clutch bleed nipple question
stevie-p
PostPosted: 13:22 - 30 Mar 2011    Post subject: clutch bleed nipple question Reply with quote
I have a ducati monster and when undoing the clutch bleed nipple managed to shear it off. does anyone know what the fixing is called that the nipple screws into as i need a new one but can't find one anywhere as i don't know the name of it.
Bezzer
PostPosted: 15:01 - 30 Mar 2011    Post subject: Reply with quote
It'll be the clutch slave cylinder. If you think it's knackered it's worth having a go getting it out, soak with Plusgas, bit of heat and try a decent stud remover as you're already got the central hole. Bleed nipples are about the only thing I've managed to get out with the extractors as they usually snap. Plus you could try and drill it going up in .5mm increments until you can just see the thread then pick it out.
jimbothe
PostPosted: 16:49 - 30 Mar 2011    Post subject: Reply with quote
I would go with the above but if not, is this the one?
https://cgi.ebay.co.uk/Ducati-600-750-900-Monster-SS-clutch-slave-line-good-/330524664948?pt=UK_Motorcycle_Parts&hash=item4cf4ce2474
I think the seller is in Kent.
Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle
The last post was made 15 years, 104 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.02 - MySQL Queries: 13 - Page Size: 35.63 Kb
