Filling up a two stroke.
AzA
PostPosted: 01:51 - 15 Aug 2004    Post subject: Filling up a two stroke. Reply with quote
When you have a two stroke i know you have to mix the petrol with oil.
so when your at the petrol station do/did you guys buy oil an petrol there and then? or did you buy the petrol put it in a petrol can and do the mixing at home?
Currently riding a 2000 RS125, ( I have a bike at last Very Happy)
https://www.bikepics.com/members/bcfaza/
Ride Safe
bikedudextrm
PostPosted: 02:14 - 15 Aug 2004    Post subject: Reply with quote
On most 2 strokes the oil is stored in a separate tank and goes through an oil pump, the oil pump is usually controlled by the throttle cable so lets the right amount of oil go to the carb where it is mixed with the petrol. This means all you have to do i top up the oil tank now and again.
What you are refereing to is pre-mix where you have to mix the petrol and oil yourself and put it in the petrol tank. On my old scrambler i had to do this and basically i would just take a small amount of oil in a pot with me (measured out) and put it in with petrol when i needed to fill it up.
Pre-mix is a pain in the arse really.
Police Tut Tut
https://www.bikepics.com/members/bikedudextrm/
AzA
PostPosted: 02:20 - 15 Aug 2004    Post subject: Reply with quote
So am right in assuming Supermoto bikes(Scrambler style) Don't have a Seperate oil tank then?
Ride Safe
bikedudextrm
PostPosted: 02:40 - 15 Aug 2004    Post subject: Reply with quote
What bike is it your thinking off, mostly all of them have a separate tank for 2 stroke oil.
Police Tut Tut
AzA
PostPosted: 02:46 - 15 Aug 2004    Post subject: Reply with quote
A Yamaha Dt50sm Or a Gilera Gsm.
I'm liking the Dt50 more but im not sure what year model im after, As i still yet have to gather the funds to aquire it.
Ride Safe
Trunecka
PostPosted: 04:04 - 15 Aug 2004    Post subject: Reply with quote
The DT50sm is a pretty recent bike; are you looking to buy brand new? If so, ask at the bike shop.
Either way, nigh on all new 2strokes have a separate 2T oil tank. In fact I can't name ANY brand new premix 2strokes; if there are any out there they're probably motocrossers.
I'll have a scan of some internet pics to try and identify the dt50's oil tank, should be in the same place as my dtr125's
"I'm gonna get free, Ride into the sun..."
-The Vines
bikedudextrm
PostPosted: 11:45 - 15 Aug 2004    Post subject: Reply with quote
Both those bikes have a separate oil tank.
Police Tut Tut
Frost
PostPosted: 12:11 - 15 Aug 2004    Post subject: Reply with quote
It should have a large white tank towards the front of the bike. its easy access as you fill it up on a regular basis.
ts50x0
PostPosted: 12:27 - 15 Aug 2004    Post subject: Reply with quote
on both of those bikes its under the seat. in fact apart from the newer fizzies where its on the side i cant think of a 2 stroke that has it anywhere but under the seat.(apart from old mito has it under the tank)
mrchips
PostPosted: 14:34 - 15 Aug 2004    Post subject: Reply with quote
The only 2 strokes I've came across where you need to mix is scramblers. All the rest have a seperate bottle and oil pump.
AzA
PostPosted: 14:46 - 15 Aug 2004    Post subject: Reply with quote
So the DT50sm Should have a seperate oil thank then, If it doesn't does anyone know the part oil to part petrol ratio for the DT50sm?
Ride Safe
ts50x0
PostPosted: 19:10 - 15 Aug 2004    Post subject: Reply with quote
no knowone will know as it is definatly a seperate tank and therfore mixed for you.
divuk83
PostPosted: 09:58 - 16 Aug 2004    Post subject: Reply with quote
I took the oil pump out of my bike a while back, its not really to much hassle to use premix. I just carry a little measuring bottle full of oil around under the seat. Pretty much any fairly new road legal bike will have a separate tank so you shouldn't need to use premix.
https://www.scootercenter.com/catalog/images/products/big782.jpg
Dave
The last post was made 22 years, 5 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 76.43 Kb
