Piaggio Zip 50cc 2t
parv1
PostPosted: 01:18 - 26 Mar 2011    Post subject: Piaggio Zip 50cc 2t Reply with quote
I've picked up a Zip 50 recently and just wanted to know if it is normal for the rear wheel to be rotating slowly whilst on the centre stand.
When i first start it up in the morning, the auto choke kicks in and its revving fairly high making the wheel spin fast, but when it slows down or is warm, it does rotate.
Normal or what do i need to do to rectify the matter.
Nope.
PostPosted: 01:58 - 26 Mar 2011    Post subject: Reply with quote
yeah its common for it to move a little bit very slowly. If its actually moving fast enough to move the bike you need to adjust the Idle Screw to change the idling speed.
parv1
PostPosted: 13:17 - 27 Mar 2011    Post subject: Reply with quote
Thanks for that.
I think i might have a quick play with the idle screw and see if i can get it slightly slower.
I have found also sometimes after stopping at a junction that the engine seems to rev excessively. Would it be the same issue with the idle screw?
cb1rocket
PostPosted: 16:35 - 27 Mar 2011    Post subject: Reply with quote
yes it possible. the idle screw should be adjusted when the engine is warmed up obviously after 10 mins of riding then adjusted it properly
bass2k8
PostPosted: 19:15 - 27 Mar 2011    Post subject: Reply with quote
My friend has a Piaggio Zip and his does the exact same to yours. When its on its centre stand on idle the rear wheel slowly moves around. So I think this should be normal Smile But yeah you can adjust your idle speed if you feel the need to.
Peugeot Speedfight 2 100 Prost, 01 Plate, 2000 model.
cb1rocket
PostPosted: 19:26 - 27 Mar 2011    Post subject: Reply with quote
its normal for the rear wheel on any scoot to spin slowly. Just don't set the revs high or the clutch will be burnt out!
bass2k8
PostPosted: 19:28 - 27 Mar 2011    Post subject: Reply with quote
My rear wheel on my speedfight doesn't spin slowly around... so it doesn't happen on all scooters. And it sits on about 1.5/2k revs.
cb1rocket
PostPosted: 19:46 - 27 Mar 2011    Post subject: Reply with quote
1.2k to 1.4k is ideal. 2k is rather high.
bass2k8
PostPosted: 19:49 - 27 Mar 2011    Post subject: Reply with quote
Hmm I will try setting it at 1.2k/1.4k. Does it really make a difference though?
SpannerMonkey
PostPosted: 20:05 - 27 Mar 2011    Post subject: Reply with quote
Also, worn clutch springs will cause this
My bike? A YX140 powered one-off Monkey Bike, something a little different!
matto224
PostPosted: 20:29 - 27 Mar 2011    Post subject: Reply with quote
https://www.youtube.com/watch?v=GVemRGNBnME
mine does this :/ ?
I have only one eye. Do you want me to look at the road or the at the speedometer.
bass2k8
PostPosted: 20:33 - 27 Mar 2011    Post subject: Reply with quote
It seems like your fuel/air mixture is running a bit too rich in fuel, either that or the idle speed screw is giving out too many RPM's on idle. I would firstly adjust the idle speed screw to see if it makes any difference.
matto224
PostPosted: 20:39 - 27 Mar 2011    Post subject: Reply with quote
well im wondering if this is the problem? https://img834.imageshack.us/img834/5013/17057810150093269669787.jpg
theres a hole in the sidecase plastic bit and im wondering if thats causing a air leak maybe?
let me know
bass2k8
PostPosted: 20:41 - 27 Mar 2011    Post subject: Reply with quote
Hmm I don't know what that casing for is exactly, but that could be causing it. Its quite a big hole aint it lol.
matto224
PostPosted: 20:44 - 27 Mar 2011    Post subject: Reply with quote
same im not sure on what it exactly it does lol.. maybe someone could shed some light on this..
and yes it is lol Sad
potato
PostPosted: 22:40 - 27 Mar 2011    Post subject: Reply with quote
Its just a cover, the older models have a tube going into it allowing air flow, to cool inside the casing.
It will run the same without it, but i would recommend getting it replaced, because you don't want any stones or anything falling in there. Very Happy
matto224
PostPosted: 00:54 - 28 Mar 2011    Post subject: Reply with quote
yes i will get a new one lol but them rare to find Sad found a nice carbon effect one for 14.99 though Wink
The last post was made 15 years, 212 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 90.73 Kb
