| Shaft |
 Shaft World Chat Champion
 Posted: 22:14 - 24 May 2011 Post subject: Anyone know what this is? Cat Valve |
I posted this pic in my 'show & tell' moped project thread, but I wondered if I might get a better response here:
https://img69.imageshack.us/img69/3286/artycopy.jpg
I have very little experience with modern bikes in general and scooters in particular, so this has got me stumped.
The armoured hose appears to run to the airbox, so I'm guessing it's some kind of emissions gubbins, but there's no electrical connections, so whatever is in that box must be heat/pressure operated.
I was planning on changing the exhaust, but would removing this alter the way the bike runs and what would I do to rectify it?
Sorry if I'm asking the bleeding obvious, but I've not come across anything like this before. ____________________ Things get better with age; I'm close to being magnificent........
| Fisty |
 Fisty Super Spammer
| Shaft |
 Posted: 22:19 - 24 May 2011 Post subject: |
Ho bloody ho  ____________________ Things get better with age; I'm close to being magnificent........
WooHoo, I'm a Man Point Millionaire! https://www.bikechatforums.com/viewtopic.php?t=234035 |
| heehaw |
 heehaw Nova Slayer
| Shaft |
 Posted: 23:04 - 24 May 2011 Post subject: |
Eh?
| N cee thirty |
 N cee thirty Banned
| Shaft |
| Pete. |
 Pete. Super Spammer
 Posted: 20:58 - 25 May 2011 Post subject: |
It's a valve for pumping fresh air out of the airbox into the exhaust to supply oxygen for burning off any un-spent fuel. Has no effect on engine performance. ____________________ a.k.a 'Geri'
| Shaft |
 Posted: 21:17 - 25 May 2011 Post subject: |
Thanks for the explanation Pete, the only thing I've seen like it is on old Yank car engines, where they used to fit all sorts of Heath Robinson contraptions, usually with devastating effects on performance.
If there's that much fuel in there, I might tap it for a spark plug  ____________________ Things get better with age; I'm close to being magnificent........
| stinkwheel |
 Posted: 21:41 - 25 May 2011 Post subject: |
Aye. Also called a passive air valve. Bleeds air into the exhaust to reduce emissions.
They sometimes have a vacuum takeoff from the carb to open and shut the valve. Remember to blank this off if you remove it or you'll run lean. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 15 years, 151 days ago. Instead of replying here, would creating a new thread be more useful? |
