CG 125 - More powerrrrrr?
sandman1976
PostPosted: 19:33 - 25 Apr 2011    Post subject: CG 125 - More powerrrrrr? Reply with quote
Hey all is there a way to get more power from a CG125 engine?
Its a field bike not a road bike btw..
Gearing change? front/rear sprockets? carb mods etc..
Thanks Smile
MaybeGuy
PostPosted: 19:40 - 25 Apr 2011    Post subject: Reply with quote
fit a 150cc kit
SpannerMonkey
PostPosted: 19:43 - 25 Apr 2011    Post subject: Reply with quote
Change the carb, free flow filter... maybe play about with sprockets, but short of spending serious money, this is all you can do
My bike? A YX140 powered one-off Monkey Bike, something a little different!
sandman1976
PostPosted: 21:04 - 25 Apr 2011    Post subject: Reply with quote
Done the freeflow filter, might jiggle about with the carb, is a 150 head worth the increase?
SpannerMonkey
PostPosted: 21:12 - 25 Apr 2011    Post subject: Reply with quote
I wouldnt have thought so. If you're feeling lucky, mill the head for a bit more compression, and make sure your ignition timing is spot on.
Nexus Icon
PostPosted: 22:19 - 25 Apr 2011    Post subject: Reply with quote
Scoot along with your feet?
Seriously though, refreshing and renewing every part will get it as close to its original power as possible and they don't have a whole lot more to offer than that.
Greetings from Shitsville!
Ingah
PostPosted: 22:51 - 25 Apr 2011    Post subject: Reply with quote
https://hondacg125.awardspace.com/improving_performance.htm
Read that.
-- Ingah
prawny1
PostPosted: 22:54 - 25 Apr 2011    Post subject: Reply with quote
No
hellkat wrote:
Ingah
PostPosted: 23:02 - 25 Apr 2011    Post subject: Reply with quote
prawny1 wrote:
No
To expand on this answer:
Pound for smile, nothing you can do to the CG is worthwhile. Upgrade to a bigger bike, the performance is in another world, and if you're sensible won't cost you as much as jazzing up your CG.
-- Ingah
sandman1976
PostPosted: 19:09 - 26 Apr 2011    Post subject: Reply with quote
Ah right well the general feel is you cant do that much.
Ok well its a good field bike as it it as i have converted it to mono shock, put a cone air filter on it and a knobbly back wheel Smile
Its just a bit noisy as i have crafted a stainless up and over trials style exhaust pipe but cant seem to silence it down much so any ideas on that one?
Thanks Smile
prawny1
PostPosted: 19:19 - 26 Apr 2011    Post subject: Reply with quote
Even if you quieten the exhaust down you are going to get alot of intake noise with an open air filter.
Unless you are getting complaints about the noise when you are out riding don't worry about it.
If your after pepping the bike up a bit you can just fit a bigger back sprocket, you are not likely to be tearing round a feild at the 60+mph the original ratio gets you,
shorter gearing for better acceleration is worth it off road especialy when you are attacking mud etc, 125 2t crossers are geared so short they would be lucky to see 60-70mph but can spin the back wheel up pretty easily on most surfaces and climb very steep hills.
sandman1976
PostPosted: 22:19 - 26 Apr 2011    Post subject: Reply with quote
I like this idea!
What rear sprockets off what other bikes will go on the cg fitting?
Thanks Smile
prawny1
PostPosted: 22:38 - 26 Apr 2011    Post subject: Reply with quote
You can get after market sprockets for the cg in a multitude of sizes both larger and smaller than stock, you will need to experiment with the number of teeth and chain length untill you are happy with how the bike feels.
If your math savvy you could look up your gear ratios and calculate your new max speed for each sprocket size from them.
The last post was made 15 years, 75 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.37 Sec - Server Load: 5.14 - MySQL Queries: 13 - Page Size: 80.67 Kb
