| ms51ves3 |
 ms51ves3 Super Spammer
| m0l0t0v |
 m0l0t0v World Chat Champion
 Posted: 18:55 - 19 Apr 2011 Post subject: |
Would be more helpful if there was a link  ____________________ '99 Hornet 600 , VFR 400 NC30 '92 , Kasawamasaki GT 550 , '98 Hornet 600
**\Tarmacsurfer/** said: It's that immaculately manly coiffure of yours isn't it. One glimpse of your virile locks and the punters can't wait to buy whatever it is you suggest, as it might let them be just a little bit like the Adonis that is our very own Molly Doovydoo said: Its not my fault I can't get it up properly, I just wasn't blessed  |
| ms51ves3 |
| m0l0t0v |
 Posted: 20:17 - 19 Apr 2011 Post subject: |
| cb1rocket |
 cb1rocket World Chat Champion
| 2 litre |
 2 litre Nova Slayer
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 23:53 - 04 May 2011 Post subject: |
Strangely enough, I've just bought 5M (£2.50) of air tubing to do just this at the weekend. Using ATF is easier to read as it's red  ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| ms51ves3 |
| The Shaggy D.A. |
 Posted: 18:38 - 05 May 2011 Post subject: |
Did you find you had to pinch the tube at all to stop fluctuations, or was it fairly smooth to read untouched? ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| ms51ves3 |
| ms51ves3 |
| The Shaggy D.A. |
 Posted: 18:05 - 10 May 2011 Post subject: |
I found that carb #2 on a CB500 requires a spigot adaptor to put the tube on. Which I don't have
https://dz99.fw.hu/carb_synch_CB500.pdf
I'm just wondering now if a brake caliper bleed nipple might fit... ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| ms51ves3 |
| herulach |
 herulach World Chat Champion
| sickpup |
 sickpup Old Timer
| 2wheelsteve |
 2wheelsteve Spanner Monkey
 Posted: 22:11 - 27 Sep 2011 Post subject: |
| The Shaggy D.A. |
 Posted: 18:41 - 29 Sep 2011 Post subject: |
Finally
https://www.bikechatforums.com/files/manometer2.jpg
For next time :-
1. Use a longer bit of wood.
2. Or less fluid.
3. Put it on the floor, not on the bike. Otherwise when you overadjust, the fluid goes over the top bend and heads to your carb. Meaning you kill the engine, and have to wait to get the fluid back in the loop again. Meaning the carbs will run out of fuel restarting it. Again. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
The last post was made 14 years, 351 days ago. Instead of replying here, would creating a new thread be more useful? |
