DIY paint job -Pic Heavy
poole122
PostPosted: 17:53 - 30 Apr 2011    Post subject: DIY paint job -Pic Heavy Reply with quote
ok so after lots of back and forth i finally decided what colour i wanted for my bike, and i also decided to have a go myself Neutral
bike before:
https://i231.photobucket.com/albums/ee277/poole122/mynewtoy3.jpg
prep and primer:
https://i231.photobucket.com/albums/ee277/poole122/motorbikepaintjob009.jpg
https://i231.photobucket.com/albums/ee277/poole122/motorbikepaintjob008.jpg
https://i231.photobucket.com/albums/ee277/poole122/motorbikepaintjob011.jpg
https://i231.photobucket.com/albums/ee277/poole122/motorbikepaintjob013.jpg
https://i231.photobucket.com/albums/ee277/poole122/motorbikepaintjob014.jpg
base colour:
https://i231.photobucket.com/albums/ee277/poole122/motorbikepaintjob018.jpg
https://i231.photobucket.com/albums/ee277/poole122/motorbikepaintjob020.jpg
https://i231.photobucket.com/albums/ee277/poole122/motorbikepaintjob022.jpg
second colour:
https://i231.photobucket.com/albums/ee277/poole122/motorbikepaintjob023.jpg
https://i231.photobucket.com/albums/ee277/poole122/motorbikepaintjob026.jpg
https://i231.photobucket.com/albums/ee277/poole122/motorbikepaintjob027.jpg
https://i231.photobucket.com/albums/ee277/poole122/motorbikepaintjob033.jpg
bike finished and shiny:
https://i231.photobucket.com/albums/ee277/poole122/motorbikepaintjob001.jpg
https://i231.photobucket.com/albums/ee277/poole122/motorbikepaintjob002.jpg
https://i231.photobucket.com/albums/ee277/poole122/motorbikepaintjob003.jpg
https://i231.photobucket.com/albums/ee277/poole122/motorbikepaintjob030.jpg
https://i231.photobucket.com/albums/ee277/poole122/motorbikepaintjob031.jpg
https://i231.photobucket.com/albums/ee277/poole122/motorbikepaintjob035.jpg
the orange is pearlescent with a metalic flake so looks great when the sun catches it Very Happy
i know its not everyones taste but i love it Wub
PostPosted: 17:58 - 30 Apr 2011    Post subject: Reply with quote
[rsimg] isn't a tag in use on this forum. you want to use
Code:
[img][/img]
Edit your post and find and replace rs with an empty string and you should be sorted.
We only use [img] here, not [rsimg].
poole122
PostPosted: 18:04 - 30 Apr 2011    Post subject: Reply with quote
cheers for the advise, should work now Surprised
deleted111
PostPosted: 18:07 - 30 Apr 2011    Post subject: Reply with quote
I like that, good work Thumbs Up Thumbs Up
serlant
PostPosted: 18:23 - 30 Apr 2011    Post subject: Reply with quote
Possibly looking into respraying the fairings on my bike, which paint did you use? as I fancied a metallic black, and any tips on doing it?
04 CBR1000RR, 1995 Husqvarna TE410, 1998 VTR1000(Sold), 1990 XJ600(sold), 1996 KH125(dead and sold)
poole122
PostPosted: 18:45 - 30 Apr 2011    Post subject: Reply with quote
i just used the spray paints from halfords, there very good quality. best tip i could give is spend alot of time on prep, i spent 12 hours just sanding down and cleaning to make sure everything was smooth. if your doing metalic black you will need the grey primer. i used 2500 grit sand paper between each coat and that gave it a very smooth finish. jsut take your time and dont rush Very Happy
this link might help:
https://www.fireblades.org/forums/honda-cbr400rr/84564-respraying.html
serlant
PostPosted: 19:43 - 30 Apr 2011    Post subject: Reply with quote
Perfect timing, I was looking around halfords paint section earlier today, but was unsure of the paints, i'll give it a go Razz and 2500 you say? :O how much paint was used on the lot?
poole122
PostPosted: 19:52 - 30 Apr 2011    Post subject: Reply with quote
ha yeah i used quite a high grade paper, most recomend anything between 1500 - 2000 between coats and 150 for sanding down. i used 4x500ml cans for the orange, 2x500ml for the black, 4x500ml primer, 1x500ml petrol laquer for the tank and 2x500ml clear laquer for the rest Smile
ryhardcastle
PostPosted: 20:05 - 30 Apr 2011    Post subject: Reply with quote
One of the best rattle can jobs I have ever seen Thumbs Up
How long has it been since you sprayed the lacquer? Let it set properly for a good fortnight and then get some rubbing compound on and it will come up super shiny. Wink Then some decent wax to keep it in top nick.
crowe
PostPosted: 20:07 - 30 Apr 2011    Post subject: Reply with quote
Looks brilliant!
