Humming from transmission
sunnyj58
PostPosted: 15:55 - 22 Mar 2011    Post subject: Humming from transmission Reply with quote
On sunday evening me and my gfs dad decided too open the transmission too take the variator restrictor out.
Well, after alot off hassle, we got in. Managed too find something too hold the teeth on the starter gear still, and undo the nut too find....
The variator washer had already been removed..
So, put it all back together.
But now whenever I use it there is quite a loud hum coming from inside the transmission.
Any ideas what ive done wrong?
Also, dont know it it was this way before but if I take off the breather cap on transmission its incredibly loud.
sunnyj58
PostPosted: 09:50 - 24 Mar 2011    Post subject: Reply with quote
bump
Nope.
PostPosted: 02:15 - 26 Mar 2011    Post subject: Reply with quote
Are you sure the nut is on properly? Your not supposed to just hold the variator and undo it, you either use the PROPER TOOL, or use an impact wrench. Use anything else and it probably wont be tourqued up enough. Check you haven't broken any of the varitor fins or teeth as well.
PostPosted: 09:26 - 26 Mar 2011    Post subject: Reply with quote
Sounds like something is damaged or bent. You need to take it apart again as it probably won't last very long at all.
sunnyj58
PostPosted: 14:00 - 26 Mar 2011    Post subject: Reply with quote
Thanks for replies.
I used a screwdriver too hold the teeth in place, but it didnt bend anything at all.
Im going too take it apart today and make sure its all together right.
Quick question, can I start the engine with the transmission cover off too check if the humming is gone??
Paivi
PostPosted: 14:53 - 26 Mar 2011    Post subject: Reply with quote
We need to know the tune it's humming to correctly diagnose the fault.
Nope.
PostPosted: 22:39 - 26 Mar 2011    Post subject: Reply with quote
sunnyj58 wrote:
Thanks for replies.
Yeah, you can, just stand well back incase the crank nut comes flying off!
The last post was made 15 years, 221 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 52.35 Kb
