| Charlie |
 Charlie World Chat Champion
| prawny1 |
 prawny1 World Chat Champion
| Charlie |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 18:30 - 30 Apr 2011 Post subject: |
Where does it read from? Sprocket or front wheel?
If sprocket, are you running standard gearing, if front wheel is that standard?
Fit a speedohealer if your speedo's electronic.
If it's cable driven, I'm not entirely sure.  ____________________ My Flickr |
| Rogerborg |
 Rogerborg nimbA
 Posted: 10:03 - 01 May 2011 Post subject: |
Speedos tend to read about 5% over, but yours sounds extreme.
From a quick eBay trawl, it looks like the VFR750 used to use a front wheel drive but changed to an engine drive somewhere before 1992.
| Big_Ham wrote: | If sprocket, are you running standard gearing |
By which we mean: count the number of teeth on the front sprocket (should be 16) and the rear sprocket (should be 43). If there are fewer teeth on the front, and/or or more on the rear then that's shortened the gearing and the engine will be revving higher for a given speed than the speedo expects. ____________________ Biking is 1/20th as dangerous as horse riding.
| Kickstart |
 Kickstart The Oracle
| Charlie |
 Posted: 07:49 - 02 May 2011 Post subject: |
My first thought was different sprockets... I haven't counted them however the receipt for when they where last changed says 16 and 43.
The next thing I thought of was what Keith said, but I dismissed it thinking they'd be the same. Good to know the mph speedo drive may be different to km/h one. I'll give the sprockets a count before I change them over.
Thanks guys  ____________________ Past: Honda x8rs, Honda City fly, Honda Hornet 250, Honda VFR750, Yamaha xt600e.
Current: Honda CBR929RR & Yamaha XT660Z Tenere |
| Kickstart |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 13:02 - 02 May 2011 Post subject: |
rog's comment about sproket drive speedo is intreguing.
My imediete reaction would have been, that its a front wheel speedo drive, and the same wheel's tyres and brakes as my '93 CB750...
And they have 'uncommon' tyres sizings.
I cant remember what the 'book' sizes are, but they are a tad narrow and not as 'low' profile as more contemprary bikes.
My 750 over reads a little, as it has a 120/60 front tyre on it, where I think it ought to have a 120/70 'or something'.....
Not sure and doesn't matter..... but check the tyre sizes, as 40 & 50 profile tyres are a lot more common and easier to get hold of these days, and MORE than likely, whether the speedo drives from or sproket, a lower profile tyre would reduce the roling diameter of the wheel, hence have to do more turns to cover a mile, hence make teh speedo over read..... and that would work whichever end the speedo takes from. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Charlie |
 Posted: 15:05 - 02 May 2011 Post subject: |
I'll check them to then Mike, I didn't think that wrong sized tyres would change the speedo readings when it is sprocket driven but now you've said it makes sense that it could. Thanks  ____________________ Past: Honda x8rs, Honda City fly, Honda Hornet 250, Honda VFR750, Yamaha xt600e.
| Charlie |
 Posted: 16:27 - 13 Jun 2011 Post subject: |
Right I've finally got around to having a look into this.
Front tyre: 120/70 as per handbook
Rear tyre: 170/60 as per handbook
Front sprocket: 16 tooth
Rear sprocket: 43 tooth
So that is all what is expected.
I've emailed David Silver and they say that there doesn't seem to be any differences between different speedo drivers...
I had a look at the speedo driver and it seems fine and spins freely. I am still tempted to try a different speedo driver (eBay for £16 or so), as I cant see what else would be wrong
Anyone got any further ideas? ____________________ Past: Honda x8rs, Honda City fly, Honda Hornet 250, Honda VFR750, Yamaha xt600e.
| Kickstart |
 Posted: 16:51 - 13 Jun 2011 Post subject: |
Not sure what to suggest. Possibly look for a speedo healer hidden somewhere. Could be that someone has had different gearing on at some point and used a speedo healer to correct the speedo reading, then gone back to stock gearing without removing the speedo healer.
However looking at a parts list it looks like the speedo is cable driven (there is a gearbox for it on the back of the clocks, although the same one for both mph and kmh), but I can't see where it is driven from (and can't find the cable shown anywhere).
| Charlie |
| Charlie |
The last post was made 15 years, 129 days ago. Instead of replying here, would creating a new thread be more useful? |
