| P3TR0L H34D |
 P3TR0L H34D Two Stroke Sniffer
 Posted: 17:04 - 24 May 2011 Post subject: Bike wont start, unless I bump it??? |
Iv just bought my bike (Yamaha DT125RE) and when I bought it, I saw it running. It then fell over in transit and wouldn't start, so I left it alone for 48 hours and had another try. By this time the battery was too flat to start it! GGRRR!!
I then tried to charge the battery and discovered it needed a new one. I then purchased another battery, charged and fitted it. Cleaned the crap out of the air filter, re-oiled and put back. Put a new iridium spark plug in. Changed the oil and generally inspected the bike.
Still it would not start!! So I bumped it and it fired up on the third attempt. I ran it for 10 mins and turned the idle speed up, so it was ticking over fine. Then hit the kill switch and tried the electric start once again and it STILL won't start!! It will start if I bump it though
I took the new spark plug out and it was VERY black, so obviously running rich and when it was first started it was slightly spluttery.
Can someone please advise me, thanks in advance  |
| Paxovasa |
 Paxovasa World Chat Champion
| P3TR0L H34D |
| krytenboog |
 krytenboog Nova Slayer
| stirlinggaz |
 stirlinggaz World Chat Champion
| skatefreak |
 skatefreak World Chat Champion
 Posted: 19:23 - 24 May 2011 Post subject: |
he has just bought a new battery
I found that when my NSR blew a reg and the battery started going down hill, it would crank the engine over for ages but not start, turned out the battery only had enough amps to turn the starter to give a good spark but not both
Asside that, no clue. Try charging again?
Do you have a multimeter?
-Jvr |
| Pete. |
 Pete. Super Spammer
 Posted: 19:25 - 24 May 2011 Post subject: |
Your bike fell over, then won't start from cranking and the idle has changed?
Clean out the carb. ____________________ a.k.a 'Geri'
| P3TR0L H34D |
The last post was made 15 years, 55 days ago. Instead of replying here, would creating a new thread be more useful? |
