| pork6156 |
 pork6156 Renault 5 Driver
| kat250 |
 kat250 World Chat Champion
| MarkJ |
 MarkJ World Chat Champion
| Gazdaman |
 Gazdaman I did a trackday!!!
 Posted: 17:18 - 20 May 2011 Post subject: |
Having a ZZR600 I can understand your feelings. While the brakes might be decent enough when new they seem to be especially prone to turning to a useless mess with a bit of time.
I am not a great fan of braided hoses (not saying they don't work, more that the difference between them and conventional rubber covered braided cloth lines isn't that great compared to the difference from actually bleeding the brakes thoroughly), but if your hoses are wrecked then they are worthwhile.
Having already got braided hoses and being sick of stripping the useless calipers down (especially when once I could get them to bleed through despite new pistons and seals) I am tempted to go with the Honda calipers and small spacers. Think you need a top hat shaped spacer to go from the 10mm ZZR mounting bolt holes on the forks to the 8mm bolts the Honda calipers use, top hat shaped to offset the calipers slightly.
| Vincent |
 Vincent Banned
 Posted: 18:39 - 20 May 2011 Post subject: |
I picked mine up for £25 on eBay As new condition too. Gotta admit, they are very well designed and put together. |
| Vincent |
 Vincent Banned
 Posted: 18:47 - 20 May 2011 Post subject: |
Honda use the 8mm bolts as standard, so you can keep using the bolts that match the calipers. I would be rather more worried about chopping some material away from the caliper where it mounts.
That said, some people seem to have got away with just bolting on the Honda calipers without spacers, just doing the bolts up tight to try and keep them in position .
| Vincent |
 Vincent Banned
 Posted: 21:02 - 20 May 2011 Post subject: |
I'd be tempted to use some green bearing fit on the sleeves or make them marginally oversize for an interference fit and sweat them in, then they wont be going anywhere.
I think honda use stretch bolts there anyway? Once they're nipped up tight to the correct torque, it's all acting like a single piece of metal anyway. The bolt itself wont be subjected to much in the way of shear stress. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 15 years, 155 days ago. Instead of replying here, would creating a new thread be more useful? |
