Upcoming changes to MOD 1 test
Bike Chat Forums Index -> Biking News & Rumours Goto page 1, 2  Next
Asharin
PostPosted: 16:30 - 30 Mar 2011    Post subject: Upcoming changes to MOD 1 test Reply with quote
From here:
https://www.dft.gov.uk/dsa/News.asp?id=SXA13E-A783A660&cat=593
Changes to the module one motorcycle test
The government is working with the motorcycle industry to review the delivery and content of the motorcycle test. This working group includes DSA, DfT, the motorcycle training industry and motorcycle user groups.
This work (along with DSA's ongoing monitoring and review process of all tests) has identified a number of minor changes that can be quickly introduced before the main review is finished.
The following provides you with an outline of the minor changes DSA intends to introduce to module one with effect from 16 May 2011.
Change to the sequence of the manoeuvres (see revised order below)
So that all the slow speed elements will be carried out before the higher speed exercises. This will allow candidates to demonstrate the necessary competence in motorcycle control before moving onto the more demanding manoeuvres.
Controlled stop
This provides an opportunity for candidates to ride the circuit bend of the motorcycle manoeuvring area before coming to a controlled stop. There will not be a minimum speed requirement to this manoeuvre which will allow the candidates the opportunity to familiarise themselves with the layout before moving on to the emergency stop.
Emergency stop manoeuvre
This is to take place before the avoidance exercise. If candidates fail the emergency stop they will not be permitted to carry out the avoidance exercise. This should significantly reduce the likelihood of incident for poorly prepared candidates.
Choosing preferred riding line
Re-position cones on the exit of both left and right hand bends to allow the rider to choose their preferred riding line.
The slow ride
This will now be conducted whilst the candidate rides between the figure of eight and the U-turn manoeuvres. The examiner will observe rather than walk beside the candidate. This will make for a smoother transition from one manoeuvre to another whilst compensating for the extra time required for the candidate to benefit from the additional ride around the circuit bend.
Altering requirements for the controlled stop following the avoidance exercise
The requirements for the controlled stop following the avoidance exercise will be altered. The first pair of blue cones that currently form the stopping box will be removed for this exercise. The examiner will ask the candidate to stop near the remaining two blue cones. This will allow the candidate a greater length to stop in and also allows flexibility in where they stop. Candidates will still be required to stop under control.
Flexibility of speed assessment
For the high speed manoeuvres, DSA intends to introduce a degree of flexibility into the assessment of the speed requirement. There will be a five per cent tolerance of the speed required. (2 km/h below 50 km/h). Providing the candidate commits no faults other than not reaching the speed within this tolerance, the examiner should record this as a riding fault rather than a serious fault. (A riding fault will contribute to the result of the test. A serious fault would result in failure)
Rider faults
The maximum number of rider faults a successful candidate is allowed will remain at five; the number of attempts allowed for the higher speed exercises will also remain unchanged.
Summary
To summarise, these changes are designed to address those aspects the motorcycle industry felt needed to be changed.
The key message is that the exercises will remain the same; it is mainly the order in which they are delivered that will change. This will give candidates more time to settle down and familiarise themselves with the updated layout. This will also give them the opportunity to build up their speed gradually, reducing the risk of candidates riding too fast.
Revised sequence of set exercises for module one of motorcycle test
manual handling
slow control steering (slalom and figure of eight)
slow ride: this will be observed as the candidate rides to the next exercise
U-turn
circuit bend and controlled stop carried out between 30 km/h and 50 km/h (about 20 mph to 30 mph) followed by a controlled stop in the area marked by the four blue cones; speed not measured
cornering and emergency stop; speed measured
cornering, avoidance exercise and controlled stop; speed measured
Reading that I get that they are altering the MOD 1, while the review is ongoing....I wonder if they'll end up just leaving it at that though...until 2013 that is!
blurredman
PostPosted: 17:06 - 30 Mar 2011    Post subject: Reply with quote
That's extremely interesting!
