Honda XR 125
Bike Chat Forums Index -> The Workshop Goto page 1, 2, 3, 4  Next
Aivaras55
PostPosted: 22:53 - 18 Mar 2011    Post subject: Honda XR 125 Reply with quote
Hello, I need some advice about my Honda, because it won't start.
Here is the story:
I bought bike for 900 (2006y.), but I had problems starting it, coz it was cold, however a guy showed me a choked, it helped. I tried it myself but I left it on for too long and he said battery could die if I do that. :/ However This helped to start a bike. So I went on a 20miles trip home, but on a junction it stalled and I wasn't able to turn it on, so I used a choked(turning on and then off after start), started fine on another junction it stalled again and I tried using choke, but it didn't work Sad So yeah I tried few more times and after trying bike was totally dead without any sound when turning ignition. When I press ignition all lights become less visible. Also if I left lights for a minute they become less and less visible, but I tried waiting for an hour and still no sound after hitting ignition, lights glows just fine unless I touch ignition.
I found MOT service on the way and one helpful men tried connecting some voltage or smth(I'm not good at it) sound of engine appeared, but only a sound if he release throttle it turns off.
Is this because I have drained a battery? Seller said that he have changed battery month ago and he had a prove.. Also is it normal for lights to become less visible when turning on ignition?
That's annoying I fear that I made mistake buying this bike :/
I would be really thankful to get some advice.. Smile
Aivaras55
PostPosted: 23:32 - 18 Mar 2011    Post subject: Reply with quote
rob yarrr wrote:
your batterys flat and i'm guessing the idle jet in the carbs blocked Thumbs Up
Thanks for reply!
I think I'll ask to charge my battery in a bike shop.
And how to solve idle jet problem once my battery is charged? Don't know anything about it ;/
PostPosted: 01:13 - 19 Mar 2011    Post subject: Reply with quote
Leave the carb for now it sounds like your new at this and have no idea what you are doing (no offence intended).
First don't take the bike to a shop or take anything a part.
Second, buy a battery charger, try to get one specifically for motorcycles they shouldn't be too dear.
Charge the battery preferably overnight, then try to start it.
Tips for starting it.
Make sure the petrol is on.
Put the choke on.
Leave the throttle alone.
Thumb the starter do not continuously hold it down no more than 5 second bursts.
If it struggles feather the throttle every slow slightly.
Once the bike has started let it run for a little while then turn the choke off, the choke should only be used when the bike is cold.
I think you were not shown these things and have been trying to start it incorrectly and has such have drained the battery. DId you leave the choke on whilst riding it?
Aivaras55
PostPosted: 02:42 - 19 Mar 2011    Post subject: Reply with quote
Yeah I was planning to charge it and see how it goes.
I was looking for a charger and I came by this https://cgi.ebay.co.uk/12V-ATV-CAR-QUAD-VAN-MOTORCYCLE-BATTERY-TRICKLE-CHARGER-/120659196906?pt=UK_Motorcycle_Parts&hash=item1c17d93bea#ht_888wt_905
Is this any good, or I should stay away from it? Because others are quite expensive, I may try to bump start it or ask my instructor to charge a battery Smile
Anyway, thanks for the tips! Sadly I wasn't given any proper instructions..
nsr_J22_FOXEYE
PostPosted: 15:02 - 19 Mar 2011    Post subject: Reply with quote
that will work fine... but why not bump start it and charge from your bike till you can charge it fully?
Never Ride Faster Than Your Angel Can Fly
Aivaras55
PostPosted: 21:05 - 19 Mar 2011    Post subject: Reply with quote
Yeah I tried that today it worked. However not long. I rode like 500meters then came to the red light. so had to stop. When I stopped rear lights in 3 seconds from bright went almost off and engine stalled after that.
So yeah I tried again I stopped on neutral and maintained throttle a little bit N green light was flashing great, but when I released throttle it became less visible and engine stalled. So yeah I kept engine a life for like 2 minutes, but when I release throttle totally on neutral it dies again..
Actually that's why my battery died when I was going home, coz bike kept stalling every junction when I had to stop... Any thoughts? My friend says it has something to do with petrol feed?
Aivaras55
PostPosted: 22:27 - 19 Mar 2011    Post subject: Reply with quote
So yeah moto works fine when you increase rev's a little bit, but it stalls without rev's even when engine is hot.
Maybe it has something to do with adjusting rev bolt?
EDITED: Yep it was rev bolt. We increased revs and bike didn't stall since then! I have left for an hour to charge a little bit. Tomorrow I'm gonna leave it for another hour.
Thanks for all the help. It's great to have such a forum!
PostPosted: 23:54 - 19 Mar 2011    Post subject: Reply with quote
Are you turning the choke off?
If you are it could be that your idle is set too low. There will be a screw on the carb to turn this up. Usually it is a screw that you can turn with your fingers it may have a spring on it.
https://www.teamcalamari.com/pix/24mm/7a.jpg
Look something like this.
what you need to do is start the bike and have it idling and turn the screw slowly one direction. If the idle goes up keep turning it so that it is set to about 2k rpm. Leave it alone and let it warm up. Once it has warmed up turn the choke off then adjust the idle to about 1200rpm-1500rpm.
Where are you based? I'm sure a helpful bcf'er could help out.
Aivaras55
PostPosted: 00:38 - 20 Mar 2011    Post subject: Reply with quote
Yeah by saying rev bolt I meant that screw on the carb. I tried increasing it by one full turn without choke and it worked like a charm, moto no longer stalls.