Are you going to do anything with the wheels? Paint or maybe just rimtape?
Kawasaki ER-5
poole122
PostPosted: 20:15 - 30 Apr 2011    Post subject: Reply with quote
thanks mate, much appreciated. I left it for 1 week to dry in a warm room (ie dining room)lol ive got some rubbing compound ready to go, and always have wax in the garage Wink
the wheels are going to be powder coated black then with an orange rim tape Very Happy
GeneralXcepti...
PostPosted: 20:28 - 30 Apr 2011    Post subject: Reply with quote
Looking really nice. Love the colour, but I think I prefer the white instead of the black (for the lines) but that's just just me and my lack of taste Very Happy
Couple of questions for ya. How come you didn't remove the filler cap before you started sanding the tank? Did you mask it up to stop the thing from getting accidentaly scratched?
What tape did you use to mask off the lines and when did you take the tape away? I was so tempted to put a white line down the middle of my tank but wasn't sure if the edges would be clean enough? I heard that you should remove it whilst the paint is still wet - how'd you get on?
poole122
PostPosted: 20:56 - 30 Apr 2011    Post subject: Reply with quote
must admit i thought the white orange was a really nice contrast, might be an idea for someone else to use Wink i removed the filler cap after the initial sand down, im going to be buffing and polishing up the filler cap so wasnt to bothered if got scrached as i will be doing that in a couple of weeks.
i bought some autocare masking tape from halfords, i spent about 30 minutes applying the tape, i made sure the line was spot on, then rubbed down the edges of the tape until i was happy there were no creases/bubbles. the directions say to leave on for no longer than 2 hours, and this gave the result above Thumbs Up
m0l0t0v
PostPosted: 22:08 - 30 Apr 2011    Post subject: Reply with quote
I still don't like the headlight, radiator wing things and the lever guards.
BUT, awesome job on the paintjob. Thumbs Up
poole122
PostPosted: 22:34 - 30 Apr 2011    Post subject: Reply with quote
ha cheers, i knows its not to everyones taste but shes almost perfect in my eyes Mr. Green lol
GREENI3
Now your bike really does look like a hornet! Wink
m0l0t0v
PostPosted: 22:40 - 30 Apr 2011    Post subject: Reply with quote
To each his own Wink
How much did all th spray paint and sanding stuff cost If you don't mind my asking?
poole122
PostPosted: 23:01 - 30 Apr 2011    Post subject: Reply with quote
total cost for everything was just under 120, bought everything from halfords. accept decals ofcourse lol
m0l0t0v
PostPosted: 23:34 - 30 Apr 2011    Post subject: Reply with quote
That's awesome.
May try this for my cheaper Hornet then...
dixiethedog
PostPosted: 09:32 - 01 May 2011    Post subject: Reply with quote
Thats a great looking job youve done! I think orange must be this years colour,just as an example,heres one ive just done for a friends Yamaha fj1200. Pass the sunglasses!
https://s596.photobucket.com/albums/tt50/lindarobjones/project%20stuff/?action=view¤t=100_1827.mp4
Every silver lining has a cloud....
poole122
PostPosted: 13:06 - 01 May 2011    Post subject: Reply with quote
as long as you've got the time and patience i would recommend having a go, its not overly complicated, just time consuming.
WOW mines got a metal fleck to it, but thats mad Shocked lol
m0l0t0v
PostPosted: 20:58 - 01 May 2011    Post subject: Reply with quote
Yeah I'll give it a shot, but a bit later on. Thumbs Up
moppy
PostPosted: 22:31 - 01 May 2011    Post subject: Reply with quote
Thats really impressive, well done.
Bike Bunker
PostPosted: 13:46 - 03 May 2011    Post subject: Reply with quote
Wicked!! wish i had the patient's facilities and knowledge to do my own painting Crying or Very sad
done a wicked job with rattle cans as well just thinking of the result if you had a air brush Shocked
Brilliant job
The last post was made 15 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.03 - MySQL Queries: 13 - Page Size: 137.36 Kb
