DESPERATE! Cant handle rain?
adamcfc
PostPosted: 00:08 - 30 Apr 2011    Post subject: DESPERATE! Cant handle rain? Reply with quote
Hello, my names adam, im 16 and own a Rieju RS2 Matrix 50cc. A geared bike, made in 2007, done just over 4000 miles.
I am desperate for help ASAP, hopefully today as i plan on sorting it out saturday and sunday if someone can help me on here. I should also point out whilst i know more than the average 16 year old about bikes, im no way an expert Smile
The problem - its a long story.
I bought the bike about a month ago, in seemingly immaculate condition other than the fact it wouldnt start on the button. The bloke had put a new battery and starter motor in and said the problem laid with the starter solenoid. It bumpstarted and ran fine. On the way home i could hear fizzing, so pulled over only to find watery substance all over the right fairing, the coolant was leaking from the lid and dripping onto the exhaust manifold then evapourating, apparently so. Until i got the lid fixed i was topping up the expansion bottle after every ride and sometimes during it, being careful to never let the bottle be completely empty.
One day at school it rained, the first since i had the bike. I went to start it after school (bump start) everything was fine, rode about 200m and then it started spluttering, losing power, and eventually died. Now things were strange, it would start, then find it very difficult to idle, if i revved it it would only go to around 5000 revs and then the next twist of the throttle only took it to 4000, then 2500, and so on until it died again. There was also white smoke from the exhaust. We left it at school as it was unridable and came back the next morning, to find the same problems. So it went to the garage.
The garage said it was the head gasket becuase the coolant bottle was emptying into the engine. They tried the new head gasket 4 times, (events i wont go into) the garage took around 2 weeks to do this, until we just collected it and took it to a man to fix in his spare time. Each time the garage changed the gasket after a few hours the water had leaked back into the engine.
Today i got the bike back from the man after another week. He replaced the piston barrel and head as they were incredibly warped and rubbed. This is because the thermostat wasnt connected, so i didnt know when the boke was overheating, which it must have done due to coolant problems. So this warped the head and blew the head gasket. He charge me £302.78 for parts and labour.
I rode the bike today, seemed fine although a little different. Its been running ok today. Then as i left my girfreinds house it rained VERY hard, 5 mins later it was spluttering as i was riding and losing power until it wouldnt rev above 2000 and died. Once again i can start it but it wont rev, dies, and has white smoke coming from the exhaust.
Any ideas? Is this an electrical problem (there was a slight problem after the episode today when it lost power and went funny again, but i can expand on that if i need too)? Is it due to water leaking in the top of the fuel tank? Water in the carburetta?
Only proper symptoms i can give is that theres white smoke, and if left idling will rev once up to about 5000, then goes down and down until it dies.
Really need help please, i have the next two days to try out any solutions.
Many thanks, Adam Crying or Very sad
binge
Emo Kiddy
PostPosted: 00:15 - 30 Apr 2011    Post subject: Reply with quote
What condition is your HT lead in?
2 strokes are renowned for cutting out in the rain because of water getting in and around the HT lead and cap.
Pull the cap off, clean it out. Give it a mist of WD40, and put it back onto the plug. While you're there, whip the plug out, and check to see how it's burning.
Make sure the Airbox is clean, and fixed properly onto the carb.
And it might also be worth, just trying out a shower cap or some sort, pulled over the petrol tank, to eliminate the fact of water in the tank.
Ben
adamcfc
PostPosted: 00:27 - 30 Apr 2011    Post subject: Reply with quote
Thanks for the reply. Going to have to ask what a HT lead is though :/ Is that what delivers the spark into the head of the piston?
It has a racing air filter on the carb, a metallic red one. I can give that a check tomorow by taking it off?
Yeah i will try with the shower cap, but last time i couldnt get the bike running again so will try that once its working again.
Thanks again Smile
hornetmike
PostPosted: 00:35 - 30 Apr 2011    Post subject: Reply with quote
sure its not the head again ?
