| Syris D Indomitable |
 Syris D Indomitable Nitrous Nuisance
 ..... Quote Me Happy
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 19:41 - 03 Mar 2011 Post subject: |
One again, you totally jumping the gun.
Just because you have a metalic 'click' when you use the kick-start doesn't automatically mean you have low compression. Its probably the locking mechanism or something working. I suspect its the kickstart cogs and such like. You could take it off and oil all the parts maybe? But then you will probably need a new kick-start, and gearbox.
Your bike has done 3500 miles, you won't need a new piston.
As I last thread you made, do a compression test. If its low, put a teaspoon of oil down the barrel. If the compression increases then the rings are worn, if it doesn't change it means its the valves.
No point in guessing. ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Bikes: 2007 Derbi GPR 50, 1998 Yamaha Fazer 600 (written off), 2002 Yamaha Fazer 600, 1994 CBR 600F, 2003 Triumph Daytona 600, Kawasaki ZX6R J1.....Current: 2006 Yamaha FZ6, 1998 Suzuki TL1000R and a Honda VFR 400 NC30. |
| Martay |
 Martay World Chat Champion
 Posted: 19:59 - 03 Mar 2011 Post subject: |
Just because it kicks over easily doesnt necessarily mean compressoin is low. Get a compression test done, one how it stands now, and one with a little oil in the cylinder.
A friends honda CG would kick over as though the spark plug was out, but never failed to fire up first time. ____________________ Eat well, poo hard
Drives: Cavalier 2.0 16v
Rides: Slightly ratted Honda City Express  |
| serlant |
 serlant Brolly Dolly
| tatters |
 tatters Exxon Valdez
 Posted: 20:28 - 03 Mar 2011 Post subject: |
| serlant wrote: | And just to add, next door has a ktm 640, and kicking it over with the plug out once it made quick a clicking noise each time he kicked it over, i'd say its normal? just the ratchet going as the pistons moving? |
Most likey the Auto de-compression opening a exhaust vavle. ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| 0l0dom0l0 |
 Posted: 20:31 - 03 Mar 2011 Post subject: |
| Val Killmore wrote: | The last owner de-restricted the exhaust and thrashed it to death |
Can you please enlighten me as to what you mean by this? Do you mean de-baffled?
If you do they are TOTALLY different things. De-baffled is where the baffles are removed, to reduce back pressure and when tuned correctly eventually produce more power.
De-restricted is something that is referred to commonly on 2 strokes. Something like my old GPR 50 where there was a separate 'chamber' that collected old exhaust gases and the engine drew them back in to reduce power making it learner legal. ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
| chris-red |
| MarJay |
 MarJay But it's British!
 Posted: 00:07 - 04 Mar 2011 Post subject: Re: Guy's XR400 Cylinder sizes please? |
Do they go up in size by .25mm or by .5mm.
I'm going to go for a barrel rehone if they go up by .25.
If they go up by .5, I guess I will need a re-bore.
Thanks! |
Nonsense, nonsense, nonsense. I don't think I've ever read such crap being masqueraded as technical knowledge on this forum before. Most people just claim to not know what they are doing, or they at least get it a little bit right.
You seem to have no clue, and then don't listen to anyone's advice regarding you not having a clue. Take the above statement for example. What will happen when you fit an oversized piston to a standard bore that has just had a rehone? Absolutely nothing, because the smegging piston won't fit! If you want to put an oversized piston in it WILL need a rebore, and then a hone. Sometimes if you are just changing the rings, you can give the bore a bit of a hone and it'll be OK. This is ONLY when changing the rings though.
In all honesty, it is very rare for a four stroke to need a rebore. Usually this is only required if a ring has become damaged somehow and has scored the barrel. You WILL NOT be able to determine this without inspecting the barrel.
Here's something to think about which you should have been told at school, but evidently were off sick that day or something. When doing an investigation into something, anything, you need to work from the evidence. You use the evidence to create a hypothesis, and then you test the hypothesis by experimentation. What you absolutely DO NOT do is randomly make up a hypothesis, then try to resolve the problem based upon that hypotheisis with no examination or experimentation. This is where you fail.
Why not look for actual evidence of a problem before going to a whole load of effort and pain which will probably result in a broken bike? If you do the investigation properly then you'll work out what the issue is (if there is one - which I don't believe) and you can fix it.
Its not a hard concept to master. I remember being taught this when I was eleven years old. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| weasley |
 weasley World Chat Champion
| 0ddball |
 0ddball World Chat Champion
 Posted: 11:00 - 04 Mar 2011 Post subject: |
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
| MarJay |
| devojunior |
 devojunior Brolly Dolly
The last post was made 15 years, 83 days ago. Instead of replying here, would creating a new thread be more useful? |
