ARRRGGHHH HELP
cloric_tzr
PostPosted: 18:48 - 03 May 2011    Post subject: ARRRGGHHH HELP Reply with quote
im set up out the front of my house so quick help would be apreciated with karma rewards.
i cant get my f'in fork seals out its not as simple as the haynes illustrates, i think the previous owner has glued them in and being alloy i dont want to lever to hard (altho i aklread have give it quite alot,
do fork seals have steel inserts? other than the coil spring?
cheers rick
i dumped my girlfriend the other day! she wouldnt act out one of my fantasy's. all i wanted her to do was come home from work, catch me fucking her sister and join in!!! miserable bitch!
My wifes so ugly, the only thing that goes down on her
Is the internet connection.
Teflon-Mike
tl;dr
PostPosted: 20:35 - 03 May 2011    Post subject: Reply with quote
have you removed the cir-clip at the top of the seals?
dust cap
cir-clip
seal?
Snowtigeress
when i did the pups they were a pain to get out just prise they out by going all the way round the seal with a little force
https://i1177.photobucket.com/albums/x349/snowtigeress/forks/imag0877.jpg
Use the screw driver to take out the circlip that was under the dust cover in the slider
https://i1177.photobucket.com/albums/x349/snowtigeress/forks/imag0878.jpg
https://i1177.photobucket.com/albums/x349/snowtigeress/forks/imag0879.jpg
kestrel
PostPosted: 20:39 - 03 May 2011    Post subject: Reply with quote
^^^Was just going to ask about the circlips!
ZRX61
Victor Meldrew
PostPosted: 23:03 - 03 May 2011    Post subject: Reply with quote
dust cap
cir-clip
seal?
Snowtigeress
Christ, talk about doing it the hard way. Ya just remove the dust cover, pop the circlip out, remove the bolt at the bottom of the forks that holds the damper rod & pull the forks apart. The bushing on the fork leg will hit the bottom of the seal & pop it right out. None of this arsing about with pry bars & screwdrivers etc.
& it has the advantage of leaving the rest of the fork still assembled.
They're not one night stands, they're auditions.
cloric_tzr
PostPosted: 15:05 - 04 May 2011    Post subject: Reply with quote
dust cap
cir-clip
yes i have the forks are completly dis-assembled other than the seals themselves.
the forks are apart stantions out and wrapped along with the dampers springs ect.
its just the dambed seals wont budge. i was tempted to cut them out but i fear damaging the forks themselves.
the stantions came out with a pop but the seals are so worn there was not enough force to even budge them.
The last post was made 15 years, 168 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.25 - MySQL Queries: 13 - Page Size: 47.14 Kb
