I'm an idiot, diesel in bike. What to do?
herulach
PostPosted: 00:22 - 04 Apr 2011    Post subject: I'm an idiot, diesel in bike. What to do? Reply with quote
Update, I'm a fucking idiot and filled it full of diesel. Obviously the carbs and the tank need draining, but can I just do that and fill it back up with no worries?
So, Coming home from work the other night the bike conked out on the motorway sliproad (onto the motorway). Engine won't rev past about 5k, and idle is very weak (5-600 rpm less than normal, and dies very quickly).
Theres some white smoke from the exhaust (not clouds of the stuff, but a lot more than usual). I daren't run the thing so only saw this at the side of the motorway, so can't speak for unusual noises.
Bike is a 99 FZS600, 26k, serviced 3k ago. Bike had been fine all the way up to carlisle (about 120miles) and for about 700 miles earlier this week and last. Clapped out about 1/4 mile from where it had been stood for the day.
My immediate thought was the head gasket, but there wasn't that much smoke, and IIRC that usually billows out the back. It sat pretty much empty of petrol the entire day, could that be a possible cause? (I'd filled up as I set off).
Anyway, anyone hae any guesses as to what it might be? It'll be off for a garage for sorting due to me not being able to get time off to sort it, but I don't want to get taken for a mug.
YBR 125>FZS600
prawny1
PostPosted: 00:31 - 04 Apr 2011    Post subject: Reply with quote
try drainig your float bowls as you could have picked up some water when you filled up.
hellkat wrote:
virus
PostPosted: 14:01 - 04 Apr 2011    Post subject: Reply with quote
Drain the tank and rinse it with fresh petrol, same with the carb, change the fuel filter if there is one fitted then fill with petrol and try and run it, dont rev it too much it its not happy, it should clear out eventually without any engine damage.
Diesel is a heavy oil so the chances of damaging the engine are quite slim, its just going to be very well lubricated so it will smoke like a bugger for a while.
John
own: 81 xs1100g...
PostPosted: 14:11 - 04 Apr 2011    Post subject: Reply with quote
Personally as long as it still runs I would drain the diesel out of the tank and fill with petrol and keep riding it, it would be shit for a while but as the diesel gets weaker it would get better. My dad ran his petrol car on a mix of 50/50 petrol and diesel for a tank full, it drove like crap but he kept topping it up with petrol and and was fine.
Draining the floats bowls is the proper way but If you lack the knowledge/ Can't be arsed, I reckon it will be fine to fill it up with petrol and run it. Not sure why you would need the change the fuel filter mind.
herulach
PostPosted: 14:35 - 04 Apr 2011    Post subject: Reply with quote
Damn right it's brainless. At least it won't fuck it too hard, only ran for about 2 minutes. Float bowls are easy enough to get to without removing carbs.
Assume recommendations for the fuel filter are to remove traces in that? Garage want 4 hours labour to strip carbs down. Seems like overkill.
YBR 125>FZS600
Quote Me Happy
PostPosted: 14:50 - 04 Apr 2011    Post subject: Reply with quote
Drain tank, drain float bowls, fill with petrol and off you go.
virus
PostPosted: 17:57 - 04 Apr 2011    Post subject: Reply with quote
garage are being cunts, drain the tank, drain the float bowls, put petrol in and ride it.
John
own: 81 xs1100g...
0l0dom0l0
PostPosted: 22:51 - 04 Apr 2011    Post subject: Reply with quote
I got a call from a friend the other day saying one of the bikes at his work (papa johns) had been filled with Diesel and could I go and fix it.
Went over with a fresh can of petrol, and an empty one. Sifened off the diesel and filled th tank with petrol. Hit the start button and twisted the throttle a bit then she fired into life. Smoke for the first 5 mins of running but went away after that.
Tbh, just empty all the fuel lines and drain the carbs along with the tank and brim it with unleaded. Any diesel left will be diluted down enough so that it won't cause a problem. Just keep cranking on full choke for a while and she should go.
Its not that much of a big deal. Diesel doesn't burn well in a petrol engine because of the lower compression so it doesn't actually cause any long term damage. Petrol in a Diesel though Shocked. Bye bye engine!
STONEY!
PostPosted: 09:49 - 05 Apr 2011    Post subject: Reply with quote
meh Ive run my old diesel van on a roughly 60/40 deisel petrol mix before cos it was free actually seemed to run better than straight derv, back in the day they used to put petrol in diesel to thin it down in the winter
binge
Emo Kiddy
PostPosted: 10:15 - 05 Apr 2011    Post subject: Reply with quote
drain the tank, drain the float bowls and fill with petrol.
PostPosted: 10:42 - 05 Apr 2011    Post subject: Reply with quote
Only if its a modern common-rail diesel engine with a high pressure pump. The pumps are lubricated by the flow of diesel, and petrol washes diesel away so when petrol is pumped through the diesel pump it can seize.
Ancient old smoker diesels will run on a petrol-diesel mix.
Clanger
Stirrer
PostPosted: 11:23 - 05 Apr 2011    Post subject: Reply with quote
I can understand that you might make the mistake in the car, what with being in automatic pilot/sleepy/fuzzy/whatever...but for anything bike, you really need to be in tip top condition...sharp as nails.
Still, it shouldn't be too costly to put right, and I doubt you'll make the same error, ever again!!! Laughing
(what to do has been said above, drain, rinse in petrol and re-assemble and off you go)
herulach
PostPosted: 12:05 - 05 Apr 2011    Post subject: Reply with quote
I'm usually very paranoid about it, only thing I can put it down to is the layout of the petrol station, asda I fill up 90% of the time has a single petrol, then one pump with petrol/diesel at front. This one had a single diesel.
YBR 125>FZS600
herulach
PostPosted: 18:01 - 06 Apr 2011    Post subject: Reply with quote
Happy to report everything working fine. Smoked like a fucking smoky thing for the first 4-5 miles and throttle response was somewhat laggy (like throttle wait wait wait, wait a bit more weeeeeee), but appears to be spot on now with no smoke at all (about 40 miles later)
YBR 125>FZS600
The last post was made 15 years, 202 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.24 - MySQL Queries: 13 - Page Size: 101.11 Kb
