Dt 125x rebuild when ?
scott dt125 x
PostPosted: 20:53 - 08 Apr 2011    Post subject: Dt 125x rebuild when ? Reply with quote
hi there all bcf members just wondering when roughly my dt125x needs a rebuild its mileage is 12,473
thanks Smile
Teflon-Mike
tl;dr
PostPosted: 21:23 - 08 Apr 2011    Post subject: Re: Dt 125x rebuild when ? Reply with quote
thanks Smile
whole bike, shouldn't really need to be 'rebuilt' unless you crash it, or take it apart!
Engine may benefit from a rebuild from time to time, but on a DT, interval depends more on how sorely its been thrashed, user numptyness forgetting to put two stroke oil in it or something, or clean out the radiator after getting it full of mud.... misguided attempts at de-restriction, or tuning, rather than any strict mileage.
scott dt125 x
PostPosted: 18:38 - 09 Apr 2011    Post subject: Thanks mike Reply with quote
i was just wondering its not been extremly thrashed and its always had good oils thanks for the advice Smile
prawny1
PostPosted: 21:18 - 09 Apr 2011    Post subject: Reply with quote
12k miles could probably do with a set of piston rings and little end bearing, you don't even need to disturb the head gasket on the dt assuming clearance on the newer frames is good you just undo the base nuts and take the top end off complete.
aprilia rs 125 recommend rings at 5000 mile intervals and most motocross say ring every 50hrs if you average 50mph that would be 2500 miles mx bikes mostly use single ringed pistons.
So 12k miles on one set is good going.
hellkat wrote:
scott dt125 x
PostPosted: 06:46 - 10 Apr 2011    Post subject: Hi prawny Reply with quote
thats what i had in mind it was just to save me money in the long run ie a re plating or new piston thanks for the advice Thumbs Up Cool
The last post was made 15 years, 4 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 45.75 Kb
