Bought a new TV, how to get XBOX to play HD?
DJH
PostPosted: 23:23 - 07 Mar 2011    Post subject: Bought a new TV, how to get XBOX to play HD? Reply with quote
Just bought a new tv to replace the shite one i have and i want to know do i need to buy a HDMI wire to play XBOX 360 in HD? Or some other wire? Embarassed
Digitalize
PostPosted: 23:26 - 07 Mar 2011    Post subject: Reply with quote
Depends if your 360 has an HDMI port, if it does (Any black colour 360 does, anyone bought in like the last 3(?) years will.
If so, yup all you need is an HDMI cable, don't be a mug and buy an expensive one, they're all essentially the same.
1998 CB600F Hornet
butterob
PostPosted: 23:29 - 07 Mar 2011    Post subject: Reply with quote
if you have the component cable check if their is a small switch on the block that goes into the back of the xbox.... it should say something like HDTV on one side and TV on the other. Switch it to HDTV then check the settings on your dashboard to make sure you are outputting in 1080P!
HDMI works better if you can get one though!
j1 zx6r in green
g2 zx6r trackbike Trackdays done: Mallory park, Brands Hatch Indy, Snetterton 300
Digitalize
PostPosted: 23:34 - 07 Mar 2011    Post subject: Reply with quote
Component will only go to 1080i
1998 CB600F Hornet
butterob
PostPosted: 23:44 - 07 Mar 2011    Post subject: Reply with quote
Are you sure? I thought they brought out a patch for that years ago!
j1 zx6r in green
DJH
PostPosted: 23:48 - 07 Mar 2011    Post subject: Reply with quote
Thank you. Very Happy Karma Thumbs Up
Digitalize
PostPosted: 23:54 - 07 Mar 2011    Post subject: Reply with quote
Hmm might be, I always thought it was a hardware limitation of Component but just had a quick look and seems not, oh well, HDMI is the way to go anyway.
1998 CB600F Hornet
butterob
PostPosted: 23:56 - 07 Mar 2011    Post subject: Reply with quote
Yep HDMI all the way
j1 zx6r in green
gazzeh
PostPosted: 11:31 - 08 Mar 2011    Post subject: Reply with quote
Don't spend over the odds on an HDMI cable either - get a 2m length from amazon. Cheapo one will do, digital signal, so no difference in quality to a more expensive cable!
Scotsman37
PostPosted: 20:08 - 08 Mar 2011    Post subject: Reply with quote
Xbox 360 playback of HD movies is supposedly not as detailed as Playstation 3's Blu-Ray due to the fact that Microsoft reduced the processing load on their system as it couldn't handle it because it created overheating problems before going to manufacture and I guess that is why it's only 1080i rather than 1080p, but unsure if the newer Xbox 360s have resolved this problem or not?
brooky
PostPosted: 21:01 - 08 Mar 2011    Post subject: Reply with quote
Xbox 360's have had 1080p support since 2006 but only been able to display it once the systems started to have HDMI ports fitted (Zephyr).
Suzuki GSX-R 750 K6.
bikertomm
PostPosted: 23:37 - 08 Mar 2011    Post subject: Reply with quote
Yeah I got a £2 HDMI cable from Ebay, works a treat great picture.
My dad got like a £30 odd pound one and we compared them on a bigger tv, could'nt see a difference!
butterob
PostPosted: 00:40 - 09 Mar 2011    Post subject: Reply with quote
Component allows for 1080P aswell...
j1 zx6r in green
sickpup
Old Timer
PostPosted: 01:24 - 09 Mar 2011    Post subject: Reply with quote
Xbox's only have a DVD drive so a bit confused as to how they play HDfilms? If by streaming then the limit is probably the bandwidth.
willis1337
PostPosted: 18:25 - 11 Mar 2011    Post subject: Reply with quote
If your router is nearby then connect your xbox to it. Then you can view all your avi files on your PC (which is connected to the same router), on your TV, through your xbox.
DJH
PostPosted: 19:23 - 11 Mar 2011    Post subject: Reply with quote
TV got stolen at the depot. Laughing Laughing Crying or Very sad
willis1337
PostPosted: 20:07 - 11 Mar 2011    Post subject: Reply with quote
Laughing Laughing oh bad luck, patience patience Cool
Black Knight
PostPosted: 13:16 - 12 Mar 2011    Post subject: Reply with quote
You used to be able to get a HD drive for them. Quite a few folks on AV Forums trade the HD DVDs and use the 360 as the player.
Where does a turn end? 'Where you can do anything with the gas you want to, where you are brave again, where your attention is free from the turn, where you are sure you can do it better next time; that's the end' - Keith Code.
TomCB
PostPosted: 16:50 - 12 Mar 2011    Post subject: Reply with quote
not strictly true, VGA has been out since near enough launch and it can display 1080p.
Faldo: "Classic BCF. A thread about sky diving is NSFW on post #2."
The last post was made 15 years, 182 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.03 - MySQL Queries: 13 - Page Size: 103.03 Kb