I know alot of people had greif over the 48/49kmph thing
fozzym
PostPosted: 22:17 - 30 Mar 2011    Post subject: Reply with quote
I don't know what all the fuss is about with the mod 1... To be honest its a piece of piss and without sounding harsh for those that have problems with the swerve then god help them on the road when things happen out of the blue.
The problem with any test is that its not real life even when its on the public roads. By that I mean, you don't ride how you would normally on your test.
You learn to pass the test and then develop your skills and own style, granted some are better than others but then that could be said for anything.....some doctors are crap but they passed the same tests as the very best.
PostPosted: 22:48 - 30 Mar 2011    Post subject: Reply with quote
Mod 1 is a piece of cake on a sunny Spring day on an ER-5. But do it in standing water or a howling gale on a shagged out CG125, and that 50kph limit looks a bit more intimidating.
These changes are a bizarre attack of common sense, and I welcome them.
Sham
PostPosted: 07:52 - 31 Mar 2011    Post subject: Reply with quote
What the Double Standards Agency doing something sensible? Surely not!
I like the % speed business, that's a good idea. I think the MOD1 is a good concept, and this 'tweak' is a good enhancement.
UnspeedySam
PostPosted: 12:17 - 31 Mar 2011    Post subject: Reply with quote
They're good changes. Although there's nothing particularly significant other than the 2kph boundary thing the reordering is also nice. I'm a little pissed off because I would have passed first time rather than 4th...only failed on being 2kph too slow before the swerve.
In case anyone is wondering, the second and third times were just stupid mistakes. Second time I had my feet sticking out when going through the speed trap for the swerve, knocking over the measuring device. Third time there was standing water and I had a pretty major rear wheel lock up.
The 50kph thing is some serious speed on a 125...I know it doesn't sound like much but it really is tough especially under stress.
PostPosted: 13:12 - 31 Mar 2011    Post subject: Reply with quote
Yup, they're decent, sensible changes. Shocked
I think there should be even more discretion in the speed test: candidates should be expected to ride to the conditions on the day, not to try to achieve something that they believe is dangerous.
Ah well, they might sort it out when they do the full re-spin later in the year.
Redoko
PostPosted: 13:24 - 31 Mar 2011    Post subject: Reply with quote
Ridiculous test.
Finally they've changed it.
Too little too late IMO.
Would of much prefered it if they got their act together before I had to do it.
Paulington
PostPosted: 18:59 - 31 Mar 2011    Post subject: Reply with quote
I did it first time, the 50kph was no problem at all.
In fact I think on my SC125 I managed to take it at roughly 62kph and I wasn't going full whack.
The problem is people try to corner through the cones and then slam on the power when they straighten up when they should be maintaining 30-35kph through the turn and then throttling it at the apex of the turn to give them speed + set them up in the correct positioning.
However, very few schools teach that from what I've seen which is a shame. Thumbs Down.
fozzym
PostPosted: 20:15 - 31 Mar 2011    Post subject: Reply with quote
I feel sorry for folks that fail the test and i reckon most is due to nerves but if you can't do a maneuver in controlled conditions then god help you on the road. When you do the serve test you know what you have to do and the test only goes ahead if the conditions are deemed safe.
I'd imagine most people that fail would admit they just screwed up due to nerves if they are being honest.
When you think about it, its the mod 2 that has all the uncontrollable elements ie.. other road users and varying road conditions ect.
Get a grip guys and get it done. We can all moan that its too hard and our Dads only had to ride round the block in the 70's but times move on.
I must be a freak but i quite enjoyed the mod 1. Are you guys that fail getting adequate and good quality training??
PostPosted: 21:46 - 31 Mar 2011    Post subject: Reply with quote
What's your evidence for that statement?
Go on, surprise me.
fozzym
PostPosted: 21:49 - 31 Mar 2011    Post subject: Reply with quote
Go on, surprise me.
Mine got cancelled because it was too foggy.
Hyaon
PostPosted: 22:39 - 31 Mar 2011    Post subject: Reply with quote
Frightening....lots of common sense there, bet most of it was feedback screamed on a loudhailer by riders and instructors rather than the dsa people coming to their own conclusion Very Happy
bit late indeed, especially for me even though I got it done with no minors.
