Guy's XR400 Cylinder sizes please?
Bike Chat Forums Index -> The Workshop Goto page 1, 2, 3, 4, 5, 6, 7, 8  Next
Syris D Indomitable
PostPosted: 19:30 - 03 Mar 2011    Post subject: Guy's XR400 Cylinder sizes please? Reply with quote
Sorry I mean't piston sizes
I have it running sweetish now, My last prob turned out to be the mixture screw on the carb not being set right. (Way out)
It ran rough as hell when cold. (My de-restricted exhaust doesn't help either)
I do have low compression though, my bike has been thrashed.
It's nothing serious but when I kick it over I get a metalic crack sound.
Anyway I'm going to go for a new piston kit as the compression is low.
I will be fitting a new piston kit soon and need some advice please.
Do they go up in size by .25mm or by .5mm.
I'm going to go for a barrel rehone if they go up by .25.
If they go up by .5, I guess I will need a re-bore.
Thanks!
Quote Me Happy
PostPosted: 19:33 - 03 Mar 2011    Post subject: Reply with quote
How do you know the compression is low? Have you done a compression test yet?
0l0dom0l0
PostPosted: 19:41 - 03 Mar 2011    Post subject: Reply with quote
One again, you totally jumping the gun.
Just because you have a metalic 'click' when you use the kick-start doesn't automatically mean you have low compression. Its probably the locking mechanism or something working. I suspect its the kickstart cogs and such like. You could take it off and oil all the parts maybe? But then you will probably need a new kick-start, and gearbox.
Your bike has done 3500 miles, you won't need a new piston.
As I last thread you made, do a compression test. If its low, put a teaspoon of oil down the barrel. If the compression increases then the rings are worn, if it doesn't change it means its the valves.
No point in guessing.
Syris D Indomitable
PostPosted: 19:50 - 03 Mar 2011    Post subject: Reply with quote
Ok above will do. My trusted mechanics a bit busy at the mo.
All valves are set correctly, when I kick for TDC on the compression stroke in order to start there is very little commpression.
The kick start passes with ease.
The last owner de-restricted the exhaust and thrashed it to death.
I will get it checked though.
Martay
PostPosted: 19:59 - 03 Mar 2011    Post subject: Reply with quote
Just because it kicks over easily doesnt necessarily mean compressoin is low. Get a compression test done, one how it stands now, and one with a little oil in the cylinder.
A friends honda CG would kick over as though the spark plug was out, but never failed to fire up first time.
Eat well, poo hard Very Happy
Drives: Cavalier 2.0 16v
serlant
PostPosted: 20:24 - 03 Mar 2011    Post subject: Reply with quote
And just to add, next door has a ktm 640, and kicking it over with the plug out once it made quick a clicking noise each time he kicked it over, i'd say its normal? just the ratchet going as the pistons moving?
04 CBR1000RR, 1995 Husqvarna TE410, 1998 VTR1000(Sold), 1990 XJ600(sold), 1996 KH125(dead and sold)
tatters
Exxon Valdez
PostPosted: 20:28 - 03 Mar 2011    Post subject: Reply with quote
Most likey the Auto de-compression opening a exhaust vavle.
0l0dom0l0
PostPosted: 20:31 - 03 Mar 2011    Post subject: Reply with quote
Can you please enlighten me as to what you mean by this? Do you mean de-baffled?
If you do they are TOTALLY different things. De-baffled is where the baffles are removed, to reduce back pressure and when tuned correctly eventually produce more power.
De-restricted is something that is referred to commonly on 2 strokes. Something like my old GPR 50 where there was a separate 'chamber' that collected old exhaust gases and the engine drew them back in to reduce power making it learner legal.
Syris D Indomitable
PostPosted: 22:33 - 03 Mar 2011    Post subject: Reply with quote
your bike has a decompression system to deliberately lower the compression, to make it easier to start.
