Pad change... other troubles now.
woll
PostPosted: 15:19 - 27 Apr 2011    Post subject: Pad change... other troubles now. Reply with quote
I started doing a pad change on my cbr600fv a few weeks ago...
I've been doing the head gasket at the same time, i just stripped the callipers while i was waiting for the new head gasket to arrive. When i took the pads out the pad springs flew out.
I've got the bike ready to start (once i've got the coils connected right & got a charged battery) I just need to put the new pads in and bleed up the callipers.
The problem is I can't work out how the new pad springs go in. I've tried a few different ways but they scrape on the back of the disc.
I've looked in my haynes manual but it isn't very clear how they go in.
Anybody know how they go?
woll
PostPosted: 17:23 - 27 Apr 2011    Post subject: Reply with quote
I have worked it out now Smile
Beelzebob
PostPosted: 17:59 - 27 Apr 2011    Post subject: Reply with quote
Good work Thumbs Up
'09 YBR 125 -> '92 XJ600 S Diversion -> '99 Hornet 600
"Stronger than your average female lifeguard"
jimbothe
PostPosted: 18:00 - 27 Apr 2011    Post subject: Reply with quote
You're welcome Thumbs Up
Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle
Nexus Icon
PostPosted: 18:50 - 27 Apr 2011    Post subject: Reply with quote
I love a happy ending.
Greetings from Shitsville!
woll
PostPosted: 21:15 - 27 Apr 2011    Post subject: Reply with quote
In othernews.... Got it running for the first time since the hg change. Only problem is it's only revving to 1k with choke on (normally goes to 4) it dies when i rev it. And it randomly backfires, any ideas on what it could be?
Chris fears we may not of timed it right or possibly it slipped a tooth at some point.
Could it be possible that it's only running on 2 cylinders? i'm not 100% sure i've connected the coils right Confused
Chalky.
PostPosted: 21:16 - 27 Apr 2011    Post subject: Reply with quote
You can do mine now you fucking expert Laughing
The Artist
PostPosted: 21:17 - 27 Apr 2011    Post subject: Reply with quote
If you have haynes, just work through each possible item with the most likely first.
Chris doesn't have the best record with setting timing *cough* gs *cough*
woll
PostPosted: 21:26 - 27 Apr 2011    Post subject: Reply with quote
Aye i'll be up bright and early tomorrow morning, fault finding. Just wondered if any of them in the know might have an idea of the problem.
woll
PostPosted: 17:57 - 28 Apr 2011    Post subject: Reply with quote
I've took the rocker cover off and it looks like it's correctly timed. Still running like a bag of poo Sad and it was rattling before I took the rocker cover off. Think the valves need doing although that's doesn't explain why it's running rough, any ideas?
prawny1
PostPosted: 20:47 - 28 Apr 2011    Post subject: Reply with quote
tight valve (as in negative clearance) can cause misfires.
How have you got your leads, one coil goes to the middle two the other goes to the outer two.
hellkat wrote:
woll
PostPosted: 23:35 - 28 Apr 2011    Post subject: Reply with quote
Left hand coil feeding 2/3 and right hand coil feeding 1/4 not sure if i've had the two wires going into the coils connected right, but the downpipes are all getting hot so i presume it's firing right.
I am wondering if the inlet valves on 3/4 are tight as i noticed it was blowing fuel out the 3/4 carbs.
alun111
PostPosted: 02:26 - 29 Apr 2011    Post subject: Reply with quote
Have you tried new spark plugs?
Have your carbs been sitting with stale fuel in them? Blocked jets?
woll
PostPosted: 10:12 - 29 Apr 2011    Post subject: Reply with quote
Plugs haven't even seen a mile on the road, i serviced the bike before i did the head gasket. Carbs have been cleaned they're spotless.
jimbothe
PostPosted: 10:29 - 29 Apr 2011    Post subject: Reply with quote
Just a thought. Have you checked the fuel lines and made sure they are routed right. One little pinch from the tank to carbs and it messed my fj up similar to yours. I'm not teaching you to suck eggs but sometimes the simplist little error can lead to bigger problems. Thumbs Up
woll
PostPosted: 10:46 - 29 Apr 2011    Post subject: Reply with quote
I've connected them up the same way as they came off, couldn't see any pinches in the pipe. And that wouldn't explain when fuel was blowing back out of 3/4 carbs.
woll
PostPosted: 11:28 - 29 Apr 2011    Post subject: Reply with quote
I've got the rocker cover off rob, and unless the marks aren't in the right position on the cam gears then it's timed up right.
woll
PostPosted: 11:47 - 29 Apr 2011    Post subject: Reply with quote
Not tried it yet but it's not old fuel really.
jimbothe
PostPosted: 12:25 - 29 Apr 2011    Post subject: Reply with quote
Have you tried dropping the fuel out of the bowls and letting them fill up again? Just in case a minute piece of debris has got in or the bowls haven't levelled off properly.
woll
PostPosted: 12:54 - 29 Apr 2011    Post subject: Reply with quote
Yep i did that before i took the rocker cover off and cleaned the jets out too.
The last post was made 14 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 114.67 Kb
