ZX6-R Socket Set
Jon-W
PostPosted: 11:44 - 03 May 2011    Post subject: ZX6-R Socket Set Reply with quote
Hi All,
Sorry for the stupid question but can anyone tell me what size socket I will need for loosening the rear axle nut on my ZX6R. The Hayne's manual just doesnt say. All it says is I need a socket set with a 3/8" Drive.
Help appreciated!
PostPosted: 11:49 - 03 May 2011    Post subject: Reply with quote
Measure it.
A 1/2 drive would be better for the rear wheel bolt.
Souleh
PostPosted: 12:40 - 03 May 2011    Post subject: Reply with quote
B1H is a 32mm socket - Unsure of others sorry
DaveH
PostPosted: 13:34 - 03 May 2011    Post subject: Reply with quote
My J2 and the ZX7R are also 32mm, make sure you get a deep socket Thumbs Up
https://www.timhastingsracing.co.uk/
ZX7R & ER6F
Souleh
PostPosted: 13:55 - 03 May 2011    Post subject: Reply with quote
Sorry C1H is 32mm too, should know this since I swapped my swingarm.. lol
herulach
PostPosted: 19:55 - 03 May 2011    Post subject: Reply with quote
Just to confirm its usually stamped on the appropriate spanner that comes with the bikes toolkit.
Depending on the bike you may also need something to hold the other end of the axle
YBR 125>FZS600
Raffles
PostPosted: 21:25 - 03 May 2011    Post subject: Reply with quote
If you are going to purchase a socket set then you should do as chris says and go for a 1/2 inch set. I have several sizes of socket drives though I very rarely use the 3/8 drive. I find that it is too cumbersome for small stuff and not robust enough for the manly jobs. I wouldn't rate your chances of removing a 32mm wheel nut with a 3/8 drive very highly.
ZRX61
Victor Meldrew
PostPosted: 23:21 - 03 May 2011    Post subject: Reply with quote
I just have a 1/2in breaker bar & the right socket for axles, no need to buy a complete 1/2in drive set for one nut.... Break it lose, then stick the socket on a 3/8-1/2in adaptor... & you can easily tighten it with the 3/8 ratchet.
They're not one night stands, they're auditions.
Raffles
PostPosted: 23:54 - 03 May 2011    Post subject: Reply with quote
A breaker bar is one of the best tools anyone can buy. A good quality 1/2'' complete socket set should be owned by all bikers as a matter of course as a 3/8'' set is only really suitable for ''girly'' jobs. I use 1/4'' drive for small stuff and 1/2'' drive for stuff up to about 27mm. Anything above 27mm gets the 3/4'' treatment.
The last post was made 15 years, 53 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 58.85 Kb
