YBR 125 Wheel Bearing-Removal/Replacement
sparkywilliam...
PostPosted: 12:08 - 23 May 2011    Post subject: YBR 125 Wheel Bearing-Removal/Replacement Reply with quote
Excuse the newbie query,I know lots just use a socket and hammer them out but if i was to buy the proper tool for it can anyone point me to a website?
Ta
Previously CG125,YBR125 Now GSF600 Bandit
Quote Me Happy
PostPosted: 12:25 - 23 May 2011    Post subject: Reply with quote
Don't use a proper tool (bearing puller?) just tap them out using a hammer and drift. Use a hammer and socket to tap the new ones into place. Make sure the socket fits onto the outer race of the bearing not the inner race.
neil.
PostPosted: 12:52 - 23 May 2011    Post subject: Reply with quote
I used a hammer and drift to start the process then a slide hammer bearing puller (about £30 off eBay) to drive the bearings right out once I could get decent purchase on them (you need a gap so the jaws can get under it). Used a socket to drive the new ones in, being careful to make sure that no force was put on the inner races.
Quote Me Happy
PostPosted: 12:55 - 23 May 2011    Post subject: Reply with quote
No need to use a bearing puller as once they've moved a bit they're easy to get out. You can always use the trick of heating the hub to help them out and in plus freezing the new bearings.
sparkywilliam...
PostPosted: 13:02 - 23 May 2011    Post subject: Reply with quote
appreciate your wisdom but i'm fed up whaling on the end of a hammer,so a tool is what i'm after but i'm not sure if it's a standard bearing puller or blind bearing puller that i need.Seen some mighty dear one from the likes of symes-pikavant-any advice?
Wilson12345 This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
yen_powell
PostPosted: 13:15 - 23 May 2011    Post subject: Reply with quote
With a good drift a bearing can be removed in less than 5 blows. Most bearing pullers need to be assembled before use. You only really need them when the bearing is sitting in a hole with only one entrance.
XT1200Z and a DR350 in bits
PostPosted: 13:24 - 23 May 2011    Post subject: Reply with quote
If you've been whaling on the inner race with a hammer and drift and it isn't moving, check you've removed any circlips.
You might also have got it "wedged" at a slight angle (you should move round the inner race so it comes out square). If it is wedged, you're best to drive it back in then start again.
sparkywilliam...
PostPosted: 13:57 - 23 May 2011    Post subject: Reply with quote
no i've not attempted anything yet,just thought it best to check if there was a simple tool that would make a clean job of it.
I get the impression it's not needed.
Quote Me Happy
PostPosted: 13:59 - 23 May 2011    Post subject: Reply with quote
A length of bar with a decent sharp lip works for me as it catches nicely on the bearing edge.
PostPosted: 14:09 - 23 May 2011    Post subject: Reply with quote
I find it much easier with a proper tool steel drift rather than a bolt and I usually make sure the end is square by filing/sanding it prior to use.
Done many of them this way, never had a problem (other than forgetting a circlip on occasion).
PostPosted: 21:33 - 23 May 2011    Post subject: Reply with quote
I noticed a lack of any videos on youtube showing how to remove motorcycle wheel bearings without the use of unecessarily expensive tools.
As it happens, I needed to remove some bearings from a wheel I got off the breakers so I videoed it.
Most of the video is of me battering away at one of the bearings that, as it turns out, was in pretty solid due to corrosion round the outside of it. As soon as I swapped onto the other one, it waltzed out. As soon as you get one of them moving, it all gets a lot easier.
I videoed the entire job which took 6 minutes but would have taken 2 if I'd started with the other bearing first (random chance).
I'll do another one of me fitting the new bearings once they arrive.
https://youtu.be/obPQMiQgZv0
retrobiker
PostPosted: 21:46 - 23 May 2011    Post subject: Reply with quote
when i did my bearings on the cb550, best tip i got was heat the
hub with a heat gun, not roasting but just too hot to touch
few whacks at 12,6, 3 and 9 oclock and out it popped
Fairies attack This post is not being displayed because the poster is banned. Unhide this post / all posts.
PostPosted: 00:17 - 25 May 2011    Post subject: Reply with quote
As promised. Bearing fitting.
Not the best way, not the only way, but one way.
So 2 unedited videos. Old bearings out, new ones in. 14 minutes.
https://youtu.be/DMDNjfcVRss
sparkywilliam...
PostPosted: 16:14 - 25 May 2011    Post subject: Reply with quote
brilliant,thanks Stinkwheel
The last post was made 15 years, 157 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 92.63 Kb
