| adamcfc |
 adamcfc Borekit Bruiser
 Posted: 01:08 - 30 Apr 2011 Post subject: DESPERATE! Cant handle rain? |
Hello, my names adam, im 16 and own a Rieju RS2 Matrix 50cc. A geared bike, made in 2007, done just over 4000 miles.
I am desperate for help ASAP, hopefully today as i plan on sorting it out saturday and sunday if someone can help me on here. I should also point out whilst i know more than the average 16 year old about bikes, im no way an expert
The problem - its a long story.
I bought the bike about a month ago, in seemingly immaculate condition other than the fact it wouldnt start on the button. The bloke had put a new battery and starter motor in and said the problem laid with the starter solenoid. It bumpstarted and ran fine. On the way home i could hear fizzing, so pulled over only to find watery substance all over the right fairing, the coolant was leaking from the lid and dripping onto the exhaust manifold then evapourating, apparently so. Until i got the lid fixed i was topping up the expansion bottle after every ride and sometimes during it, being careful to never let the bottle be completely empty.
One day at school it rained, the first since i had the bike. I went to start it after school (bump start) everything was fine, rode about 200m and then it started spluttering, losing power, and eventually died. Now things were strange, it would start, then find it very difficult to idle, if i revved it it would only go to around 5000 revs and then the next twist of the throttle only took it to 4000, then 2500, and so on until it died again. There was also white smoke from the exhaust. We left it at school as it was unridable and came back the next morning, to find the same problems. So it went to the garage.
The garage said it was the head gasket becuase the coolant bottle was emptying into the engine. They tried the new head gasket 4 times, (events i wont go into) the garage took around 2 weeks to do this, until we just collected it and took it to a man to fix in his spare time. Each time the garage changed the gasket after a few hours the water had leaked back into the engine.
Today i got the bike back from the man after another week. He replaced the piston barrel and head as they were incredibly warped and rubbed. This is because the thermostat wasnt connected, so i didnt know when the boke was overheating, which it must have done due to coolant problems. So this warped the head and blew the head gasket. He charge me £302.78 for parts and labour.
I rode the bike today, seemed fine although a little different. Its been running ok today. Then as i left my girfreinds house it rained VERY hard, 5 mins later it was spluttering as i was riding and losing power until it wouldnt rev above 2000 and died. Once again i can start it but it wont rev, dies, and has white smoke coming from the exhaust.
Any ideas? Is this an electrical problem (there was a slight problem after the episode today when it lost power and went funny again, but i can expand on that if i need too)? Is it due to water leaking in the top of the fuel tank? Water in the carburetta?
Only proper symptoms i can give is that theres white smoke, and if left idling will rev once up to about 5000, then goes down and down until it dies.
Really need help please, i have the next two days to try out any solutions.
Many thanks, Adam
| binge |
 binge Emo Kiddy
| adamcfc |
 Posted: 01:27 - 30 Apr 2011 Post subject: |
Thanks for the reply. Going to have to ask what a HT lead is though :/ Is that what delivers the spark into the head of the piston?
It has a racing air filter on the carb, a metallic red one. I can give that a check tomorow by taking it off?
Yeah i will try with the shower cap, but last time i couldnt get the bike running again so will try that once its working again.
Thanks again  |
| hornetmike |
 hornetmike World Chat Champion
| adamcfc |
| Frost |
 Frost World Chat Champion
| adamcfc |
 Posted: 01:54 - 30 Apr 2011 Post subject: |
Ok, so tomorow i will take the fairings off, take the air filter off and check it for crap, and check its not wet?
Is there a way of checking for water in the fuel tank, or checking the HT lead?
And i will google how to clean the carburetta and might attempt that, but what would i be looking for to know theres water in there?
And any other ideas are useful
I will check back in the morning, and start to try a few things out on it. Many thanks |
| adamcfc |
| kramdra |
 kramdra World Chat Champion
| Noxious89123 |
 Noxious89123 World Chat Champion
| Paxovasa |
 Paxovasa World Chat Champion
| adamcfc |
 Posted: 08:19 - 30 Apr 2011 Post subject: |
| Ichy |
 Ichy World Chat Champion
 Posted: 08:27 - 30 Apr 2011 Post subject: |
How exposed is the air filter? Pod filters are notorious for soaking up water when it rains which causes them to become restrictive. This creates a very rich mixture and stops the bike from reving. Next time it does it just pull the filter off and see if it improves. Don't leave it off for too long since the mixture will go weak without the filter on there. From a practical point of view your far better off fitting an original air box. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| adamcfc |
 Posted: 09:13 - 30 Apr 2011 Post subject: |
Thanks Marki, il bear that in mind next time
BREAKTHROUGH!?
Tried it about 30mins ago and exactly the same, sounds like its misfiring, and still the white smoke.
Now, i opened to fuel cap, to see drops of water clearly along the bottom of the cap! I think water must have got in the petrol tank through a dodgy seal around the top of the tank. If the engine was combusting water aswell, would this produce white smoke?
Im going to drain the petrol down this morning, and replace with new stuff, then try the bike again. Like i say it starts and idles okay, but wont go above 5-6000 rpm, would this also be explained by water in the fuel? But when i put the new petrol in, wont water still be left in the tank, so should i try and flush some petrol through the tank first before i put all the new petrol in?
Finally, could this have gone further, i.e water gone into the carb, or engine, or somewhere else, if i just change the petrol is that the right thing to do. |
| Paxovasa |
| binge |
 binge Emo Kiddy
| adamcfc |
| Livefast123 |
 Livefast123 Nearly there...
| Truzo |
 Truzo Nova Slayer
| finpos |
 finpos World Chat Champion
The last post was made 14 years, 339 days ago. Instead of replying here, would creating a new thread be more useful? |