87 Honda CG 125 - 97 ER5 - SR 50 -81 Z250- 96 CBR 600 F- 94 GPX600R 88- GPX 400R- 87 GS 125 - 2006 Honda CB600F- 2003 ER5 - Honda CBF 1000 2009 - Honda CBR 600 RR 2011
Current BMW R1200GS 2010
adamcfc
PostPosted: 00:40 - 30 Apr 2011    Post subject: Reply with quote
I just cant see how it can be the head again. Ive done nothing for it to go? It just rained. And its less than 48 hours old, and done less than 50 miles of which ive been going careful anyway.
Frost
PostPosted: 00:48 - 30 Apr 2011    Post subject: Reply with quote
Sounds like someone has modified the air box or air filter to try to make it go faster but just let it fill up with water. It's also possible that there is water in the fuel, or carb.
adamcfc
PostPosted: 00:54 - 30 Apr 2011    Post subject: Reply with quote
Ok, so tomorow i will take the fairings off, take the air filter off and check it for crap, and check its not wet?
Is there a way of checking for water in the fuel tank, or checking the HT lead?
And i will google how to clean the carburetta and might attempt that, but what would i be looking for to know theres water in there?
And any other ideas are useful Smile
I will check back in the morning, and start to try a few things out on it. Many thanks
adamcfc
PostPosted: 00:57 - 30 Apr 2011    Post subject: Reply with quote
Ben
Can someone explain how i see how its burning, and what im looking for?
kramdra
PostPosted: 01:01 - 30 Apr 2011    Post subject: Reply with quote
I dont know about 2 strokes however should be pissible to do compression/leak down test.
If the gasket surfaces are not good, it will leak and need to be resurfaced. + are the head bolts done up correctly
did you follow the run in, since its a new barrel?
Noxious89123
PostPosted: 01:04 - 30 Apr 2011    Post subject: Reply with quote
Here's a chart showing different spark plug condition / colour that will give you an indication of how it's running. Failing that, you can always take a photo and post it up here for a second opinion.
https://img26.imageshack.us/img26/3743/readingsparkplugs.jpg
Paxovasa
PostPosted: 05:58 - 30 Apr 2011    Post subject: Reply with quote
HT lead is the lead that clips onto the spark plug. Water may be getting flicked up and onto the spark plug (HT lead) by the front wheel. As has been suggested, spray the plug and the spark plug cap (HT lead) with wd40.
adamcfc
PostPosted: 07:19 - 30 Apr 2011    Post subject: Reply with quote
Yeah, the bloke whos been fixing it knows what hes doing i just cant get hold of him at the moment.
The thing is he replaced the gasket and put the head, barrel and engine back together friday night. I picked it up at 2pm yesturday and did about 40 miles with it carefully. So the thing is this head and barrel has literally a few hours and a few miles on it so i really dont understand how it can of gone again Confused
As i couldnt pick it up i had to park it in the underground car park or Tesco last night at 11pm Rolling Eyes just going to pick it up now, and it may of had a chance to dry off whatever was wrong, but i dont have much hope as the last time it got wet it did the exact same thing the next day as well.
As for the spark plug, i can have a look at that and spray it so it doesnt do it again, but i need to get the bike working again first which im struggling with.
Will update soon Smile
Ichy
PostPosted: 07:27 - 30 Apr 2011    Post subject: Reply with quote
How exposed is the air filter? Pod filters are notorious for soaking up water when it rains which causes them to become restrictive. This creates a very rich mixture and stops the bike from reving. Next time it does it just pull the filter off and see if it improves. Don't leave it off for too long since the mixture will go weak without the filter on there. From a practical point of view your far better off fitting an original air box.
adamcfc
PostPosted: 08:13 - 30 Apr 2011    Post subject: Reply with quote
Thanks Marki, il bear that in mind next time Very Happy
BREAKTHROUGH!?
