| Aivaras55 |
 Aivaras55 Borekit Bruiser
 Posted: 22:53 - 18 Mar 2011 Post subject: Honda XR 125 |
Hello, I need some advice about my Honda, because it won't start.
Here is the story:
I bought bike for 900 (2006y.), but I had problems starting it, coz it was cold, however a guy showed me a choked, it helped. I tried it myself but I left it on for too long and he said battery could die if I do that. :/ However This helped to start a bike. So I went on a 20miles trip home, but on a junction it stalled and I wasn't able to turn it on, so I used a choked(turning on and then off after start), started fine on another junction it stalled again and I tried using choke, but it didn't work So yeah I tried few more times and after trying bike was totally dead without any sound when turning ignition. When I press ignition all lights become less visible. Also if I left lights for a minute they become less and less visible, but I tried waiting for an hour and still no sound after hitting ignition, lights glows just fine unless I touch ignition.
I found MOT service on the way and one helpful men tried connecting some voltage or smth(I'm not good at it) sound of engine appeared, but only a sound if he release throttle it turns off.
Is this because I have drained a battery? Seller said that he have changed battery month ago and he had a prove.. Also is it normal for lights to become less visible when turning on ignition?
That's annoying I fear that I made mistake buying this bike :/
I would be really thankful to get some advice..  |
| N cee thirty |
 N cee thirty Banned
 Posted: 22:56 - 18 Mar 2011 Post subject: |
your batterys flat and i'm guessing the idle jet in the carbs blocked  ____________________ '00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30 Mod 2 Passed 09/06/2011
Jewlio Iglesias wrote: I actually did vote BNP once |
| Aivaras55 |
| N cee thirty |
 N cee thirty Banned
 Posted: 23:41 - 18 Mar 2011 Post subject: |
just take the carb apart,20 min job really
take the carb apart,all you have to do is unscrew the throttle at the top,unscrew the cable at the side for the excellerator pump
then undo the 2 nuts that connect it to the rubber manifold,then pull the carb out,undo the float chamber (3 scews) and you'll see the jets.
get a flat head to the jets and unscrew them and blow through them,then get a 10mm ? spanner and undo the bits the the jets go in to,blow through all these and clean them up
then do the stuff in reverse order and your bike shall work...hopefully
https://www.bikechatforums.com/viewtopic.php?p=2770082&highlight=#2770082 same engine as a cg  ____________________ '00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30 Mod 2 Passed 09/06/2011
| chris-red |
| Aivaras55 |
| nsr_J22_FOXEYE |
 nsr_J22_FOXEYE Scooby Slapper
| Aivaras55 |
| Aivaras55 |
| chris-red |
 Posted: 23:54 - 19 Mar 2011 Post subject: |
Are you turning the choke off?
If you are it could be that your idle is set too low. There will be a screw on the carb to turn this up. Usually it is a screw that you can turn with your fingers it may have a spring on it.
https://www.teamcalamari.com/pix/24mm/7a.jpg
Look something like this.
what you need to do is start the bike and have it idling and turn the screw slowly one direction. If the idle goes up keep turning it so that it is set to about 2k rpm. Leave it alone and let it warm up. Once it has warmed up turn the choke off then adjust the idle to about 1200rpm-1500rpm.
Where are you based? I'm sure a helpful bcf'er could help out. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| Aivaras55 |
 Posted: 00:38 - 20 Mar 2011 Post subject: |
Yeah by saying rev bolt I meant that screw on the carb. I tried increasing it by one full turn without choke and it worked like a charm, moto no longer stalls.
Anyway, I don't have any rpm indications, but I'm guessing it's around 1000.
At the end everything works now, it still wants to stall if you increase throttle too fast so maybe I should try to increase idle a little bit more?
I'm based in west London Yeah it would be fantastic.
My flat mate knows something about cars, so if not him I would be totally srewed  |
| Livefast123 |
 Livefast123 Nearly there...
| Aivaras55 |
 Posted: 14:49 - 20 Mar 2011 Post subject: |
Thanks for input!
Spark plug was recently change.
I looked for fuel filter, but I couldn't find for xr 125. Or this one would do a trick? https://www.chinesemotorcyclepartsonline.co.uk/part_FFT2_CBX750.php ?
About air filter. The problem is I can't open seat :/ I tried with key, I can turn lock half way, but without any click sound.. |
| Livefast123 |
| JonE |
 JonE Scooby Slapper
| el_oso |
 el_oso World Chat Champion
| Aivaras55 |
| Aivaras55 |
| N cee thirty |
 N cee thirty Banned
| Aivaras55 |
| N cee thirty |
 N cee thirty Banned
| Aivaras55 |
| N cee thirty |
 N cee thirty Banned
| Vincent |
 Vincent Banned
 Posted: 15:30 - 26 Mar 2011 Post subject: |
I think that the best thing you could do is to buy yourself a manual - a Haynes one should do the trick. You should only be using the choke to warm the bike up, if you use it too much, you could damage the engine. Same with incorrect carb adjustments.
Don't try and start the bike with the lights on. Without the engine running, the lights will soon flatten the battery. If you've stalled at night in the middle of the road, switch to side lights.
Be patient, you'll get there  |
| Aivaras55 |
 Posted: 16:05 - 26 Mar 2011 Post subject: |
| rob yarrr wrote: | its probs seized in,is it under the carb ?
try running it without the air filter attatched and see if its any different |
Yeah it's under the carb. Dunno how to turn it now.
| Vincent wrote: | I think that the best thing you could do is to buy yourself a manual - a Haynes one should do the trick. You should only be using the choke to warm the bike up, if you use it too much, you could damage the engine. Same with incorrect carb adjustments.
I haven't used a choke for a few days now, maybe coz I increased idle screw. I fear that incorrect carb adjustments are right now, coz previous owner didn't know anything about bikes.
About the lights. I don't use lights switch at all. I mean lights are always on automatically and I don't use long lights, coz I never rode at night or in the dark.
Yeah I'm trying to be patient, but I want to use my bike too.. About manual I have found one on the internet for xr400 and CG 125, those should help I guess? |
The last post was made 15 years, 214 days ago. Instead of replying here, would creating a new thread be more useful? |
