16" front wheel
1foggy
PostPosted: 21:11 - 04 May 2011    Post subject: 16" front wheel Reply with quote
Hi all got a blade with 16" front wheel but the privious owner streetfighterd the bike and put a small speedo on so what would i need to change to set the speedo right as speedo is set for 17" front wheel i think lol
900 blade RR wpb yx160
PostPosted: 22:09 - 04 May 2011    Post subject: Reply with quote
Have you actually checked the error?
MarkJ
PostPosted: 08:34 - 05 May 2011    Post subject: Reply with quote
My Hornet has the 16" fireblade wheel but the speedo was always driven off the front sprocket, is it the same with the blade?
Do you now have a bicycle speedo driven from the front wheel?
effit
PostPosted: 08:47 - 05 May 2011    Post subject: Reply with quote
My Fireblade has 16` front wheel and is driven from the front wheel.
What is the actual problem, are you doing 30 and its reading 80 or ssomething, for example? Also, where is the speedo being driven from at the moment?
binge
Emo Kiddy
PostPosted: 08:56 - 05 May 2011    Post subject: Reply with quote
As he said, the previous owner has fitted a small digital speedo by the sounds of it.
Speedo settings have nothing to do with wheel size. They go by the tyre circumference.
Ben
iooi
PostPosted: 09:02 - 05 May 2011    Post subject: Reply with quote
Ben
Would need a massive high profile tyre on a 16" wheel to make the same reading as a 17" wheel. Laughing
binge
Emo Kiddy
PostPosted: 09:12 - 05 May 2011    Post subject: Reply with quote
Hardly.
A 120/60-17 wouldnt have a much greater rolling radius, than a 120/70-16.
72mm profile on the 17,
84mm profile on the 16,
Overall tyre diameter wise;
The 17 will have a 575mm diameter.
The 16 will have a 574mm diameter.
*Hope's to fuck my calculations are right* Laughing
Ben
Bikeless
PostPosted: 09:18 - 05 May 2011    Post subject: Reply with quote
16" blade fronts generally had 130 section tyres,so the rolling diameter can't be much different.
PostPosted: 09:19 - 05 May 2011    Post subject: Reply with quote
431mm - 17"
406mm - 16"
72mm - 120/60
84mm - 120/70
Total Diameter 16" = 574
Total Diameter 17" = 575
I make you right
binge
Emo Kiddy
PostPosted: 09:27 - 05 May 2011    Post subject: Reply with quote
Forgot about that!
Even at 130/60-16, It'll still be 562mm total diameter.
Which is next to nothing.
Ben
1foggy
PostPosted: 20:07 - 05 May 2011    Post subject: Reply with quote
when im doing 30 mph speedo will say 40ish and cable is to front wheel and tyre is 130/60/16
kestrel
PostPosted: 20:45 - 05 May 2011    Post subject: Reply with quote
Mechanical speedometers driven from the front wheel are available with different ratios. It sounds like the replacement mini speedo that the previous owner fitted is not the correct ratio.
How to calculate the correct speedo ratio for your bike here:-
https://www.customfighters.com/forums/showthread.php?p=425467
The last post was made 14 years, 285 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 71.27 Kb
