NEED HELP!!!!!!!!
Thekillerhams...
PostPosted: 19:06 - 02 May 2011    Post subject: NEED HELP!!!!!!!! Reply with quote
Hey I need help with my 125.
My bike wouldn't start the other morning and I'm not really sure what's wrong with it so I decided to see if anyone out there could help me.
It's a kangchao kc118 (I know all the bad comments about Chinese bike but I honestly it isn't a bad bike) when trying to start it with the kick start there is no resistance and won't start when kicking then all of a sudden there's a bang and the kick start has resistance and once kicked will start the bike, I have good compression and a ok spark. I have also replaced the starter coil and then cdi but doesn't help at all. The engine is a lifan 125 engine and wasn't sure if it's a common fault or the engine is knackered
Frost
PostPosted: 19:57 - 02 May 2011    Post subject: Reply with quote
Try push starting it. With the bike not in gear push it as fast as you can (rolling down a hill works well) and knock it into gear whilst giving it some throttle. If after a few goes it doesn't start you have engine trouble. If it starts okay, as above the kick start is the issue.
cloric_tzr
PostPosted: 20:00 - 02 May 2011    Post subject: Reply with quote
take the exhaust off stik ur willy in the port and get a assistant to kick her over. if she chopps ur bell of she fine
i dumped my girlfriend the other day! she wouldnt act out one of my fantasy's. all i wanted her to do was come home from work, catch me fucking her sister and join in!!! miserable bitch!
My wifes so ugly, the only thing that goes down on her
Is the internet connection.
Easter Bunny
PostPosted: 20:26 - 02 May 2011    Post subject: Reply with quote
If you do bump start it, do it in second gear!
PostPosted: 21:07 - 02 May 2011    Post subject: Reply with quote
1st is fine on a chinky dink, in fact I use first for most things...
PostPosted: 21:15 - 02 May 2011    Post subject: Reply with quote
Trying to knock it into gear whilst running is guaranteed to have him on his arse.
Best way is select second, clutch out, roll it backwards until you get resistance, clutch in. THEN run with it, jump on and dump the clutch.
dragstaar
PostPosted: 21:31 - 02 May 2011    Post subject: Reply with quote
If you have a nice big hill near you, its worth pushing it up to the top of that and rolling down as you try to bump start it.
Shaggy is right, Clutch in, roll, pick up speed, then dump clutch and see if that breathes some life into her
Frost
PostPosted: 22:11 - 02 May 2011    Post subject: Reply with quote
That's how i always do it. Push the bike up a big hill, sit on it, paddle your way down the hill for extra speed and kick it into 1st. I've managed it with some big old heavy bikes and i'm not exactly strong Laughing
Killer Rat
PostPosted: 22:48 - 02 May 2011    Post subject: Reply with quote
we are not related for the record.
No! No more talk! We go in! We kill! Kill! We kill 'em! They kill us, we kill them! Kill 'em! Kill 'em! Kill! Kill!
_______________________________________________________
cbf125 09', cbt passed 4/6/2010 - 28k miles - 1 major breakdown (stator)
Thekillerhams...
PostPosted: 08:23 - 03 May 2011    Post subject: Reply with quote
I tried to bump start it this morning but the clutch has decided not to work, I was wondering if that could any help or if that gives anyone any clues what's wrong with it
dragstaar
PostPosted: 10:27 - 03 May 2011    Post subject: Reply with quote
Do you mean that the clutch isn't disengaging?
Try rolling the bike back and forth whilst trying to change gear and it should free up
PostPosted: 10:48 - 03 May 2011    Post subject: Reply with quote
I hope its not one of those MZ style designs where it won't kick over if the clutch is disengaged. If it is, its more likely that your clutch is knackered than the kickstart ratchet gear...
Easter Bunny
PostPosted: 12:18 - 03 May 2011    Post subject: Reply with quote
I've always found that first gives too much of a jolt where as second just catches nicely! Thumbs Up
Thekillerhams...
PostPosted: 16:45 - 03 May 2011    Post subject: Reply with quote
I don't know it's really starting to annoy me, basically once I pull the clutch in nothing happens if it's in gear u can't roll the bike freely, I've triedto adjust the clutch but nothing at all happens
cloric_tzr
PostPosted: 18:54 - 03 May 2011    Post subject: Reply with quote
my bad obviously was not as amusing as it was in my head judging by the bad karma Razz
cloric_tzr
PostPosted: 19:00 - 03 May 2011    Post subject: Reply with quote
sounds like your clutch is dragging. i cant understand why it would stop it from starting though.
try the bumping method without using the clutch but go for second gear, bounce on the seat at the same time as engaging the gear to give it that extra oompfh (anyone who has had naff bikes or stuborn crossers will understand) its a bit of an art but affective never the less.
The last post was made 14 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 92.86 Kb
