Best and quickest way to dry boots
timboellis
PostPosted: 19:43 - 03 Apr 2011    Post subject: Best and quickest way to dry boots Reply with quote
Well just back from a run ended in the sea up top my knees (Long Story) but now got my boots upside down on the radiator in the house, any quicker ways to dry them as need them the morrow.
The only other suggestion I could think of was to slap one on the end of the exhaust ?
Quote Me Happy
PostPosted: 19:44 - 03 Apr 2011    Post subject: Reply with quote
Stuff them full of newspaper and put them somewhere warm.
timboellis
PostPosted: 19:46 - 03 Apr 2011    Post subject: Reply with quote
cheers, pack them tight or loose?
weasley
PostPosted: 19:57 - 03 Apr 2011    Post subject: Reply with quote
Screw up the paper into fairly tight balls and stuff as many in as you can. Do not use direct heat (eg on a radiator), just a warm place (eg airing cupboard). Leave for at least 24 hours.
Charlie
PostPosted: 20:20 - 03 Apr 2011    Post subject: Reply with quote
Could probably replace the newspaper after 8 or so hours if you want speed it up slightly (although I suspect it only speeds it up slightly)
Willson
PostPosted: 20:23 - 03 Apr 2011    Post subject: Reply with quote
this +1.
It's all about playing the waiting game unfortunately.
Benson: Wouldn't life be easier if we were all turtles?
Me: Pig on bread = The way forward.
Riding: '00 Suzuki SV650S. Previous: '99 Kawasaki ER5 - sold, '02 Suzuki GZ125 Marauder - sold
PostPosted: 20:49 - 03 Apr 2011    Post subject: Reply with quote
Hair dryer alternating between cold and warm - not full heat.
PostPosted: 20:53 - 03 Apr 2011    Post subject: Reply with quote
Unless they're 'the bestest boots ever' i'd hairdryer the bastards..Full heat..whilst they're toasting on a hot radiator.
Gerrard
PostPosted: 21:14 - 03 Apr 2011    Post subject: Reply with quote
+ 1.. Thumbs Up
Honda Blackbird the great all rounder.
Chillin near Malaga.
Marco Simoncelli 58
The Tot
PostPosted: 21:47 - 03 Apr 2011    Post subject: Reply with quote
Alll of the above... and them afterwards apply some nikwax leather restorer to take the hardness off them and keep the supple!
Newspaper and under the radiator...
Never argue with autism
Marmalade
PostPosted: 21:55 - 03 Apr 2011    Post subject: Reply with quote
I always stick mine on the top shelf in the airing cupboard, usually dry the next morning.
I keep the door open a tiny bit, I feel this helps move a bit of air around, probably does sod all to help but gives me hope.
Teflon-Mike
tl;dr
PostPosted: 22:01 - 03 Apr 2011    Post subject: Reply with quote
DEFINITELY stuff'em with newspaper or they tend to shrink as they dry.
Forced heat will make them hard and crack, and the faster you dry them worse they'll be (if leather) If they are modernish boots with lots of armour and re enforcement, then be very wary about force drying, as the plastic and metal will not move lile the leather or textile will, as the water comes out, plus heat, can build up in metal and can distort plastic.
Always best to dry at room temperature if you can.
Always re 'proof' them with leather conditioner and then fabsil or nickwax or similar to re water proof.
timboellis
PostPosted: 09:39 - 04 Apr 2011    Post subject: Reply with quote
Well had no newspaper just stuffed them with bog roll and more or less dry now in the airing cupboard
Pernig
PostPosted: 14:50 - 04 Apr 2011    Post subject: Reply with quote
Bear in mind they are going to fucking stink once they are dry. When this happened to my boots I sprayed anti perspirant inside them to try and get rid.
H100 Breaking for spares
timboellis
PostPosted: 16:11 - 04 Apr 2011    Post subject: Reply with quote
They stank before Smile
chillyman0
PostPosted: 17:12 - 04 Apr 2011    Post subject: Reply with quote
stick 'em in a bag in the freezer over night, then take em out and let them normalise then get some old socks and fill them with some cheap loose tea and add a few drops of tea tree oil, tie the ends off and stick them in the boots over night and furthermore leave in the boots whenever your not using them.
Thats to stop the odour not the wetness btw Mr. Green
1996 gsf600n (sold)
The last post was made 15 years, 90 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 91.26 Kb