Anyway, I don't have any rpm indications, but I'm guessing it's around 1000.
At the end everything works now, it still wants to stall if you increase throttle too fast so maybe I should try to increase idle a little bit more?
I'm based in west London Smile Yeah it would be fantastic.
My flat mate knows something about cars, so if not him I would be totally srewed Smile
Livefast123
PostPosted: 11:21 - 20 Mar 2011    Post subject: Reply with quote
1 whole turn is a large amount to have to adjust the idle screw. Was the bike sat up for long before you bought it.
If the bike stalls when you turn the apply throttle fairly quickly then there are a few culprits.
Carb jets partially blocked
Fuel filter clogged
Air filter clogged
Knackered spark plug
Air leak
Sounds to me like you have one of the above problems but you have just adjusted the idle upwards to mask the problem.
Personally I would replace the spark plug and fuel filter then clean the air filter and go from there. It will cost you pennies and at least you can eliminate that before you have to learn how to clean a carb!
Current ride - Yamaha MT-07
Aivaras55
PostPosted: 14:49 - 20 Mar 2011    Post subject: Reply with quote
Thanks for input!
Spark plug was recently change.
I looked for fuel filter, but I couldn't find for xr 125. Or this one would do a trick? https://www.chinesemotorcyclepartsonline.co.uk/part_FFT2_CBX750.php ?
About air filter. The problem is I can't open seat :/ I tried with key, I can turn lock half way, but without any click sound..
Livefast123
PostPosted: 17:45 - 20 Mar 2011    Post subject: Reply with quote
Change the plug again, they are only cheap and even a new one can be faulty or go faulty in a short space of time.
An inline fuel filter will be fine but they are cheaper on ebay etc. There may be a mesh filter attached to the top of the fuel tap inside the tank or a mesh strainer where the fuel line goes into the carb but i'm not familier with Honda 4 strokes.
Maybe the last owner couldn't open the seat to clean the filter. Are you sure there's nothing to pull when you turn the key halfway to open the seat. On the NSR you turn the key then pull a bracket down. I'm sure an XR owner could shed some light.
If that doesn't work then you'll have to clean the carb out. Easy even with little knowledge and basic tools. There are loads of video's and guides on the internet.
JonE
PostPosted: 18:36 - 20 Mar 2011    Post subject: Reply with quote
To remove the seat on the XR you need to remove both side panels, then there is another 2 bolts securing the seat.
Jon
el_oso
have you turned the key the other way as well. been a few years since i seen my xr125 but iirc turning the normal way to open a lock releases the helmet holder thing and turning the other way opens the seat.
so turn the ket both ways is what i am saying
Duke 390
Car: Jeep Wrangler 4.0L
Aivaras55
PostPosted: 19:08 - 20 Mar 2011    Post subject: Reply with quote
Jon
Oh that's what I thought! I'll need to buy spanner first offc..
And do you know what fuel filter I should buy? 8mm or 6? I guess 6 right?
Thanks for all info before this topic I have know nothing about motorbikes, now I know something at least Smile
Aivaras55
PostPosted: 21:12 - 24 Mar 2011    Post subject: Reply with quote
Can anyone tell me how to check oil? How much there is? I had a car before and I could check it easily, but I couldn't find any info on motorbike(only how to change).
Thanks.
Aivaras55
PostPosted: 20:44 - 25 Mar 2011    Post subject: Reply with quote
Thanks. Rode with the bike today and it really feels like it's impure. If I didn't apply almost max of throttle on the start it wanted to stall.
Where is that fuel filter? In the petrol tank? :/ And air filter near carburettor? Gonna clean those two. Also I thought about using wynn's Fuel injection system cleaner after dealing with filters. Anyone tried it?
Aivaras55
PostPosted: 15:13 - 26 Mar 2011    Post subject: Reply with quote
I have got a new plug, new fuel filter, still the same.
How about this?
https://classicmotorcycles.about.com/od/serviceandrepair/a/CarburetorProblems.htm
Maybe I have Lean Mixture? Or rich? I tried working with that fuel screw , but I couldn't turn it, tried with various instruments lol How can I adjust it?
Aivaras55
PostPosted: 16:05 - 26 Mar 2011    Post subject: Reply with quote
rob yarrr wrote:
its probs seized in,is it under the carb ?
try running it without the air filter attatched and see if its any different
Yeah it's under the carb. Dunno how to turn it now.
Vincent wrote:
I think that the best thing you could do is to buy yourself a manual - a Haynes one should do the trick. You should only be using the choke to warm the bike up, if you use it too much, you could damage the engine. Same with incorrect carb adjustments.
Don't try and start the bike with the lights on. Without the engine running, the lights will soon flatten the battery. If you've stalled at night in the middle of the road, switch to side lights.
Be patient, you'll get there Wink
I haven't used a choke for a few days now, maybe coz I increased idle screw. I fear that incorrect carb adjustments are right now, coz previous owner didn't know anything about bikes.
About the lights. I don't use lights switch at all. I mean lights are always on automatically and I don't use long lights, coz I never rode at night or in the dark.
Yeah I'm trying to be patient, but I want to use my bike too.. About manual I have found one on the internet for xr400 and CG 125, those should help I guess?
The last post was made 15 years, 217 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 4
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.54 - MySQL Queries: 15 - Page Size: 135.26 Kb
