So err... New seals?
m0l0t0v
PostPosted: 11:40 - 22 Apr 2011    Post subject: So err... New seals? Reply with quote
Well I got my chain and sprockets yesterday but didn't get back till near enough midnight so got on with it this morning. And decided while the wheels are off I'll give them a proper good clean as they're cake din about 1cm of shit. They look better but there's lots of flaking/etc.
Main problem is I found one of the seals was slightly.... fucked.
Guessing it wouldn't be a good idea to ride on it for a bit? (1 week max!)
And since I'll be having to change it I might as well change the wheel bearings?
You can see how raised/deformed it is. Neutral
https://a7.sphotos.ak.fbcdn.net/hphotos-ak-snc6/223059_10150154298901615_509016614_7107410_3242374_n.jpg
https://a3.sphotos.ak.fbcdn.net/hphotos-ak-snc6/207205_10150154298991615_509016614_7107412_3946429_n.jpg
https://a5.sphotos.ak.fbcdn.net/hphotos-ak-snc6/217247_10150154299061615_509016614_7107413_5467327_n.jpg
Lovely old gunked up sprocket
https://a4.sphotos.ak.fbcdn.net/hphotos-ak-snc6/215265_10150154298861615_509016614_7107409_8234016_n.jpg
How it stands atm Neutral
https://a3.sphotos.ak.fbcdn.net/hphotos-ak-snc6/205105_10150154298726615_509016614_7107406_6197138_n.jpg
PostPosted: 11:45 - 22 Apr 2011    Post subject: Reply with quote
With proper rubber sealed bearings I wouldn't be too concerned about the outer seal (although that one is a real mess).
m0l0t0v
PostPosted: 11:50 - 22 Apr 2011    Post subject: Reply with quote
Well that's good to know Smile
Still worth getting changed asap though right? And should I get new wheel bearing or wait until I get the wheels powdercoated later?
The Artist
PostPosted: 11:53 - 22 Apr 2011    Post subject: Reply with quote
Yeh, that is just to stop crap getting in to the bearing cavity, not the bearing itself. Replace when you can.
PostPosted: 11:55 - 22 Apr 2011    Post subject: Re: So err... New seals? Reply with quote
Seals are too keep grease in/water out.
A lot more important if you're off-roading, say - but for road riding in summer it's less of an issue, especially, as Keith mentions, if your bearings are pretty sealed as it is.
Probably couldn't hurt to slap a wodge of grease in there.
m0l0t0v
PostPosted: 11:55 - 22 Apr 2011    Post subject: Reply with quote
Dance!
Walloper
PostPosted: 13:16 - 22 Apr 2011    Post subject: Reply with quote
Get that garage tidied up for the next photo shoot.
You should be ashamed. Sad
m0l0t0v
PostPosted: 15:58 - 22 Apr 2011    Post subject: Reply with quote
Never!
There's 4 bikes in there! Laughing
Walloper
PostPosted: 16:00 - 22 Apr 2011    Post subject: Reply with quote
m0l0t0v wrote:
Never!
I just noticed the big hammer on the floor.
Frustration creeping in?????
m0l0t0v
PostPosted: 16:05 - 22 Apr 2011    Post subject: Reply with quote
Nope, jut gently tapping the wheel spindle out (with a bit of wood between hammer and spindle Razz)
Makes it easier Wink
jimbothe
PostPosted: 16:27 - 22 Apr 2011    Post subject: Reply with quote
Loving the pic.
Where's Wally?
I reckon he's here:
https://i22.photobucket.com/albums/b342/jgillard/molotov.jpg
Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle
m0l0t0v
PostPosted: 16:29 - 22 Apr 2011    Post subject: Reply with quote
neil.
PostPosted: 17:31 - 22 Apr 2011    Post subject: Reply with quote
What a co-incidence - I just did my front wheel bearings today. Not sure how you'll be getting the old ones out but if you have one of these slide hammer pullers, it really helps, once you drift one side out a bit first:
https://cdn.overstock.com/images/products/P11568311.jpg
Walloper
PostPosted: 19:34 - 22 Apr 2011    Post subject: Reply with quote
You can always punch the old ones out from the other side.
Use the old one to knock in the new ones.
Bearings REALLY should be pressed into place.
It is very easy to damage them when hammering.
Specially hitting the inner race to knock them in. It is hard material but the balls will indent the track and then they won't last as long.
If you plan it you can phannie a puller together using some M16 studs and nuts with a pile of washers.
Keep tightening until the bearing are home.
It's more hassle but a more reliable repair will result.
Here endeth the lesson.
m0l0t0v
PostPosted: 23:00 - 22 Apr 2011    Post subject: Reply with quote
I'll remember that when I change the bearings then.
Now I find out my battery is dead. Neutral
le sigh
Ichy
PostPosted: 23:09 - 22 Apr 2011    Post subject: Reply with quote
Just me butting in but try simplybearings.co.uk for replacements. I've used them loads of times and they have always been cheaper and delivered next day. Generally seals are marked up with the size or you can search for the microfiche.
m0l0t0v
PostPosted: 23:22 - 22 Apr 2011    Post subject: Reply with quote
Awesome thanks. Thumbs Up
I'll order them on payday Smile
The last post was made 15 years, 193 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 101.69 Kb
