decent oil suggestions
pork6156
PostPosted: 09:52 - 19 Mar 2011    Post subject: decent oil suggestions Reply with quote
Gonna be servicing my 97 kwak zzr600 next week, I would like to put some decent oil in, any suggestions to a decent brand, rather than the usual castrol stuff etc? Very Happy
Paxovasa
PostPosted: 10:06 - 19 Mar 2011    Post subject: Reply with quote
I use Silkolene Comp 4 10W 40 Motorcycle Engine Oil, I rate it highly. Not the cheapest though. Thumbs Up
coolhands
PostPosted: 10:09 - 19 Mar 2011    Post subject: Reply with quote
I use guardian semi-synthetic. It's good value and fine quality for an older bike. It's not silly money either. It's made by Rock Oil
PostPosted: 10:47 - 19 Mar 2011    Post subject: Reply with quote
Crip n Dry. Laughing
weasley
PostPosted: 11:24 - 19 Mar 2011    Post subject: Re: decent oil suggestions Reply with quote
Are you suggesting Castrol is not decent, or that you just fancy a change? Oil is not something to try and be fashionable with!
Even if you fancy a change, the Castrol motorcycle site is worth a look.
pork6156
PostPosted: 11:55 - 19 Mar 2011    Post subject: Re: decent oil suggestions Reply with quote
[quote="weasley"]
No i am not suggesting castrol is not decent! And no I am not trying to be fashionable with my oil, infact I did not know people did try to be fashionable with oil.
I normally pay for my servicing, so not 100% sure what make of oil goes in it, I have decided to do it myself this year, so was just looking for suggestions, if castrol turns out to be best then castrol it will be!!
kawashima
PostPosted: 12:27 - 19 Mar 2011    Post subject: Reply with quote
I use Nutec oil but I will use Kawasaki genuine oil next time.
own:2020 Serow 250
bacon
PostPosted: 13:06 - 19 Mar 2011    Post subject: Reply with quote
I normally use the Hein Gericke offer when it runs of £20 for semi synth 10w40 and filter.
But my last change I used some Motul + filter combo from busters for £25
not sure I could stomach £35 just for oil personally. Regular changes will be of more benefit
neatbik
PostPosted: 14:48 - 19 Mar 2011    Post subject: Reply with quote
Motul is pretty good Thumbs Up
Nixon
PostPosted: 14:57 - 19 Mar 2011    Post subject: Reply with quote
Castrol GTX semi synthetic is £3 per litre and £10 for 4 litres at ASDA Thumbs Up
Jim Mc
PostPosted: 16:34 - 19 Mar 2011    Post subject: Reply with quote
Taken from the Castrol website, a lower viscosity oil actually helps acceleration, I wouldn't have thought it'd make that much difference, especially not 2.9s worth.
https://www.castrolmoto.com/en/our_oils/power1_range.php
Helps you accelerate to top speeds up to 3 seconds faster than other oils. *
*Based on tests carried out by Castrol under strict laboratory conditions and verified by an independent statistician. Tests were run on a mutli-cylinder sports bike, simulating a ride accelerating from 0 to 250kph. New Castrol Power 1 was compared against other Castrol products, a market general reference oil and two competitor products. Test results included findings that Power1 Racing 5W-40 accelerated 2.9 seconds faster than a 20W-50 market general reference oil and Power 1 10W-40 accelerated up to 1 second faster than the comparable 10W-40 oils.
P.S. Could always try Repsol if you wan't a designer oil brand. Doesn't seem that expensive @ £30 for 4L 10W40: https://www.saundersextremesports.co.uk/products.php?id=16
imabikr
PostPosted: 17:03 - 19 Mar 2011    Post subject: Reply with quote
try www.opieoils.co.uk always got some good deals on there..
weasley
PostPosted: 20:47 - 19 Mar 2011    Post subject: Reply with quote
It's not just about viscosity but also friction management. At the Ten Kate Fireblade launch, Ronald TK himself stated that the oil they use gives them extra power (he didn't say how much) and this is the cheapest tuning you will ever do.
Robby
Dirty Old Man
PostPosted: 21:04 - 19 Mar 2011    Post subject: Reply with quote
There is no bad brand of oil. If you want to spend more and get the best oil, then get a fully synthetic oil in the correct grade, which is probably 10W40. Recommended oil for it will be semi-synthetic, which is more than suitable to last the recommended oil change interval.
PostPosted: 21:12 - 19 Mar 2011    Post subject: Reply with quote
I think it's Wilkinson's that do 4 or 5 litres of semi for £10.
Will probably get some for my ER if ASDA don't have any cheap Castrol in.
evoboy
PostPosted: 01:54 - 20 Mar 2011    Post subject: Reply with quote
Castrol GTX.
Or whatever i can get cheap next when that supply runs out.
APT Motorcycles
The last post was made 15 years, 175 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 89.29 Kb
