Car Problem - Diesel - Lack of power
Chriss
PostPosted: 10:14 - 19 Apr 2011    Post subject: Car Problem - Diesel - Lack of power Reply with quote
Hi all,
I've recently acquired a Mondeo TDDi. Everything's good with it except one major problem, it's down on power. It still drives, except where I would expect the turbo to kick in, there's nothing.
I've been told it could be the turbo, the waste gate or the diesel pump.
Anyone advice me how I could diagnose which of these it's likely to be? I know nothing about the practical side of diesel engines and even less about a turbo.
Thanks
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
UnknownStuntm...
PostPosted: 10:18 - 19 Apr 2011    Post subject: Re: Car Problem - Diesel - Lack of power Reply with quote
Wind the window down when you drive it. Put it in 2nd or 3rd, at low speed and put your foot down. If you can hear a whistling noise about 3k rpm it's a hole in the boost pipe (or most likely a fuggered clamp holding one end on).
Chriss
PostPosted: 10:58 - 19 Apr 2011    Post subject: Reply with quote
I've heard that's a common problem, but I can't hear any strange noises. A big problem I've got is this is my first four cylinder car in four years so it sounds weird to me anyway. Confused
Any idea how I would tell if any of the three parts listed aren't working?
PostPosted: 11:04 - 19 Apr 2011    Post subject: Reply with quote
There are common issues with various vacuum hoses coming loose or the turbo boost pipe becoming disconnected or holed.
I'd have a look under the bonnet and see if you can see any rubber hoses (large or small) which are out of place.
Livefast123
PostPosted: 11:55 - 19 Apr 2011    Post subject: Reply with quote
There are a number of issues with the TDDi's but they are not as bad as the TDCI's.
Leaks from the turbo boost hoses
Wastegate problems
Turbo vanes sticking ( if variable vane turbo fitted)
Mass Air Flow sensor faulty
Exhaust Gas Recirculation valve blocked / Faulty
Try here https://www.fordmondeoownersclub.co.uk/
Current ride - Yamaha MT-07
Gazdaman
I did a trackday!!!
PostPosted: 17:32 - 19 Apr 2011    Post subject: Reply with quote
I've got a TDCI and it just cost me £750 for 4 new injectors.
They use Delphi injectors, which have a life span of about 60k miles. So you could be looking at dodgy injectors.
Does it ever cut to 'limp mode'? i.e the glow plug light flashes and you're down on power.
I'd say a boost hose has probably popped off the turbo, so you've got no boost.
Gaz
Livefast123
PostPosted: 18:34 - 19 Apr 2011    Post subject: Reply with quote
Can you hear the turbo spooling up if you rev it?
I don't think the TDDI's had the dodgy injectors, but do you have lots of black smoke coming out the back?
Chriss
PostPosted: 18:49 - 19 Apr 2011    Post subject: Reply with quote
Ouch!
No, no problems at all, 1k miles covered so far.
Along with many others (I quote you because you're the last to say it) sounds a likely contender.
Not at all.
No smoke at all.
I had a look under the bonnet, but the turbo is hidden right at the back of the engine and a complete git to get to. I took the heat shield off and everything's all the wrong side for ease of access. I had a look around the hoses, but nothing obvious, not that I'm totally sure where everything's supposed to be plugged into, but all seemed well enough.
With the wife unable to ride bikes at the moment we can't afford to be without the car for too long investigating it. Sad
This is a recipe for
Garage mechanic wrote:
*sucks air between teeth* Ohh, it's going to cost you mate...
Gazdaman
I did a trackday!!!
PostPosted: 21:26 - 19 Apr 2011    Post subject: Reply with quote
The turbo should kick in about 2k, but the TDDI's aren't spectacularly quick is it definitely down on power? Have you felt it with more power in the past?
Gaz
ozzy r6
PostPosted: 22:30 - 19 Apr 2011    Post subject: Reply with quote
what reg is the mondeo as i use to work for ford, there are a number of common problems with these vehicles,
split turbo hoses (you would hear it if there was a split hose)
turbo bearings failing (again you wouold hear this )
the common injector problems
fuel pump faults
slave pump faults (this is the pump that sits next to the tank older cars)
yamaha r6 5sl
kal9001
PostPosted: 03:29 - 20 Apr 2011    Post subject: Reply with quote
Im no mechanic, but if hes saying he cant hear the tubo spooling at all its got to be the turbine side not the compressor side. So something to do with the wastegate or the manifold. Could the entire turbo be seized?
Anyone stupid enough to think we will drag a load of wooden horses full of soldiers into our city is certanley stupid enough to drag all of ours into theirs!
Gazdaman
I did a trackday!!!
PostPosted: 09:01 - 20 Apr 2011    Post subject: Reply with quote
Or he doesn't know what he should be listening for? Or it's drowned out by the big clattery diesel unit.
Gaz
Chriss
PostPosted: 09:52 - 20 Apr 2011    Post subject: Reply with quote
No, but it can't cope with the smallest of inclines on a motorway and drops from 70-50 mph, often I'd have to change to 3rd to get it up the motorway hill (I'm referring to the hill going over the Medway from London towards Canterbury, if anyone knows it).
Hi, it's an 02 plate.
My previous two cars were a Discovery TD5 and a Passat V6 TDi, so they both sound very different to this car. Thing is, I know what the turbo should sound like and whilst I can't hear it, doesn't mean it isn't happening. Luckily, my wife is in agreement that she can't hear it either.
Just a thought relating to this, if the turbo isn't spinning up, does that eliminate the diesel pump as the problem?
Chriss
PostPosted: 10:49 - 20 Apr 2011    Post subject: Reply with quote
I'll have a look when the wife gets home tonight! Chris, when you say what sort of injection it runs, do you mean common rail or direct into the cylinder? If so it's direct into the cylinder and not common rail.
Thanks!
Quick question though, can someone explain why the diesel pump gets involved in the turbo separately to the injection?
ozzy r6
PostPosted: 21:27 - 20 Apr 2011    Post subject: Reply with quote
your car will have a wastegate type turbo on it the easy way to tell if your turbo is siezed just remove the pipe that comes from the air box to the turbo you should just be able to get your hand into the turbo and see if it spins, (but sayin that i have never had a turbo on a mondeo sieze up)
they normal snap the shaft and you can check this the same way, the impeller on the turbo should only have a little movement in it so you can check that.
but to me it sounds like you have a split pipe and most likely the hose from the intercooler to the EGR valve
yamaha r6 5sl
ozzy r6
PostPosted: 21:41 - 20 Apr 2011    Post subject: Reply with quote
CHR15 wrote:
if the turbo was seized or had loads of play, it would be putting more oil out of the exhaust than bp.
this is why i'm saying that it is most likely a split hose.
yamaha r6 5sl
Chriss
PostPosted: 21:47 - 14 May 2011    Post subject: Reply with quote
I'm still struggling with this!
Would the turbo create boost when revving in neutral? My current idea is to unplug the intercooler and see if there's pressure coming out there... Is that a silly idea? Thinking
Chriss
PostPosted: 10:27 - 15 May 2011    Post subject: Reply with quote
Bwahahaha. I love that idea, if for nothing else, to look uber chav in my 90hp Mondeo Estate. Laughing
PostPosted: 10:34 - 15 May 2011    Post subject: Reply with quote
I'll pm you if I still have my spare boost gauge.
If you dont get a pm before 3pm, i dont have it, sorry Laughing Thumbs Up
The last post was made 15 years, 129 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 107.29 Kb