Only if I pull the lever to actuate it.
And yes above, De-Baffled! It's been De-Baffled!
Syris D Indomitable
PostPosted: 22:35 - 03 Mar 2011    Post subject: Reply with quote
Cheers!
Could be right, it doeasn't appear to affect anything.
It doesn't half make a twang though!
PostPosted: 22:45 - 03 Mar 2011    Post subject: Reply with quote
Put all the tools down and walk away from the bike, you will lose money waste time and probably lower the value of if.
PostPosted: 00:07 - 04 Mar 2011    Post subject: Re: Guy's XR400 Cylinder sizes please? Reply with quote
Thanks!
Nonsense, nonsense, nonsense. I don't think I've ever read such crap being masqueraded as technical knowledge on this forum before. Most people just claim to not know what they are doing, or they at least get it a little bit right.
You seem to have no clue, and then don't listen to anyone's advice regarding you not having a clue. Take the above statement for example. What will happen when you fit an oversized piston to a standard bore that has just had a rehone? Absolutely nothing, because the smegging piston won't fit! If you want to put an oversized piston in it WILL need a rebore, and then a hone. Sometimes if you are just changing the rings, you can give the bore a bit of a hone and it'll be OK. This is ONLY when changing the rings though.
In all honesty, it is very rare for a four stroke to need a rebore. Usually this is only required if a ring has become damaged somehow and has scored the barrel. You WILL NOT be able to determine this without inspecting the barrel.
Here's something to think about which you should have been told at school, but evidently were off sick that day or something. When doing an investigation into something, anything, you need to work from the evidence. You use the evidence to create a hypothesis, and then you test the hypothesis by experimentation. What you absolutely DO NOT do is randomly make up a hypothesis, then try to resolve the problem based upon that hypotheisis with no examination or experimentation. This is where you fail.
Why not look for actual evidence of a problem before going to a whole load of effort and pain which will probably result in a broken bike? If you do the investigation properly then you'll work out what the issue is (if there is one - which I don't believe) and you can fix it.
Its not a hard concept to master. I remember being taught this when I was eleven years old.
Syris D Indomitable
PostPosted: 08:21 - 04 Mar 2011    Post subject: Reply with quote
Ok cheers!, I spoke to Honda And they go up in size by .25
Just wondering if your aware of how much hammer xr400's get?
I Read thread on here a while back, I guy's Cylinder on his XR400 was oval after being thrashes.
It is an off bike.
As for schooling, I would think it would be better to ask the person who asked the original question more questions in order to investigate based on your expertise. This is what all skilled trades men do, and even doctors alike.
A lot of the responses I have had on here have been miss-informed judgemental assumptions, a bit like your above.
I have had some good info too.
So I now know even if I go up by .25mm oversized I will need a rebore.
I got this from XRV too.
Quote Me Happy
PostPosted: 08:25 - 04 Mar 2011    Post subject: Reply with quote
Have you registered on this site before? Esoteric1? The Thinker?
weasley
PostPosted: 09:11 - 04 Mar 2011    Post subject: Reply with quote
You STILL don't get it! You don't seem to grasp the fundamental concept of cause and effect.
You need an oversized piston if you do a rebore, you don't do a rebore to fit an oversized piston.
You do a rebore after you have dismantled the engine and measured the bore for ovality (and discovered that it is worn beyond specification), not because some geezer on a forum had a bike like yours that was rebored.
You have been given some excellent, clear advice on this thread and have consistently ignored or misunderstood it, but keep coming back with new ways in which to demonstrate your fundamental lack of understanding of basic engine mechanics.
I suggest you either start listening and implementing the advice here (like, get a compression test) or resign yourself to ruining a perfectly good bike and losing £££ along the way.
0ddball
PostPosted: 09:56 - 04 Mar 2011    Post subject: Reply with quote
Has it even been established the bike has a genuine problem? Not by you (op) as tbh you don't have the slightest clue and only seem to be happy if it does have a problem.
