pistons out of calipers with a compressor - how?
HoggyF
PostPosted: 13:28 - 14 May 2011    Post subject: pistons out of calipers with a compressor - how? Reply with quote
How do you guys connect your compressor to a caliper to blow the pistons out?
I imagine you must have to use something in place of the bleed nipple but what is it?
Gazdaman
I did a trackday!!!
PostPosted: 13:35 - 14 May 2011    Post subject: Reply with quote
I think most people just pop the banjo bolt out and blow down that hole, maybe use a bit of rag so as to not damage the threads.
I normally use the actual hydraulic action to push the pistons out. Pump them out about as far as they go, then you can tend to pull them out as long as you're careful with a set of mole grips (and something to protect the chrome on the pistons).
Gaz
PostPosted: 13:37 - 14 May 2011    Post subject: Reply with quote
A rubber nosed blow gun normally. Although they are not that common there are some on Ebay:-
Ebay link
Gazdaman
I did a trackday!!!
PostPosted: 13:38 - 14 May 2011    Post subject: Reply with quote
Ebay link
Pfft like I said,..bit of rag. Should seal it up well enough, and free (ish).
Gaz
PostPosted: 14:07 - 14 May 2011    Post subject: Reply with quote
Having tried before now with a normal blow gun and some rubber to try and seal it, I had no chance of shifting the pistons compared to the rubber nosed item. Just couldn't get a relatively useful seal.
andym
PostPosted: 14:17 - 14 May 2011    Post subject: Reply with quote
when I done mine I just used a foot pump
Frost
PostPosted: 14:21 - 14 May 2011    Post subject: Reply with quote
I've always used the brake itself to pump them right out. If done right you can get the most seized pistons out so far you can pull them out with your fingers. Another option is mole grips and some rubber inner tube.
HoggyF
PostPosted: 15:55 - 14 May 2011    Post subject: Reply with quote
How do you use a foot pump? does the nozzle that fits onto the tyre valve fit the bleed nipple? (just thougth of that and have never tried it before but I will when I get home tonight!!)
HoggyF
PostPosted: 15:56 - 14 May 2011    Post subject: Reply with quote
Just realised what I posted last and am now waiting on various replays of the "press with yer foot" type - Very Happy
what I menat was how do you connect the foot pump to the caliper! Thumbs Up
Digit
PostPosted: 16:33 - 14 May 2011    Post subject: Reply with quote
Use the brake to push them out as far as possible, if they won't come completely out I use a Jubilee clip around them then pipe pliers/mole grips etc to pull them free.
A compressor blows brake fluid every where!
Roy.
Happy daze!
the grim reaper
PostPosted: 16:42 - 14 May 2011    Post subject: Reply with quote
I cut the valve off every old inner tube I throw away, that with a bit of the rubber around it will screw into the banjo bolt hole and give a good seal. I use my MTB track pump to pop the pistons out.
Grim
stirlinggaz
PostPosted: 21:08 - 14 May 2011    Post subject: Reply with quote
I use that white stuff, ptfe tape its called, iirc.
just wrap it round the air duster nozzle & force it in to the bolt hole.
pistons fly out at a dangerous speed though...seen then land down the other end of the garden.
wouldnt like to get my fingers in the way....
cheers,
GAZ
bagger
PostPosted: 21:19 - 14 May 2011    Post subject: Reply with quote
ive just removed the pistons out of a spare set of calipers ,i used a m16 rawl bolt just push in tighten the bolt down just enough so it grips the inside without distorting the piston then pull out
easy Wink
(m16 is for a 25mm hole upwards)
sv650s,cb350s
andys675
PostPosted: 21:31 - 14 May 2011    Post subject: Reply with quote
be careful using compressed air, I shot my CB250rs caliper piston about 40ft up the workshop as a youngster, and at some speed
prawny1
PostPosted: 02:02 - 15 May 2011    Post subject: Reply with quote
First you need an old brake line with a good banjo then you cut the hose to your desired length then you buy/scavange a metal tyre/schreider valve you screw it into the cut end and jubilee clip it best part is you can reuse it as often as yoiu like.
This type of hose lets you use anything from a compressor powered tyre blower to a foot pump to pressurise the caliper, the valve means you can retain the pressure whilst not having to keep the air feed on constantly.
If your free moving piston comes completely out don't worry just clean it up and refitt it the wedge a spanner in the caliper in the space the disc usualy occupies that way the piston can only travel so far out when it stops the other more stuck piston should begin to move.
hellkat wrote:
prawny1
PostPosted: 02:07 - 15 May 2011    Post subject: Reply with quote
A guy i used to work with years ago smashed the element in the workshops calorgas fire useing to high pressure on some realy stuck pistons, it sounded like a bloody gun going off when they let go.
HoggyF
PostPosted: 22:22 - 15 May 2011    Post subject: Reply with quote
cheers guys - some good tips there, easy once you know how! Thumbs Up Very Happy
retrobiker
PostPosted: 16:01 - 16 May 2011    Post subject: Reply with quote
not sure if this is the same but on my cb550 to get the piston out i used a grease gun screwed into the caliper, kept the bleedscrew in
pumped it a few times and out it popped
The last post was made 15 years, 150 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 98.06 Kb
