Chain tensioners
-Savage-
PostPosted: 12:47 - 20 Mar 2011    Post subject: Chain tensioners Reply with quote
Ok, so we all know that chain tensioners work in bikes at high revs, for the cam chain, and this means that the chain does not need to be adjusted periodically, as the tensioner takes up the slack and solves that problem.
So..... why can we not use some sort of tensioner for the drive chain to the rear wheel?
Something like the tensioner you find on a bicycle, a cog on a sprung arm, which takes up the slack on the drive chain.
Surely this has been thought about before, but not adopted as a viable method. So why not?
https://www.diaryofamountainbiker.co.uk/oct05/singlespeed_chainset.jpg
Raffles
PostPosted: 13:39 - 20 Mar 2011    Post subject: Reply with quote
Such things are commonplace on trials bikes where there is constant volatile movement of the swinging arm. I'm sure that the clever people who design road bikes will have addressed the issue and deemed it impractical or uneconomic to install such automatic tensioners.
yen_powell
PostPosted: 13:42 - 20 Mar 2011    Post subject: Reply with quote
I seem to remember I had an old Honda XL185 that had just such a tensioner.
XT1200Z and a DR350 in bits
Jim Mc
PostPosted: 14:02 - 20 Mar 2011    Post subject: Reply with quote
Chain isn't threaded correctly through that rear derailleur. Should be over the top pulley, under the bottom.
But then why there's a derailleur on a fixie in the first place is a mystery.
Nixon
PostPosted: 14:19 - 20 Mar 2011    Post subject: Reply with quote
Without sounding too much like a heathenistical Ludite, what is wrong with the system we have at the min? I mean a couple of seconds with a spanner and you have a chain as perfectly tensioned as you need it.
On a more technical note, friction reduces power, loss of power at the chain makes all the engineers hard work on making power at the engine pointless, its the same reason most factories don't put O or X ring chains on 125s because they sap power.
PostPosted: 14:35 - 20 Mar 2011    Post subject: Reply with quote
For the tensioner Doh!
Slacker24seve...
PostPosted: 15:06 - 20 Mar 2011    Post subject: Reply with quote
Because it doesn't have horizontal dropouts to tension the chain. Which incidentally is the exact same system as on a motorbike Wink
Banger rallies are ace
Fisty
PostPosted: 15:10 - 20 Mar 2011    Post subject: Reply with quote
https://www.renold.com/Products/TransmissionChainSprockets/Roll-Ring.asp
We use these at work, quite clever bits of kit.
Fatter and faster than Fret
PostPosted: 15:14 - 20 Mar 2011    Post subject: Reply with quote
That looks great. Although I wouldnt fancy it in my bike at 70mph along the motorway without some decent mounting point. If that was to come out of the chain at that kind of speed it'll have your leg off and very possibly the few cars it shreds through like a ninja star before it stops. Shocked
PostPosted: 15:21 - 20 Mar 2011    Post subject: Reply with quote
Simple but impressive Thumbs Up
Fisty
PostPosted: 15:24 - 20 Mar 2011    Post subject: Reply with quote
Aint they just? some of the kit we have moves at 9000rpm and I havn`t seen one fail yet. They dont need a mounting point as the chain top and bottom is moving at the same rate so it stays put.
I have often wondered if they would be any good on a bike.
Jim Mc
PostPosted: 15:25 - 20 Mar 2011    Post subject: Reply with quote
Actually it does, bicycle frames have a slotted horizontal dropout, you slacken the axle off, set up the chain tension then force the axle rearward and retighten.
Slacker24seve...
PostPosted: 15:29 - 20 Mar 2011    Post subject: Reply with quote
The one in the picture clearly isn't horizontal. Its a traditional dropout as found on most bikes.
This is what I meant by horizontal dropout:
https://www.roadcyclinguk.com/news/images/bachelor_dropouts_hi.jpg
Because the bike in the picture doesn't have these it has to retain the rear mech to tension the chain Wink
Jim Mc
PostPosted: 15:35 - 20 Mar 2011    Post subject: Reply with quote
https://upload.wikimedia.org/wikipedia/commons/thumb/4/42/Rear_dropout.JPG/220px-Rear_dropout.JPG
It is the traditional type, you wouldn't need more than 10mm on a bike chain, the picture you demonstrated is no doubt better, but it's a cosmopolitan design.[/img]
PostPosted: 16:53 - 20 Mar 2011    Post subject: Reply with quote
https://cdn.bikechatforums.com/files/dsc01406.jpg
McJamweasel
BCF Junkie
PostPosted: 17:31 - 20 Mar 2011    Post subject: Reply with quote
Swingarm will be in the way. Could they cope with the change in tension that you get as the suspension compresses several times a second?
Fisty
PostPosted: 17:50 - 20 Mar 2011    Post subject: Reply with quote
Renold wrote:
Roll-Ring even has
potential for use on
motorcycle chain
Seems possible.....
The last post was made 15 years, 173 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.25 - MySQL Queries: 13 - Page Size: 97.77 Kb
