05 bandit 650 tools
big.bee.time
PostPosted: 00:14 - 05 May 2011    Post subject: 05 bandit 650 tools Reply with quote
Hi could anyone help me with what special tool it is i need to get the bottom bolt out of the forks on my suzuki bandit 650 k5. In the manual it just says special tool with t bar handle and the picture is not much help. any help would be good.
hmmmnz
PostPosted: 03:04 - 05 May 2011    Post subject: Reply with quote
have a look and see what sort of nut it is Very Happy
easy
the humans are dead
I kick arse for the lord
Robby
Dirty Old Man
PostPosted: 05:38 - 05 May 2011    Post subject: Reply with quote
Assuming they are conventional forks, you should get away with not using the special tool. Before taking the fork apart, try just undoing the bottom bolt with an allen key at the bottom of the fork. The pressure of the fork spring acting on it should be enough to stop it rotating and let you undo the bolt.
The same goes for putting it back together. You should be able to get it done up tight enough to not leak when you assemble the fork and fill with oil, then you can tighten it up fully once the fork is fully assembled with the top cap back on.
If you do need a special tool, it is a long handle with essentially a nut on the end; the bottom bolt is shaped like a socket and the nut fits into it. There are a number of bodges, such as welding a correct size nut onto a rod and sticking that in there. I don't know the nut size, but google might find it, 17mm rings a bell. You can also try a wooden broom handle with the end slightly shaved off to make a slight taper that can be shoved into the bolt to stop it spinning.
Do not use threadlock on reassembly, but do use a new washer. I have never had one leak, you have a small hole with a bolt through it and a copper washer behind that, then the axle going through the hole above it to stop the bolt working loose and allowing leakage. More secure than a usual sump plug.
If you can't get it undone, see what Suzuki charge for the tool. Last time I checked it was about £15, I borrowed one from an owners club years ago for my VX800, so an owners club is another option to borrow one.
big.bee.time
PostPosted: 12:58 - 05 May 2011    Post subject: Reply with quote
Cheers that helps a good bit a might just try get hold of the tool if you can buy them SmileSmileSmileSmile Thumbs Up Thumbs Up
stirlinggaz
PostPosted: 14:14 - 05 May 2011    Post subject: Reply with quote
usual method is a broom handle, whittled to fit.(AFTER attempting to loosen bottom bolts before any other)
used it on umpteen bikes.
you seen the prices of these "special tools"?
not worth buying , unless you plan on doing a load of forks,
cheers,
GAZ
Bezzer
PostPosted: 14:16 - 05 May 2011    Post subject: Reply with quote
This is the Suzuki tool
https://i561.photobucket.com/albums/ss60/mickcbr1100/tools/ForkTool.jpg
The T bar is just a long 3/8ths" square drive that fits to it so you don't need that you can use a few 3/8ths" extension bars...but you do need about 2 feets worth.
It locates in a round hole at the bottom of the damper tube, you can get a bit of bar and shape it with an angle grinder to a point and use that, some people try broom handles but they are too thick to go right down the damper and just grip the top of the tube which usually isn't enough.
The Suzuki tool (just the pictured bit) costs around £20 Shocked
Part No 09940-34561 for some reason it's just called "Attachment D"
The best advice has already been given ie LOOSEN THE ALLEN BOLTS BEFORE YOU TAKE THE FORKS APART the pressure usually holds everything firm.
edit- told a lie Embarassed just checked and it costs £14.61 at the moment from Robinsons Foundry, but that's before you add postage etc
The last post was made 14 years, 279 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 50.41 Kb
