GSXR 750 WN - Need to get ignition barrel out
davej311
PostPosted: 20:39 - 19 May 2011    Post subject: GSXR 750 WN - Need to get ignition barrel out Reply with quote
Hi, yes I've lost my keys, so I gather what I need to do is get my barrel out & send it off to get new keys. How do I do this, & do I need any special tools?
davej311
PostPosted: 21:39 - 19 May 2011    Post subject: Reply with quote
BLUEX5 wrote:
Can't you order a key using the number on the ignition barrel?
Yes exactly, but don't I need to get the barrel out to get the number?
sickpup
Old Timer
PostPosted: 23:13 - 19 May 2011    Post subject: Reply with quote
Just take off the whole top yoke and post it to Keys Galore, they will sort it out from there.
finpos
PostPosted: 23:48 - 19 May 2011    Post subject: Reply with quote
The visible number on the barrel is just the key blank type; there's sometimes the extra information you need to make the key but that's usually hidden (e.g. on the side of the barrel) for obvious reasons!
f.
davej311
PostPosted: 16:03 - 20 May 2011    Post subject: Reply with quote
So what's involved in getting the top yolk off? I don't have a manual.
D O G
PostPosted: 16:45 - 20 May 2011    Post subject: Reply with quote
Likely just undo the nut which goes through the headstock, undo the pinch bolts around the forks, lift off, unclip the multi connector from the ignition (which will no doubt be tucked away so theives can't easily get at it), and you 'll be done.
Tho probably will need some swearing too. Wink
davej311
PostPosted: 17:22 - 20 May 2011    Post subject: Reply with quote
great thanks. plenty swearing been done already so a bit more won't hurt Wink
The last post was made 15 years, 165 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 62.17 Kb
