£10 reward to anyone that can fix this laptop prob.
Graprilia
PostPosted: 16:21 - 15 Apr 2011    Post subject: £10 reward to anyone that can fix this laptop prob. Reply with quote
Hi,
Basically my brothers laptop shut off by itself. When we tried to start it back up the screen goes black and nothing happens. When i try to put it in "safe mode" i get the following:-
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS\system32\ntoskrnl.exe
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS\system32\hal.dll
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS\system32\KDCOM.DLL
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS\system32BOOTVID.dll
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS\system32\config\system
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS\system32\system.log
And it just stays on this screen
If any solutions lead to me being able to use his laptop again like before i will send £10 via paypal , to the solution that works
Thanks
All help WOULD be greatfully recieved.
Piaggo liberty 125 SOLD - CBR 125 - SOLD Aprilia RS 125 - SOLD CBR 400 NC29 - SOLD ZX6R currently own https://bikepics.com/members/Graprilia/
MaybeGuy
PostPosted: 16:26 - 15 Apr 2011    Post subject: Reply with quote
did he fall for one of those delete system32 things?
looks like windows files are corrupted or missing. you need a windows disk to reinstall the files.
put the disk in, boot from it, then repair.
shove your tenner though.
Graprilia
PostPosted: 16:28 - 15 Apr 2011    Post subject: Reply with quote
i have a windows XP home edition disk , which i put in the laptop but how do i boot from it? plus will he lose his old files?
Frost
PostPosted: 16:29 - 15 Apr 2011    Post subject: Reply with quote
Looks like the drive has failed in some way.
You can try the repair install as suggested, but if it doesn't work you're going to need a new drive.
A repair install will just fix the operating system and will leave your files intact.
MaybeGuy
PostPosted: 16:30 - 15 Apr 2011    Post subject: Reply with quote
in bios, change the first boot device to the CD drive.
he shouldn't lose his files, just make sure you don't format it, and only either do a fresh install or a repair.
Graprilia
PostPosted: 16:34 - 15 Apr 2011    Post subject: Reply with quote
just tried that , black screen again
MaybeGuy
PostPosted: 16:35 - 15 Apr 2011    Post subject: Reply with quote
it normally says ''press any key to boot from disk...'' at some point.
if not, try making a boot disk floppy (if it has a floppy drive), then typing D:/setup.exe
if not, there'll be an option somewhere. try hammering F8 or F9 (i forget which) during boot up to get some more options.
Graprilia
PostPosted: 16:41 - 15 Apr 2011    Post subject: Reply with quote
ive got the press any key bit , should be rebooting now. if it works i will send£10 as promised mate
Graprilia
PostPosted: 16:55 - 15 Apr 2011    Post subject: Reply with quote
no good i got the folloing message now :-
the file usbstor.sys is corrupted
press any ket to continue
MaybeGuy
PostPosted: 16:56 - 15 Apr 2011    Post subject: Reply with quote
like i said, shove your tenner
Frost
PostPosted: 18:16 - 15 Apr 2011    Post subject: Reply with quote
Might be a corrupt driver. Installed or updated anything recently? Razz
bEN_
PostPosted: 18:58 - 15 Apr 2011    Post subject: Reply with quote
Google it.
paypal £10 to google for their trouble.
2010 Ducati 848 Dark
Lamp Post Enthusiast
dogbot
PostPosted: 19:03 - 15 Apr 2011    Post subject: Reply with quote
Boot from the CD.
Press R for repair console.
Type CHKDSK /R
Press enter.
When it's done, try the repair install again.
If you get back into the machine, backup everything and get a new HDD.
Seb
PostPosted: 23:27 - 16 Apr 2011    Post subject: Reply with quote
www.ubuntu.com
Download that, burn it to a CD, that'll get you a running OS on a CD and will let you attempt to copy files off your internal HDD to a usb drive, run it for a few days from the liveCD and see how it goes. If you want to do a proper test on the HDD, something like active boot disk is a good start, ubuntu probably has something on there too. Just make sure you don't accidentally install it as you'll potentially cause more damage to the OS and files on there.
Hope that helps Thumbs Up
2010 Triumph 1050 Sprint ST
kawakid
PostPosted: 12:51 - 19 Apr 2011    Post subject: Reply with quote
If you are worried about the data.
You should remove the hard drive and stick it in to a desktop pc. That way you can access all the files on it.
Or you can use something like this.
https://cgi.ebay.co.uk/Dual-IDE-SATA-HDD-Hard-Disk-Drive-USB-Dock-Docking-/160554531403?pt=UK_Collectables_HardDriveEnclosures_RL&hash=item2561cbba4b
I've a twin and a 4.
fitzy_bike
PostPosted: 13:07 - 19 Apr 2011    Post subject: Reply with quote
It sounds like the hard drives had it!
If you haven't done anything you know of then the Hard Drive might well have cooked the files itself?
How old is the laptop?
Chriss
PostPosted: 14:39 - 19 Apr 2011    Post subject: Reply with quote
Seb wrote:
www.ubuntu.com
Can I recommend https://www.sysresccd.org/ instead of Ubuntu for fixing problems. Ubuntu is an excellent distribution, but using the right tool for the right job an all.
Smaller download too.
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
Chalky.
PostPosted: 14:55 - 19 Apr 2011    Post subject: Reply with quote
I want the tenner.
The last post was made 15 years, 194 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.16 - MySQL Queries: 13 - Page Size: 100.56 Kb
