| dextersaurus |
 dextersaurus World Chat Champion
 Posted: 20:50 - 27 Mar 2011 Post subject: advice on a TT600 |
Righto.
Need to settle my mind on this.
I've only ever ridden a 125cc single, and a 500cc parallel twin, both had carbs, and both had noisy as hell engines, so i got used to that.
But now i'm on an IL4 Fuel injected 600, and I really have no idea how it should sound.
I've been told to expect a slight tapping from under the tank, which is the injectors working.
Though when riding, if i gun it, the tapping gets louder, and quicker with the revs. Would this be the injectors?
running injector cleaner through the car for a week clears up the noise due to dirty injectors, so if i run injector cleaner through the bike, should that clear it up?
It's a 2002, with 24k miles and quite clean, so i doubt the cam chain, or anything else for that matter should be on it's way out. Going to give it an oil change, with the oil and air filters just because i can.
Just want to ease my mind. bike runs fine, starts off the button, pulls smoothly and sounds great, so i'm happy enough with it, just the noise of a bike's IL4 engine i'm not used to
Dunc |
| Dr. Quack |
 Dr. Quack Could Be A Chat Bot
| dextersaurus |
| Dr. Quack |
| dextersaurus |
 Posted: 21:38 - 27 Mar 2011 Post subject: |
Not too bad then. shall have to wait till i get paid though
The EML came on the other day too after i replaced the spark plugs, probably because i was turning the engine over without the tank on, so i'll get them to re-set it while they're at it. |
| MarJay |
 MarJay But it's British!
 Posted: 21:57 - 27 Mar 2011 Post subject: Re: advice on a TT600 |
| Mr Dunkable wrote: | Righto.
Dunc |
You shouldn't be able to hear anything except the revving of the engine. Do you have to strain to hear the tapping noise or is it something that dominates the noise of the bike? If its really loud it could be the cam chain tensioner. These seem to fail on all four cylinder 600's of that era depending on lack of use rather than number of miles. My TT had a fairly loud fuel pump (as did my speed four) but that was a whine rather than a clicking noise.
Bear in mind my first TT dropped a valve and that sounded like someone had dropped a pebble into the engine. If your bike sounds like that, then you need to start worrying. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| dextersaurus |
| McJamweasel |
 McJamweasel BCF Junkie
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 22:32 - 27 Mar 2011 Post subject: |
Probably CCT. If the noise is worse from cold then its defiantly your culprit!
A little trick if it is the CCT. Before you take it out, put the bike in gear and rock it back and forwards a few times. The change in the cam chain tension is meant to free the tensioner. I have never tried it and it is a myth, but if the noise goes away then its fixed it and save you having to take it out !
With regards to valve clearances, you will only need to adjust them if they are out of spec, so measure them first. Its not very difficult just taking all the fairing off that's a pain!
If they are out of spec then you will need to remove the cams. It's not as scary as it sounds though!
Get a Haynes manual and read through the procedure. It was a massive help when I did the Fazer.
Hope that helps. ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Bikes: 2007 Derbi GPR 50, 1998 Yamaha Fazer 600 (written off), 2002 Yamaha Fazer 600, 1994 CBR 600F, 2003 Triumph Daytona 600, Kawasaki ZX6R J1.....Current: 2006 Yamaha FZ6, 1998 Suzuki TL1000R and a Honda VFR 400 NC30. |
| MarJay |
| dextersaurus |
| Dr. Quack |
| P.addy |
 P.addy Red Rocket
 Posted: 23:05 - 27 Mar 2011 Post subject: |
Same ish engine as the daytona.
Was fairly "noisy" in terms of sitting idling, there was definitely alot of clicking going on!
At 12k intervals.. i think are the major services.
The valves are a cow to do.. they were on the Daytona, no doubt the TT resembles the same arse about face approach.  |
The last post was made 15 years, 206 days ago. Instead of replying here, would creating a new thread be more useful? |