Mod2 Passed 30/03/2011!
CBF125>GSF650 Bandit K8>B-King 2008+R1 2002
PostPosted: 09:01 - 01 Apr 2011    Post subject: Reply with quote
fozzym wrote:
the test only goes ahead if the conditions are deemed safe. [...] Mine got cancelled because it was too foggy.
And you extrapolated that to all bad conditions at all sites? Neutral I can't see many tests going ahead on that basis. If we're generalising from personal experience, my Mod 1 was on a damp course in moderate winds, and I passed my Mod 2 in the tail end of a blizzard - I had to scrape the snow off of my L plates.
fozzym
PostPosted: 21:18 - 01 Apr 2011    Post subject: Reply with quote
Well obviously I can speak for the test centres however Like I said mine was cancelled and having spoken to my instructor and the guy at the test centre, it seems that its not uncommon for mod 1's to be cancelled due to adverse weather. The examiner has to be happy that the 2 speed sensitive elements can be completed safely under the conditions.
The mod 2 however is a different kettle of fish as you are required to ride in a safe manner taking into account the road conditions.
So in effect the mod 2 can be in any weather because your expected to ride safely whatever.
I just can't imagine that lots of mod 1's are being failed because the weather was such that it made passing impossible.
IMHO mod 1's are failed because folks get nervous and forget to do what they are taught....simples!
Regardless of the changes people will still fail. People fail for knocking a cone over while wheeling the bike to gods sake.
junxs
PostPosted: 20:23 - 02 Apr 2011    Post subject: Reply with quote
By the sounds of things the slow follow part of the test is being abolished.
Makes sense, the figure of eight and u turn is enough to show you have control of the bike. When on the road, if the traffic is slow then can you put your foot on the floor and wait for the traffic flow to speed up so why test this in the first place?
I failed my test because I put my foot on the ground during the slow follow, I swear he was walking as slow as a human can possibly walk. I have a Suzuki 125GZ Marauder, which has a big frame so its harder to control in extremely slow speeds.
Oldie
PostPosted: 20:24 - 02 Apr 2011    Post subject: Reply with quote
The new layouts look a bit strange (see the links at the bottom of the DSA link)
https://www.dft.gov.uk/dsa/News.asp?id=SX118A-A783A660
PostPosted: 23:19 - 02 Apr 2011    Post subject: Reply with quote
It's just different, and simpler. The old layout was "strange" as well. Wink
joncwl
PostPosted: 13:38 - 03 Apr 2011    Post subject: Reply with quote
To be honest, i welcome the changes as i've yet to look at Mod 1, before these changes and from what ive looked at from the comments its a good change, and ill wait to take this test.
currently being a cager cause winter......the bike will be back out during the summer now
last bike, 1990 yamaha tzr125 (2rk model) - still after a fairing kit for it !!!!!
Hyaon
PostPosted: 18:08 - 04 Apr 2011    Post subject: Reply with quote
Is it just me or does the MPTC Diagram look like a sperm about to fly off a ramp into a....you know.
joncwl
PostPosted: 18:12 - 04 Apr 2011    Post subject: Reply with quote
i'll have to agree with you xD
Oldie
PostPosted: 20:06 - 04 Apr 2011    Post subject: Reply with quote
I reckon that the biggest impact will be on those doing the restricted licence route as many people have failed on 125's by not getting up to 50kph. The new tolerances are a real benefit and bring back some reality to the test.
Having said that, I only managed 48 and 50 on the cb500 Embarassed
jrolph94
PostPosted: 23:45 - 02 Jun 2011    Post subject: Reply with quote
I have my mod 1 in a couple of weeks so hopefully the changes should make it slightly easier.
parkmoy
PostPosted: 09:21 - 15 Jun 2011    Post subject: Reply with quote
Has anyone got an updated link for the Mod1 layout and measurements please? The one above is coming up' error 404 not found' and I can't seem to find another link.
The last post was made 15 years, 114 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 138.21 Kb
