| chris-red |
| jimbothe |
 jimbothe World Chat Champion
 Posted: 17:18 - 14 May 2011 Post subject: |
Worn headstock bearings.
Binding front brake.
Broken spring internal.
Those are the three that come to mind. ____________________ Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle |
| chris-red |
| G |
 G The Voice of Reason
| chris-red |
| chris-red |
| MarJay |
 MarJay But it's British!
| evoboy |
 evoboy World Chat Champion
| Ingah |
 Ingah World Chat Champion
 Posted: 17:23 - 16 May 2011 Post subject: |
I would have checked the tyre (both pressure and odd wear pattern), then bearings. Head bearings if a bit tight can cause odd problems (you seem to land up constantly over correcting).
Is this a new or old Thunderbird? If the older one then it is like Charlottes, and the brakes stick rapidly (they are also very easy to strip and rebuild).
 Posted: 17:41 - 16 May 2011 Post subject: |
Binding brake would cause that, or as said a problem at the back end.
To check the brakes, go for a short ride without touching the front brake. Come to a stop using the back brake then flick a ball of spit at the front discs. If they're hot, there's your problem.
A soft back tyre will play havoc with the handling. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 15 years, 151 days ago. Instead of replying here, would creating a new thread be more useful? |
