| herulach |
 herulach World Chat Champion
 Posted: 00:22 - 04 Apr 2011 Post subject: I'm an idiot, diesel in bike. What to do? |
Update, I'm a fucking idiot and filled it full of diesel. Obviously the carbs and the tank need draining, but can I just do that and fill it back up with no worries?
So, Coming home from work the other night the bike conked out on the motorway sliproad (onto the motorway). Engine won't rev past about 5k, and idle is very weak (5-600 rpm less than normal, and dies very quickly).
Theres some white smoke from the exhaust (not clouds of the stuff, but a lot more than usual). I daren't run the thing so only saw this at the side of the motorway, so can't speak for unusual noises.
Bike is a 99 FZS600, 26k, serviced 3k ago. Bike had been fine all the way up to carlisle (about 120miles) and for about 700 miles earlier this week and last. Clapped out about 1/4 mile from where it had been stood for the day.
My immediate thought was the head gasket, but there wasn't that much smoke, and IIRC that usually billows out the back. It sat pretty much empty of petrol the entire day, could that be a possible cause? (I'd filled up as I set off).
Anyway, anyone hae any guesses as to what it might be? It'll be off for a garage for sorting due to me not being able to get time off to sort it, but I don't want to get taken for a mug. ____________________ YBR 125>FZS600
| prawny1 |
 prawny1 World Chat Champion
| N cee thirty |
 N cee thirty Banned
| virus |
 virus World Chat Champion
 Posted: 14:01 - 04 Apr 2011 Post subject: |
Drain the tank and rinse it with fresh petrol, same with the carb, change the fuel filter if there is one fitted then fill with petrol and try and run it, dont rev it too much it its not happy, it should clear out eventually without any engine damage.
Diesel is a heavy oil so the chances of damaging the engine are quite slim, its just going to be very well lubricated so it will smoke like a bugger for a while.
John ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
| chris-red |
| Banned |
 Banned World Chat Champion
 Posted: 14:12 - 04 Apr 2011 Post subject: |
Some peeps are fucking brainless !!! ...
...................................................................................................................................................................... ____________________ BLUEX5 wrote: Good to have you back covdude.
Ariel Badger - I like the moss and the hole ! |
| N cee thirty |
 N cee thirty Banned
| herulach |
 ..... Quote Me Happy
| virus |
 Posted: 17:57 - 04 Apr 2011 Post subject: |
garage are being cunts, drain the tank, drain the float bowls, put petrol in and ride it.
| Banned |
 Posted: 18:23 - 04 Apr 2011 Post subject: |
My fucktard thread shows i put petrol in, then drained it for no reason ... and they had bike for nearly 3 mionths !!! ... pick up coil ... which they nearly replaced the loom because off !! ... brainless comment was a joke in itself considering the said ...  ____________________ BLUEX5 wrote: Good to have you back covdude.
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 22:51 - 04 Apr 2011 Post subject: |
I got a call from a friend the other day saying one of the bikes at his work (papa johns) had been filled with Diesel and could I go and fix it.
Went over with a fresh can of petrol, and an empty one. Sifened off the diesel and filled th tank with petrol. Hit the start button and twisted the throttle a bit then she fired into life. Smoke for the first 5 mins of running but went away after that.
Tbh, just empty all the fuel lines and drain the carbs along with the tank and brim it with unleaded. Any diesel left will be diluted down enough so that it won't cause a problem. Just keep cranking on full choke for a while and she should go.
Its not that much of a big deal. Diesel doesn't burn well in a petrol engine because of the lower compression so it doesn't actually cause any long term damage. Petrol in a Diesel though . Bye bye engine! ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Bikes: 2007 Derbi GPR 50, 1998 Yamaha Fazer 600 (written off), 2002 Yamaha Fazer 600, 1994 CBR 600F, 2003 Triumph Daytona 600, Kawasaki ZX6R J1.....Current: 2006 Yamaha FZ6, 1998 Suzuki TL1000R and a Honda VFR 400 NC30. |
| STONEY! |
 STONEY! Brolly Dolly
| binge |
 binge Emo Kiddy
 Posted: 10:15 - 05 Apr 2011 Post subject: |
drain the tank, drain the float bowls and fill with petrol.
| MarJay |
 MarJay But it's British!
| Clanger |
 Clanger Stirrer
 Posted: 11:23 - 05 Apr 2011 Post subject: |
I can understand that you might make the mistake in the car, what with being in automatic pilot/sleepy/fuzzy/whatever...but for anything bike, you really need to be in tip top condition...sharp as nails.
Still, it shouldn't be too costly to put right, and I doubt you'll make the same error, ever again!!!
(what to do has been said above, drain, rinse in petrol and re-assemble and off you go) ____________________ Be who you are and say what you feel, because those who mind don't matter, and those who matter won't mind - Dr. Seuss |
| herulach |
 Posted: 12:05 - 05 Apr 2011 Post subject: |
| Clanger wrote: | I can understand that you might make the mistake in the car, what with being in automatic pilot/sleepy/fuzzy/whatever...but for anything bike, you really need to be in tip top condition...sharp as nails.
(what to do has been said above, drain, rinse in petrol and re-assemble and off you go) |
I'm usually very paranoid about it, only thing I can put it down to is the layout of the petrol station, asda I fill up 90% of the time has a single petrol, then one pump with petrol/diesel at front. This one had a single diesel. ____________________ YBR 125>FZS600 |
| herulach |
The last post was made 15 years, 202 days ago. Instead of replying here, would creating a new thread be more useful? |