Usually i'd encourage someone to have a go for themselves but in this case i echo what many others have said. Put the spanners down and take it to someone who knows what they are doing. Don't go in telling them there is this and that wrong with it, you are just guessing and most likely wrong. Let them tell you exactly what, if anything, is wrong with it.
Peoples patience is wearing thin.
ZXR750L
Syris D Indomitable
PostPosted: 10:41 - 04 Mar 2011    Post subject: Reply with quote
Anyway guy's, it still runs like a bag of shit when cold.
I am not going to mess with my new carb to suit the De-baffled exhaust. I am going to see if I can pick up a second hand standard end can.
Anyway what exacerbated the problems I had in the first place was Badly set valve clearances, Molested carb which included damaged pilot jet, damaged screws, choke flap not closing properly and the De-Baffles exhaust which Honda apparently took a long time to engineer. It was also in need of a good service.
Thanks for the help guy's.
All I need now is a replacement end can then I am sorted.
You lot helped eliminate issues i thought i had.
Cheers!
Chow!
Quote Me Happy
PostPosted: 10:54 - 04 Mar 2011    Post subject: Reply with quote
I'd be surprised if the end can makes that much difference. If it runs well when warm then just leave it. Warm it up and ride it instead of going round in circles in your garage chasing a different problem a day.
How long does it run badly for when cold? My XR was hesitant when cold and my XT is but warm up quicky and run fine.
Syris D Indomitable
PostPosted: 10:59 - 04 Mar 2011    Post subject: Reply with quote
It's run really bad for around 5 mins, it keeps coughing (Like an overweight granny's incontinent fart), and cutting out. I have to start it like 5 times and hold on the revs.
My carb is new with standard settings. I have read if you de-baffle or fit an after market exhaust you need to upjet and re-tune the carb on these.??
Syris D Indomitable
PostPosted: 11:00 - 04 Mar 2011    Post subject: Reply with quote
He is the troublesome one in question.
https://www.youtube.com/watch?v=7_7_pZ2aVFA
Quote Me Happy
PostPosted: 11:07 - 04 Mar 2011    Post subject: Reply with quote
That exhaust looks like it has the baffle in.
DrDonnyBrago
PostPosted: 12:12 - 04 Mar 2011    Post subject: Reply with quote
LOL.
FFS mate, get it to a fecking mechanic, any mechanic will do if your one is busy. All you want is a compression test. One test as it is, then one with some oil down the bore. Post the results on here.
Seriously just listen to the advice you are being given, you get good advice, ignore it then somehow figure you need new valves and a new piston!?!?!
Rebuilt multiple engines my ass, I wouldn't trust you to rebuild a rollerskate.
Syris D Indomitable
PostPosted: 13:45 - 04 Mar 2011    Post subject: Reply with quote
Ok will do, cheers.
Going to book it in and ask him if he can fabricate something for me too, that's if I can't pick up the genuine one in the mean time.
It has been De-Baffled Joe, there are spot welds on some tiny tube they fitted coming out from the rear.
PostPosted: 13:58 - 04 Mar 2011    Post subject: Reply with quote
Saying stuff like "It still runs like a bag of shit, so I need a rebore." Is not unlike saying
"I have a pain in my chest so I must need a coronary artery bypass graft!"
devojunior
PostPosted: 13:59 - 04 Mar 2011    Post subject: Reply with quote
ffs people the guy is trying to fix his bike and all you mr know it alls are acting like right cocks.
If nobody has anything helful to say to him which may help him fix his bike, instead of trying to act the cool guys who spend every god dam minute on here why dont you suggest a mechanic who has good rates or someone who could look at his bike for some beer tokens local to him.
oh well good look with your bike pal.
The last post was made 15 years, 84 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 8
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.81 - MySQL Queries: 13 - Page Size: 129.71 Kb
