Rotary tools/Dremels -> Advice on fairing repairs please
nick.h
PostPosted: 16:02 - 13 May 2011    Post subject: Rotary tools/Dremels -> Advice on fairing repairs please Reply with quote
I'm in need of one of these to do some fairing repairs.
I'm thinking:
Dremel
Plastic weld/Upol filler
Sand paper - various
primer
paint
Is it worth being the cheap ones 'silverline' are are dremel worth the extra?
Also any advice on fairing repairs would be great, as i've got it all to do, scratches, cracks and rebuilding missing parts.
Thanks, Nick
[Italjet MM5A] ll [Rieju RS1 Evolution] ll [Suzuki GS500e] ll [Suzuki GSX600F] ll [Honda CG125] ll [Pug Elyseo 125] ll [Yamaha YZF750R] ll [Yamaha Thunderace] ll [Yamaha R6] ll [Triumph 955i] ll [Hayabusa RZK3] ll [Suzuki RGV250] ll
PostPosted: 16:07 - 13 May 2011    Post subject: Reply with quote
I'd like to think that the Dremel tooling is a better quality than the Aldi ones i foolishly bought.
BTW dremel tooling doesn't fit the Aldi one.
DrDonnyBrago
PostPosted: 16:14 - 13 May 2011    Post subject: Reply with quote
The dremel tools themselves are pretty good and possibly worth it, reckon any good branded one would be good enough too though. I'd probably avoid a really cheap tool though just because everyone complains about them online.
Dremel branded accessories are horrendously priced, buy all the bits etc online without dremel branding for cheap: fibre reinforced cutting wheels is what you will need for most things and the cheap ebay ones are really good.
stirlinggaz
PostPosted: 16:32 - 13 May 2011    Post subject: Reply with quote
best one i had was a 20 quid argos job, challenger i think.
used it every other day for drilling & cutting steel etc.
more torque than the cordless dremel i have now.
lasted 4 or 5 yrs, which isnt much for tools, but i did really use it though.....
i'd certainly buy another cheap corded one...
cheers,
GAZ
skatefreak
PostPosted: 16:41 - 13 May 2011    Post subject: Reply with quote
I got an aldi one,
seems to be pretty awesome although i havnt found many excuses to play with it yet Neutral
-Jvr
nick.h
Well that lasted long, just brought this one:
https://www.amazon.co.uk/Draper-79340-230-Volt-Multitool-Accessories/dp/B000ELJ0HY/ref=sr_1_4?ie=UTF8&qid=1305299659&sr=8-4
Advice on fairing repairs/products/decent guides to use would be great Thumbs Up
nick.h
PostPosted: 20:39 - 15 May 2011    Post subject: Reply with quote
Sod's Law!!
I was in wilkinsons today and saw the draper I have just bought for £18
Good deal, but couldn't cancel my order
Frost
PostPosted: 21:08 - 15 May 2011    Post subject: Reply with quote
To be honest all replacement plastic i've ever attempted has been shit in comparison to well done fibreglass. They do a tissue like fibre which if used in many thin layers works very very well. course you have to make sure it bonds properly.
Filler is useful, what's it called? P-38?
Don't be tempted to use primer or colour to fill in scratches. Always turns out shit.
skatefreak
PostPosted: 21:15 - 15 May 2011    Post subject: Reply with quote
On the subject of fibreglass, i found it gets really brittle and cracked.
It could have been that i used fastglass that cures really quickly (<5 mins to work with the stuff), so when i get time i'll remove what i did and try it with less resin and maybe some woven cloth...
To make a good mating surfact I found a regular drill bit (not wood), in a dremmel and used at a 45 degree angle would leave a mighty rough finnish (for fibreglassing inside/out of sight).
For melting plastic, not worth it if its a load baring area, fibre glass may last longer!
If you are doing many pannels and have time, start with the least visible one and try a technique, see how it goes and if it goes well, carry on the same or else change the technique maybe?
Best rwegards
-Jvr
Frost
PostPosted: 22:13 - 15 May 2011    Post subject: Reply with quote
It's a composite, so the 2 parts need to work together. The resin mix is brittle and hard. The weave is flexible, put the 2 together and what you get is greater than the sum of the parts. You can adjust the setting time by putting in more or less harder. Mixing it COMPLETELY is essential.
https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_161949_langId_-1_categoryId_165625
Is shit.
https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_161890_langId_-1_categoryId_165625
Is what you want. It's really thin, so do 4-5 layers to tack it in place, then another 4-5 layers, followed by another 4-5 layers. Doing it all in 1 thick lot always fails. Use as little resin mix as you can till the final layer.
ZRX61
Victor Meldrew
PostPosted: 01:15 - 16 May 2011    Post subject: Reply with quote
If the fairing etc is made from ABS then using fibreglass to repair it is just wrong from the start.
But go ahead anyway as countless people will disagree with me, & when you get done, you might want to try pissing into the wind.
They're not one night stands, they're auditions.
The last post was made 15 years, 170 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 71.97 Kb
