What to look for when buying an R6?
Dr. Quack This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
colin1
Captain Safety
PostPosted: 10:29 - 17 Mar 2011    Post subject: Reply with quote
One thing with the earlier ones, is if they have had abuse from people doing wheelies, second gear can be fuc ked. I learnt this from BCF, and when I test rode an r6 I realised it was fuc ked. If I hadnt been told to check for it, I might have bought it.
What you do, is while in second gear, rev it a bit. If it's fuc ked, it drops out of gear as if you had knocked it into neutral, but you havent touched the gear lever.
The one I tried, would do this at less than half revs with less than half throttle.
PostPosted: 10:52 - 17 Mar 2011    Post subject: Reply with quote
I believe that problem was fixed by 2003.
lihp
PostPosted: 11:23 - 17 Mar 2011    Post subject: Reply with quote
AS with most sports bikes, check steering head bearings from wheelie damage. 2nd gear can be a problem under load, so a test ride is a definate. Check for the typical crash damage, other than that they don't suffer from many problems, my 2002 has 24k on it and is still running sweet.
Rejimbo
PostPosted: 11:56 - 17 Mar 2011    Post subject: Reply with quote
check reg/rec, many burn out the live wire in the block connector and leave you stranded miles away from anywhere with a flat battery . . .
angryjonny
PostPosted: 12:46 - 17 Mar 2011    Post subject: Reply with quote
How do you check that? I used to burn through loads of them on my old VFR and the only way I could tell one had failed was when my bike refused to start.
Paxovasa
PostPosted: 12:47 - 17 Mar 2011    Post subject: Reply with quote
Going of some threads on here, make sure it has Yamaha written on the side of it Thumbs Up
PostPosted: 12:49 - 17 Mar 2011    Post subject: Reply with quote
It was, but the OP is looking at pre 2003 models.
Rejimbo
PostPosted: 13:06 - 17 Mar 2011    Post subject: Reply with quote
Pull off the block connector and check for charred wires/ melted block. If you pull out each pin, one will be black if it has burnt out
angryjonny
PostPosted: 13:12 - 17 Mar 2011    Post subject: Reply with quote
I assume it's pretty easily accessible on an R6 then. On my VFR you had to remove the rear bodywork to get to it. Anyone who came to view my bike and started dismantling it to that degree would get told where to stick the not-quite-enough quanitity of cash they'd brought with them.
Rejimbo
PostPosted: 13:37 - 17 Mar 2011    Post subject: Reply with quote
Haha yeah of course, it was fiddly but you can manage with just your hands. Even a visual check will usually tell you if its gone, the block is white so charred bits are pretty obvious
PostPosted: 14:26 - 17 Mar 2011    Post subject: Reply with quote
My bad I didn't read properly, thought he was after a 2003 model.
cloric_tzr
PostPosted: 20:30 - 17 Mar 2011    Post subject: Reply with quote
Is there anything I should look out for when viewing one?
wheels
i dumped my girlfriend the other day! she wouldnt act out one of my fantasy's. all i wanted her to do was come home from work, catch me fucking her sister and join in!!! miserable bitch!
My wifes so ugly, the only thing that goes down on her
Is the internet connection.
Frost
PostPosted: 20:43 - 17 Mar 2011    Post subject: Reply with quote
Check around the axels for road rash. these bits get damaged in a crash but people usually don't replace them. Check it has the lock stops on the steering (crash & theft), and check that parts like the sump plug aren't drilled to be lockwired as thats a sign it's been a race bike.
timR6
PostPosted: 22:48 - 17 Mar 2011    Post subject: Reply with quote
my instructor's 98 R1 had the mentioned gearbox fault, pretty sure all the carbed R1's have the same 'box so yeah
0l0dom0l0
PostPosted: 00:07 - 18 Mar 2011    Post subject: Reply with quote
Dr. Quack wrote:
Ok thanks for that.
I am interested to know, does the R1 have the same issue with second gear pre 2003?
Thanks!
Yes.
I think it was fixed in 03 but I'm not 100% sure!
Fortuna
PostPosted: 06:11 - 18 Mar 2011    Post subject: Reply with quote
Dr. Quack wrote:
Ok thanks for that.
Thanks!
Unfortunately as I found out, yes.
It's expensive to fix Sad
The last post was made 15 years, 201 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.53 - MySQL Queries: 13 - Page Size: 103.15 Kb
