mito bits
dandit
PostPosted: 19:19 - 17 Aug 2004    Post subject: [WANTED] mito bits Reply with quote
Right I have just got my hands on a 99 mito for a project and I need some spares I need right mirror (glass fell out Confused ) A decent expansion chamber would be nice (it's got arrow can and carbon reed valves) front brake master cylinder and a manual if anyone has got one they don't need leave a msg CHEERS Also does anyone know if the piston is ment to be flat because I have stripped the engine and found a flat top piston Confused I thought they was for high compression and it's only got 1 piston ring
WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE I STILL HAD 3 GEARS TO GO OFFICER. Currently riding a naked cbr 600 and driving a 52 plate 2litre tdci mondeo
Minky_monkey
PostPosted: 11:09 - 18 Aug 2004    Post subject: Reply with quote
You could always try mito mondo.
https://www.mitomondo.co.uk/main.html
dandit
PostPosted: 16:33 - 18 Aug 2004    Post subject: Reply with quote
CHEERS will give them a try Smile
M1ke
Ped Boi
PostPosted: 17:27 - 18 Aug 2004    Post subject: Reply with quote
As standard I believe they have 2 rings like the rs125 so someone has probably fitted an aftermarket piston. The single ring will probably give a very slight increase in performance but not last as long.
Scotty
Scooter Boi
PostPosted: 17:48 - 18 Aug 2004    Post subject: Reply with quote
Think the one uses a flat head one ring piston
the other uses a domed head with 2 rings.
Both are intercahngeable on all models.
Regards
Scott
dandit
PostPosted: 22:19 - 18 Aug 2004    Post subject: Reply with quote
I think I get it I dont know bugger all bout little bikes since I got my bandit I was wondering if it had mito sp internals the con rod has a hole drilled in the top aswell is that normal
bikedudextrm
PostPosted: 23:27 - 18 Aug 2004    Post subject: Reply with quote
I had a cagiva supercity (same engine), the hole is meant to be at the top off the conrod as it was on my supercity too, my supercity used the dome top piston with 2 rings, newer mito's use the flat top piston with a single ring. I was told by a tuner that the dome top with 2 rings gives more compression than the flat top with single ring.
Police Tut Tut
https://www.bikepics.com/members/bikedudextrm/
The last post was made 22 years, 59 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 51.8 Kb
