v295/chris-red/P1010248.jpg
It seems to be some kind of sensor (temp?) it was tucked behind the engine on top of the oil filters.
There was a bung missing from the Leo Vince exhaust I got with it, in response to a thread I made a very kind BCFer made me some at work(in a very cool job may I add), made me some using a weird and wonderful machine. I believe they wish to remain anon so I will honour that.
This is the process they used...
https://www.bbc.co.uk/blogs/daveharvey/2011/03/new_from_airbus_a_bike_to_tran.html
and here is the finished result.
https://img.photobucket.com/albums/v295/chris-red/P1010252.jpg
The rougher looking ones are the ones made for me they are rougher to the touch and slightly softer but for all intents and purposes the same. Now I am just waiting for the end cap to come back from a friend of a friend who is welding it to the baffle tube I bought.
The clutch 'Problem' does appear to be my technique the more I use it the less it happens.
Part of me really wanted to strip it to the frame and get it all powder coated but my head tells me this would be pointless as it will be getting battered. The only thing I am doing to 'tidy' it is replace rusty bolts as I go.
It is going in for a service this weekend, then after that the next updates will be attempting to fit Cagiva Mito wheels for it and sticky Road tyres.
Almost forgot, this should be coming in the next few days.
https://www.trailtechproducts.co.uk/acatalog/7500-R2250.jpg
I broke the front speedo sensor when I was stripping it down, a cost of a replacement is £30+ Evil or Very Mad .
On the KTM forum they said this is essentially the same part for £4.
https://uk.farnell.com/hamlin/59070-2-t-02-a/sensor-plastic-barrel-m8-no-hv/dp/5540860.
Great I thought, oh shit, Minimum order £20, I contacted them and asked if they would let me just buy that sensor maybe with a surcharge, they said no but suggested I buy things like batteries from them to make up the £20.
I ordered some tape, some heat shrink and 3 sensors. I figured I could sell them on ebay and make a profit. Order goes through, then today I get 2 emails one saying the tape and heatshrink had been dispatched, the other saying the sensors would arrive in 3 months. Evil or Very Mad I wrung them up to cancel so I have over priced tape and heat shrink I didn't really want in the first place.
I went to order them Sensor from KTM, but decided I would rather spend £85 and get a decent unit with tacho rather than spend £30+ on just making the shitty speedo work.
PostPosted: 20:28 - 15 Mar 2011    Post subject: Reply with quote
chris-red wrote:
Sidestand switch?
PostPosted: 20:35 - 15 Mar 2011    Post subject: Reply with quote
I don't think so it looks more like a temperature sensor
You can't see in the photo, but the end looks like this.
https://www.reuk.co.uk/shopImages/lm335z-temperature-sensor.jpg
CHR15
Turbo nutter bastard
PostPosted: 20:41 - 15 Mar 2011    Post subject: Reply with quote
thats a transistor...
maybe its a diode?
they can have 3 legs.
does it have a clutch starter switch or side stand switch?
i'd be really interested if you could find out from your mysterious bcf'er what the machine was that made those things.
looks like spark erosion.. but on plastic Thinking
PostPosted: 20:57 - 15 Mar 2011    Post subject: Reply with quote
From one of the PMs
SLS machines, basically laser sintered powdered materials. I can make any 3D shapes in a range of materials but the flexible rubberised material has a melt point of only 80 deg C or thereabouts
More info in the link.
That photo is a stock photo of a heat sensor I will run out and get a better one.
No side stand switch or clutch switch this bike doesn't have indicators or mirrors or an ignition switch, It has no neutral light either, such faggotry as a safety switches where not even considered I believe. Laughing
PostPosted: 21:07 - 15 Mar 2011    Post subject: Reply with quote
Best picture I could get.
https://img.photobucket.com/albums/v295/chris-red/P1010256.jpg
The last post was made 15 years, 251 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 142.61 Kb
