| dextersaurus |
 dextersaurus World Chat Champion
 Posted: 15:24 - 18 May 2011 Post subject: Triumph TT600 - Misfiring - we have a diagnosis! |
So, just in time for the BCF BBQ, the bike has decided to be an absolute bastard.
Went out for a run today, noticed it struggled to start but put it down to not been run in the past few days.
Took it to the triumph garage to get the fuel mapping sorted out, and noticed on the way there the idle speed was just below 1k RPM...
Then the fuse for the headlight blew.
Then the fuse for the indicators blew.
Then i noticed a burning smell.
Perfect, it's happening again.
They plugged it in, nothing. wouldn't pick up anything from the ECM. The guy told me 'there's a wiring fault, you'll have to sort it out, we can't do anything.'
Problem is the generator/stator coil putting too much into the reg/rec and it's melted the wiring loom. again.
So to fix this, am i correct in thinking i need to buy a new stator coil, new loom, and new reg/rec?
That'll come to just under £200 for the lot, so if i'm right, i'll get buying.
Dunc
| MarJay |
 MarJay But it's British!
| dextersaurus |
| MarJay |
| ThoughtContro... |
 ThoughtContro... World Chat Champion
 Posted: 16:03 - 18 May 2011 Post subject: |
Dunc, the stator is only a series of windings of some copper wire wound round a soft iron former to increase inductance. If it's the right one for the bike, and it's been wound correctly out the factory then how can it be putting out too many volts for the Reg/Rec? The Reg/Rec is designed to dump any excess voltage the Alternator windings produce, that's a part of it's job of regulation. Failures in the stator are going to be either dead windings or a physical breakdown in the enamel covering causing the windings to become ineffective. Both of these would usually result in reduction of alternator voltage, not an increase.
Either the Triumph Reg/Recs are utter shit or their wiring is made by Italians causing the Reg/Rec to short out and burn up. I hope you just replaced those fuses that blew and not shorted them out (?), as that is the worst thing you can do.
Check the resistance of each of your stator windings to see if they're in spec, and the output of the same. Unless there is some mad measured output voltage that's way out of spec, I'd suspect the wiring loom and the Reg/Rec were the primary culprits. The stator is probably fine unless you've been giving it too much Irn Bru
Just a guess.You have got their Service Manual or Haynes for the bike? ____________________ Prize cunt
"In a world of universal deceit telling the truth is a revolutionary act" - George Orwell |
| ThoughtContro... |
| dextersaurus |
 Posted: 16:10 - 18 May 2011 Post subject: |
I see... i'm just going by what i've been told.
The bike has been dropped on both sides, judging by the state of the covers, and is leaking oil from the left side cover, so i'm guessing someone's had that off to get to the stator and not bothered with a gasket.
I don't have the time or tools right now to get in and test the resistance on the stator, i'd rather spend the money on a new one now and not worry about it...
It had this problem with the last owner, who, instead of replacing, had it repaired with an upgraded reg/rec. wires melted due to the problem.
Would you recommend, since i have the money, to just buy the new parts and see if that fixes it? if not, i can sell the old parts anyway.
Of course i replaced the fuses
Couldn't remember fuse the indicators took, so put a 10 in, that blew... put a 15 in, that blew, then put a 20 in, and that blew too. so i've left it with no fuse so no indicators, and no headlight.
Not going to use the bike again till this is fixed.
Dunc |
| dextersaurus |
| ThoughtContro... |
 Posted: 16:30 - 18 May 2011 Post subject: |
| Mr Dunkable wrote: |
If you had a short that's killing fuses and you upped the 10A fuse too 20A, then you definitely fried your loom and made any shorts or wiring faults much worse. If the wiring is only rated for 10A, sticking a 20A in is like turning up the heat to supermelt. The shorts could have fried the Reg/Rec good and proper, if it wasn't already FUBAR.
You should be able to measure stator resistance from the wiring connection to Reg/Rec. Just disconnect the connector and measure across the three windings. They should all measure in the same ballpark, probably less than an Ohm. 1(overrange) is a dead winding or the wiring to it is broken. 0.0 is a shorted winding. You'll need a cheap multimeter tho, from Maplins or elsewhere.
If you've got the cash, and can afford it, I'd replace the lot if you suspect the stator is dodgy. ____________________ Prize cunt
| dextersaurus |
 Posted: 16:50 - 18 May 2011 Post subject: |
| N cee thirty |
 N cee thirty Banned
 Posted: 16:55 - 18 May 2011 Post subject: |
D: is that bare wire hanging out ____________________ '00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30 Mod 2 Passed 09/06/2011
Jewlio Iglesias wrote: I actually did vote BNP once |
| dextersaurus |
 Posted: 16:59 - 18 May 2011 Post subject: |
some job, isn't it.
| ThoughtContro... |
 Posted: 17:25 - 18 May 2011 Post subject: |
The top yellow and black wires at the clear connector. Is that dirt, oil and crud or burned insulation?
If you've got a meter you should be able to test the alternator from that connector. There's a TT600 Service manual on Scribd
Disconnect any lighting fuses before running to minimise any more stuff getting fried. ____________________ Prize cunt
| dextersaurus |
| MarJay |
 Posted: 17:27 - 18 May 2011 Post subject: |
Dunno, but my S4 had a spare what looked like injector connector like that. Never found out what it is for. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| dextersaurus |
| ThoughtContro... |
| MattJ |
 MattJ World Chat Champion
 Posted: 17:42 - 18 May 2011 Post subject: |
Get a CG
HTH |
| dextersaurus |
| ThoughtContro... |
| ThoughtContro... |
 Posted: 18:07 - 18 May 2011 Post subject: |
OK, makes sense. I'd suspect the 3 yellows in the red circle are old Reg/Rec input wires, from when it was last replaced. ____________________ Prize cunt
| dextersaurus |
 Posted: 18:11 - 18 May 2011 Post subject: |
New wiring loom is in the post, with the alarm.
Think i'll pull the flywheel and stator coil so it's ready to just go straight in when i get the new one, and i'll get the wiring tidied up for then.
Hopefully fixes my problems
Dunc |
| ThoughtContro... |
| dextersaurus |
| ThoughtContro... |
The last post was made 15 years, 166 days ago. Instead of replying here, would creating a new thread be more useful? |
