| the95th |
 the95th Nitrous Nuisance
| blurredman |
 blurredman World Chat Champion
 Posted: 21:15 - 11 Apr 2011 Post subject: |
Got any pictures?  ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 40k, 1989 MZ ETZ251 - 51k. |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 21:41 - 11 Apr 2011 Post subject: |
First thing, get a primary drive gasket, get the primary drive cover off, remove oil strainer, CLEAN like it has never been cleaned before (as it probably never has been!) Refit, reseal casing with new gasket (DONT use 'gloop' any squashed inside the casing will clog that nicely cleaned strainer!) Fill with cheap oil, run it to warm, do some 'light' miles, as in maybe 50, and change it, to flush the engine. Do another 50 miles, and repeat. Then after you have done three changes, check the oil strainer again, and fill with decent oil of preference.
30K, if it hasn't already, probably in need or a rebore.
Check oil consumption, once you have clean stuff in there and flowing.
If it is using it, will need a top end doing. Not as bad as it sounds or as expensive. If it needs it, let me know I'll point you to bits you need, all in its about £80-£100's worth.
Carbs?
You can chase them for an enturnity, but if the engines down on compression and burning oil, you'll never get them set up right.
Starting place though is to check the choke mechanisms, to be sure they are holding open, then do the cables and balence by eye.
Theres a post in work shop, giving full instructions.
Otherwise, normal stuff, bleed brakes, grease pad and float pins, make sure the forks are sealing and have decent oil in them, check and grease rear suspension, and make sure shock is 'good'. Check, grease and adjust head race bearings.
They can be reasonably reliable, but they do need maintenence, and a lot more frequent 'attension' to keep them on form than most commuters, and possibly a lot of two stroke sporties, simply becouse they are a four stroke.
Oil change AT LEAST every 1000miles, strainer every 2000, and do the valve clerances and tappets at the same time.
Do the servicing, keep the oil clean, they can run well and for good miles, but ignore that oil strainer, and stretch oil changes, it wont be happy! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Teflon-Mike |
 Teflon-Mike tl;dr
| the95th |
| the95th |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 22:31 - 11 Apr 2011 Post subject: |
| the95th wrote: | I would be able to run the bike around a bit before i do all the oil changes right? |
Up to you.......
Think book says 10w40.... dont have to be good stuff, or synthetic or anything for the flush, cheap supermarket £5a gallon will do you about three flushes.
And its not taking the whole bike apart, its simply taking the side cover off as part of routine maintenence doing the ONE thing that tha lack of probably killed your CM!
Your call how long you leave it........
Looked at pics.... what plates it on?
Check frame and engine numbers, against log book.
Should all match.
THAT isn't a standard CB125TD-C, manufactured between 1982 and 1984.
Chunks of it look too shiney and in too good a condition, and the tank and side panels, and 'livery', at the very least, are from a late 1988-1992 TD-J model.
TD-J would have not had the horn cover under the headlamp, and a black painted swing arm. Engine would have been gun metal grey, not black, it would have had cast three spoke wheels and tubless tyres, and it would have CV type carburettors.
Could have simply been 'dressed up' with bodywork from a later bike with SIEZED ENGINE due to lack of cleaning that oil strainer (hint hint!)... but could also have been ringed, and could be hiding many maledies under that bodywork and gaiters...... though could have been well fettled. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 23:41 - 11 Apr 2011 Post subject: |
https://i178.photobucket.com/albums/w269/teflons-torque/Little%20Dreams/LD07%20Eng%20Build/104_0278.jpg
Sump plug.... down there, infront of gear lever. Remove, allow to drain.
https://i178.photobucket.com/albums/w269/teflons-torque/Little%20Dreams/LD07%20Eng%20Build/104_0267.jpg
Primary cover 'off'
Oil strainer where I'm pointing with spanner.
https://i178.photobucket.com/albums/w269/teflons-torque/Little%20Dreams/LD07%20Eng%20Build/104_0269.jpg
dirty strainer, about the size of a matchbox, as it will come out
https://i178.photobucket.com/albums/w269/teflons-torque/Little%20Dreams/LD07%20Eng%20Build/104_0270.jpg
CAREFULLY scrape the 'worst' of the crap off it.
https://i178.photobucket.com/albums/w269/teflons-torque/Little%20Dreams/LD07%20Eng%20Build/104_0271.jpg
Clean meticulousely, with washing up liquid and a 'soft' toothbrush!
Refit by reversal of removal!
Make sure sump plugs back in
ADD OIL
and with a bit of luck you wont kill the main bearings like you did on your CM!
Remember THIS one makes 25% more power, and revs an extra 3K up the scale, or more!
It will NOT take the 'abuse' the softer tuned CM motor did, and if you 'killed' that... this ones chances aren't any higher!
Unless you learn from the experience and the poor CM's sacrifice wasn't in vein! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| the95th |
 Posted: 11:15 - 12 Apr 2011 Post subject: |
Hahaha Thanks mike!
i shant kill this one as quickley i Hope..... it was through stupid ignorance that i kept checking my oil on my drive way, which is slightly sloped, so i it looked like it had more oil then it did... and when it did die, i pushed it a bit too far and too hard overtaking at 65ish in 4th gear.... so yeah probably my fault! lol
Im picking it up tonight, so ill take it out for a test ride, get some 1040 oil and clean out that little strainer and clean as much as possible.
Once again thank you a million ____________________ 2004 Rieju Rs2 Matrix 50cc, 1982 Honda CG125, 1986 Honda Cm125, 1982 Honda Cb125..... I kill a lot of 125's |
| FBSF |
 FBSF Nitrous Nuisance
| the95th |
The last post was made 14 years, 362 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 80.73 Kb