Tried it about 30mins ago and exactly the same, sounds like its misfiring, and still the white smoke.
Now, i opened to fuel cap, to see drops of water clearly along the bottom of the cap! I think water must have got in the petrol tank through a dodgy seal around the top of the tank. If the engine was combusting water aswell, would this produce white smoke?
Im going to drain the petrol down this morning, and replace with new stuff, then try the bike again. Like i say it starts and idles okay, but wont go above 5-6000 rpm, would this also be explained by water in the fuel? But when i put the new petrol in, wont water still be left in the tank, so should i try and flush some petrol through the tank first before i put all the new petrol in?
Finally, could this have gone further, i.e water gone into the carb, or engine, or somewhere else, if i just change the petrol is that the right thing to do.
Paxovasa
PostPosted: 08:26 - 30 Apr 2011    Post subject: Reply with quote
If you have water in the tank, it will also get into the carb.
Drain the fuel tank and the carb.
binge
Emo Kiddy
PostPosted: 09:12 - 30 Apr 2011    Post subject: Reply with quote
Bingo! There is your problem right there.
I've been there and done it plenty of times, with open air filters and 2 strokes.
It just doesn't happen. Laughing
The only "Racing" air filter you will ever get to work right on a 2t, is a massive foam one, made by TAG or companies like that.
The little metal fake, K&N sort just dont work.
In all seriousness, either fit an original air box, Or build some sort of rain cover to go around the carb.
I remember doing this on my old Speedfight to stop water getting into it when it rained.
Also, for the tank. For the time being, just cover the cap up with duct tape until you know it's running okay.
Ben
adamcfc
PostPosted: 09:37 - 30 Apr 2011    Post subject: Reply with quote
Ok so if its the air filter causing the problem, how do i get the bike running again? Then i can look at replacing it or protecting it, thanks again, Adam
Livefast123
PostPosted: 13:34 - 30 Apr 2011    Post subject: Reply with quote
Get rid of that pile of tat off your bike NOW and hopefully it will sort out some of the problems. 2 strokes hate pod filters and when it rains the pod filter gets wet, letting water into the engine and bogging it down, hence your white smoke out the back.
Get an original airbox from ebay and fit that. manufacturers spend ages getting the air box volume and filter density right for a reason!!
Spray your whole HT system with WD 40 or ignition sealer. Check the tank seal and replace if you have water in the tank.
Sounds like the guy who sold it to you royally fuc*ked you over by disconnecting the temperature sender to hide the overheating problem. Pity he didn't spend as much effort replacing the expansion bottle cap.
Sounds like your mechanics sorted the most expensive issue but any mechanic worth his salt should know about 2 strokes and pod filters, especially exposed ones.
Current ride - Yamaha MT-07
Truzo
PostPosted: 00:52 - 01 May 2011    Post subject: Reply with quote
When i got my rd125 it had a nasty k&N air filter on it.
The bike ran like dog shit !!!
Standard orignal air filter FTW !
Truzo.
Current Bikes: RXS 100, RD 125lc3, RD 350 F2
finpos
PostPosted: 11:37 - 01 May 2011    Post subject: Reply with quote
Agree with getting rid of the pod filters, but if you have water in the tank, it didn't get in through them.
Most likely the water drain for the tank is blocked. If you look around the cap recess, you should be able to see a small hole somewhere. Pour some petrol into the tank recess (not into the tank) and it should hopefully vanish down that hole through a tube that runs internally to the tank and come out of a metal pipe on the bottom of the tank - this should have on it a rubber tube which runs down the bike and comes out near the bottom of it somewhere.
If it's blocked, then water will build up in the tank recess and eventually get sucked in through the cap's air breather hole. You can try to run a bit of fishing line or similar through it to unblock it, but usually the problem is that it's corroded and is leaking internally into the tank, making the water contamination even worse. If that's happened start looking out for a new tank because it's an absolute nightmare to repair.
f.
The last post was made 14 years, 335 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 112.23 Kb
