It just doesn't want to start??!!
bass2k8
PostPosted: 14:47 - 27 Mar 2011    Post subject: It just doesn't want to start??!! Reply with quote
I cleaned my carb on my Peugeot Speedfight 100 Prost, and put it all back together and now it just doesn't want to start. Could anyone please advise me on what I may have done wrong? Thanks. Below are some images I have taken.
Here is a photo of my carb:
https://img546.imageshack.us/img546/1291/0000018w.jpg
Where the throttle needle sits inside the carb:
https://img199.imageshack.us/img199/6849/0000019h.jpg
Inside the carb:
https://img824.imageshack.us/img824/9155/img20110326132215.jpg
Peugeot Speedfight 2 100 Prost, 01 Plate, 2000 model.
bass2k8
PostPosted: 14:55 - 27 Mar 2011    Post subject: Reply with quote
I have no tried kicking it yet, as my kickstart doesn't crank around, I could try taking the transmission case off and manually crank it?
But yeah no matter how many times I use the electric start it just doesn't wanna start.
Just to let you know, once I tried covering my hand over where the air intake goes and it started up but at full revs.
serlant
PostPosted: 15:04 - 27 Mar 2011    Post subject: Reply with quote
Judging by the idle screw i'd say it'd only go in one way or be stuck wide open.
04 CBR1000RR, 1995 Husqvarna TE410, 1998 VTR1000(Sold), 1990 XJ600(sold), 1996 KH125(dead and sold)
bass2k8
PostPosted: 17:13 - 27 Mar 2011    Post subject: Reply with quote
Just an update, I cannot kickstart my moped so i cannt get the fuel into the carb bowl, so what i have done is manually put in some fuel by pouring it into the bowl and then screwing it up. I cannot start it at the moment as my battery has no charge, so its charging at the moment.
I have to be honest, I have no idea how the throttle needle actually went in. The position I have it in at the moment seems right, as its the only position where the throttle grip twists normally, where as before it was just loose.
Can u please tell me why this happens... I covered up the air intake hole with my hand and the ped started up but at full revs, but if i place the air filter and air intake on the carb it doesnt start up at all.
serlant
PostPosted: 18:02 - 27 Mar 2011    Post subject: Reply with quote
Lean as fook, and covering the intake richened it up enough to run, so possibly an air leak somewhere.
bass2k8
PostPosted: 18:06 - 27 Mar 2011    Post subject: Reply with quote
Hmm your probably right.
Where should I check to see if there is an air leak? As I'm quite new to this sort of thing.
If I'm perfectly honest the vaccum tube that connects to the fuel tap seemed a bit loose, so maybe it could be that? But wouldn't I hear like a squeaky noise if it was that??
serlant
PostPosted: 23:04 - 27 Mar 2011    Post subject: Reply with quote
it won't neccesarily make a noise, and unless you've removed the carb rubber from the engine its unlikely to be that, so might be where the carb goes into the rubber also have you screwed the top down on the carb tight?
bass2k8
PostPosted: 23:41 - 27 Mar 2011    Post subject: Reply with quote
As far as I know I have secured everything tightly. I will double check tomorrow morning to see if everything is secured properly.
Tomorrow I'm getting a family friend to look at it who fixes motorbikes, I will see what he says about it.
bass2k8
PostPosted: 13:06 - 28 Mar 2011    Post subject: Reply with quote
OMG!!! YES!!! Smile I got it working finally and its running wayyy better than it originally did... as soon as i pull the throttle i get immediate acceleration! Smile A bit smokey on the pipe of the exhaust, and quite a lot of white smoke, but the guy that helped me fix it said thats expected. Just been on a run and the white smokes gone. WOOP Smile
The last post was made 15 years, 209 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.33 - MySQL Queries: 13 - Page Size: 69.1 Kb
