| sparkywilliam... |
 sparkywilliam... Scooby Slapper
 ..... Quote Me Happy
| neil. |
 neil. World Chat Champion
| sparkywilliam... |
| Wilson12345 |
 Wilson12345 Could Be A Chat Bot
| yen_powell |
 yen_powell World Chat Champion
| N cee thirty |
 N cee thirty Banned
| stinkwheel |
 Posted: 13:24 - 23 May 2011 Post subject: |
If you've been whaling on the inner race with a hammer and drift and it isn't moving, check you've removed any circlips.
You might also have got it "wedged" at a slight angle (you should move round the inner race so it comes out square). If it is wedged, you're best to drive it back in then start again. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| sparkywilliam... |
| stinkwheel |
 Posted: 14:09 - 23 May 2011 Post subject: |
I find it much easier with a proper tool steel drift rather than a bolt and I usually make sure the end is square by filing/sanding it prior to use.
Done many of them this way, never had a problem (other than forgetting a circlip on occasion). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| stinkwheel |
 Posted: 21:33 - 23 May 2011 Post subject: |
I noticed a lack of any videos on youtube showing how to remove motorcycle wheel bearings without the use of unecessarily expensive tools.
As it happens, I needed to remove some bearings from a wheel I got off the breakers so I videoed it.
Most of the video is of me battering away at one of the bearings that, as it turns out, was in pretty solid due to corrosion round the outside of it. As soon as I swapped onto the other one, it waltzed out. As soon as you get one of them moving, it all gets a lot easier.
I videoed the entire job which took 6 minutes but would have taken 2 if I'd started with the other bearing first (random chance).
I'll do another one of me fitting the new bearings once they arrive.
https://youtu.be/obPQMiQgZv0 ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| retrobiker |
 retrobiker Renault 5 Driver
| Fairies attack |
 Fairies attack Banned
| stinkwheel |
| sparkywilliam... |
The last post was made 15 years, 156 days ago. Instead of replying here, would creating a new thread be more useful? |
