Inaccurate speedo
Charlie
PostPosted: 12:02 - 30 Apr 2011    Post subject: Inaccurate speedo Reply with quote
I bought a new bike not so long ago and the speedo is really inaccurate. When riding next to my brother, my 30mph is actually his 20/25mph. Following cars that have slowed down for 30mph speed cameras mine shows around 35-38mph.
It get's a bit 'wobbly' on the wrong side of 100. Just gets a bit annoying not knowing how fast I am going.
The bike is 1993 vfr750, it was imported from Belgium but has UK clocks on (not sure when they where added).
Any ideas?
prawny1
PostPosted: 12:09 - 30 Apr 2011    Post subject: Reply with quote
Buy a sat nav
hellkat wrote:
Charlie
PostPosted: 12:24 - 30 Apr 2011    Post subject: Reply with quote
I could use my iPhone for that and just have it on charge all the time while on the bike. But I'd rather not and just use the speedo.
PostPosted: 18:30 - 30 Apr 2011    Post subject: Reply with quote
Where does it read from? Sprocket or front wheel?
If sprocket, are you running standard gearing, if front wheel is that standard?
Fit a speedohealer if your speedo's electronic.
If it's cable driven, I'm not entirely sure. Confused
PostPosted: 10:03 - 01 May 2011    Post subject: Reply with quote
Speedos tend to read about 5% over, but yours sounds extreme.
From a quick eBay trawl, it looks like the VFR750 used to use a front wheel drive but changed to an engine drive somewhere before 1992.
By which we mean: count the number of teeth on the front sprocket (should be 16) and the rear sprocket (should be 43). If there are fewer teeth on the front, and/or or more on the rear then that's shortened the gearing and the engine will be revving higher for a given speed than the speedo expects.
PostPosted: 12:04 - 01 May 2011    Post subject: Reply with quote
It is within the very lax allowance for accuracy (10% +8kmh) but does sound miles out.
As I understand it some Hondas not only had different clocks but also speedo drives between mph and kmh
Charlie
PostPosted: 07:49 - 02 May 2011    Post subject: Reply with quote
My first thought was different sprockets... I haven't counted them however the receipt for when they where last changed says 16 and 43.
The next thing I thought of was what Keith said, but I dismissed it thinking they'd be the same. Good to know the mph speedo drive may be different to km/h one. I'll give the sprockets a count before I change them over.
Thanks guys Karma Thumbs Up
PostPosted: 12:24 - 02 May 2011    Post subject: Reply with quote
It doesn't make sense to me either, unless they changed the gearing between markets.
Teflon-Mike
tl;dr
PostPosted: 13:02 - 02 May 2011    Post subject: Reply with quote
rog's comment about sproket drive speedo is intreguing.
My imediete reaction would have been, that its a front wheel speedo drive, and the same wheel's tyres and brakes as my '93 CB750...
And they have 'uncommon' tyres sizings.
I cant remember what the 'book' sizes are, but they are a tad narrow and not as 'low' profile as more contemprary bikes.
My 750 over reads a little, as it has a 120/60 front tyre on it, where I think it ought to have a 120/70 'or something'.....
Not sure and doesn't matter..... but check the tyre sizes, as 40 & 50 profile tyres are a lot more common and easier to get hold of these days, and MORE than likely, whether the speedo drives from or sproket, a lower profile tyre would reduce the roling diameter of the wheel, hence have to do more turns to cover a mile, hence make teh speedo over read..... and that would work whichever end the speedo takes from.
Charlie
PostPosted: 15:05 - 02 May 2011    Post subject: Reply with quote
I'll check them to then Mike, I didn't think that wrong sized tyres would change the speedo readings when it is sprocket driven but now you've said it makes sense that it could. Thanks Karma Thumbs Up
Charlie
PostPosted: 16:27 - 13 Jun 2011    Post subject: Reply with quote
Right I've finally got around to having a look into this.
Front tyre: 120/70 as per handbook
Rear tyre: 170/60 as per handbook
Front sprocket: 16 tooth
Rear sprocket: 43 tooth
So that is all what is expected.
I've emailed David Silver and they say that there doesn't seem to be any differences between different speedo drivers...
I had a look at the speedo driver and it seems fine and spins freely. I am still tempted to try a different speedo driver (eBay for £16 or so), as I cant see what else would be wrong Confused
Anyone got any further ideas?
PostPosted: 16:51 - 13 Jun 2011    Post subject: Reply with quote
Not sure what to suggest. Possibly look for a speedo healer hidden somewhere. Could be that someone has had different gearing on at some point and used a speedo healer to correct the speedo reading, then gone back to stock gearing without removing the speedo healer.
However looking at a parts list it looks like the speedo is cable driven (there is a gearbox for it on the back of the clocks, although the same one for both mph and kmh), but I can't see where it is driven from (and can't find the cable shown anywhere).
Charlie
PostPosted: 17:17 - 13 Jun 2011    Post subject: Reply with quote
It's driven from the front sprocket and is cable driven. I've had a look along on the cable and there is no speedo healers fitted.
Having a bit of a read I've found this:
steve27bha wrote:
I changed to a MPH speedo on my 750FR and found it read about three quarters of the correct speed and distance. The sender on the front sprocket needs changing as well. Some are marked with a 3 for the european KpH speedo, but neither of my two had any distinguishing marks.
I think this part is common on other models as well as VFR750s. I got a secondhand unit but its cable was short - probably from a FL-FP model. It works OK after I managed to extend the wiring with a pair of connectors from my spare wires box.
There is a MPH speedo on eBay right now from WEMOTO starting at £10 IIRC.
However David Silver said this:
Nick @ David Silver wrote:
It does appear that all VFR750 FP' share the same speedo gear at the engine end so I cannot see that this would solve your problem. It may well work but I'm afraid we do not know. Honda do not give out any technical figures for these parts and we do not work on the bikes here. If you do wish to go ahead the part number is 44800MR7003 which we can order in @ £100.64 including VAT.
(a £100!!! Shocked)
Think I'll probably give a second speedo drive ago and see what happens Confused
Charlie
PostPosted: 17:35 - 13 Jun 2011    Post subject: Reply with quote
Although I then find a topic saying this:
MarkJHarris wrote:
And now the answer to the question.
Yes, the speedo drive should drive the MPH clock straight away with no problems!
The mechanical or electronic drives are all driven from the same type of unit at the front sprocket cover.
Honda wouldn't bugger about changing drive gears here, simply unnecessary.
Providing the gearing is the same, the drive revs/signals will go to the speedo and the gearing is switched here.
The clock will go straight on.
It's DAVID SILVER SPARES by the way
The last post was made 15 years, 130 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.55 - MySQL Queries: 13 - Page Size: 89.96 Kb
